Question about OKI B4600 Printer
OKI b4600 has black line along left edge of copies
Buschchris1
  • 474 Answers
SOURCE: OKI B4600 Printer will not print = error - paused
Does it have a control panel or buttons on the printer itself?
If so, are any of them blinking or red?
Sometimes an error will cause a pause in the printer and you have to press one of the buttons to get it to start back up again.
http://my.okidata.com/PP-B4600-Black.nsf?opendatabase
This is the link to the manuf. website. I did a search on your model, theres a few so i guessed. but the manuals are available along with drivers.
I suggest you go and update them and go through the PDF and see if there is anything partaining to this issue.
I went through the PDF a bit and didnt see anything partaining to the PAUSE issue but try going through and see if anything is it.
On the printer icon on the bottom right of your task bar, right click on the printer icon and see if you can select CANCEL print job, then try unpausing it. Also, power off and then power back on and see if that clears it.
You may have to un-install the printer and re-install it and update the drivers to clear it.
Sometimes a Print job will get stuck in que when theres a jam or something and it wont continue till the issue is resolved, then you open and close the top cover and that resets it, it rechecks then continues.
Good luck.
Posted on Feb 04, 2009
SOURCE: oki b4600 drum reset ?
On the printer press the menu button until you reach MAINT.Then press the item + button until you reach DRUM CT RESET. Then press select.YOUR DONE!!!!!!!!
Posted on Jul 09, 2009
SOURCE: How do I set OKI B4600 to print to top tray?
On the back tray where the paper comes out just push the extra piece in that helps to catch the paper until it clicks and it will automatically start coming out the top so you pages are in the order that you want them to be.
Posted on Oct 07, 2009
Testimonial: "The one and only answer!!!!"
SOURCE: resetting image drum after replacing for oki b4600
Posted on Oct 30, 2009
  • 97 Answers
SOURCE: oki b4600 displays check image drum toner senror error
Try this:
Press Online
Press Menu repeatedly until MAINTE MENU displays. Press Select.
Press Item+ until DRUM CNT RESET displays.
Press Select.
Posted on Mar 29, 2010
My B4600 only prints a single copy
You don't say which version of windows you are using. There is no windows 10 driver so you would be picking up a generic driver when plugging in via usb. If windows 7 or 8 then UNINSTALL (not delete) the Universal driver and install the US version 2.2.6. It wont be the printer as printers only print what they get. Its definitely a driver issue.
Mar 21, 2017 | OKI B4600 Printer
One of my employees use an Oki B4600. When she tries to print, it kicks the main tray out. This results in paper not being able to feed then it says paper jam (even though there is not an actual jam). Any...
Try to clean every rubber roller in the printer. Make some soft "paper" wet with vinniger (Juuice from grapes (not to drink but for in salad's)) and rub it over the rollers. So they can transport paper better.
If possible, removing the rollers, and then cleaning.
Ralf.
Dec 03, 2013 | OKI B4600 Printer
Okidata b4600 printer printing light on some area after replace toner and drum.
Open the top cover and take a damp rag clean LED array (thin black strip attached to cover). Then print a cleaning page.
Mar 19, 2013 | OKI B4600 Laser Printer
We have an Oki B4600 Laser Printer. It is about 6 months old and has started printing vertical white lines through our pages. It originally came with a toner that was half full (I was told) so we quickly...
This is a simple and common problem with many LED print head printers. You just have toner dust on the surface of the print head. Run your finger along the head and all will be well.
Jun 16, 2017 | OKI B4600 Laser Printer
My OKI B4600 is displaying error 134
It means the printhead [laser] is "missing" - but usually it's just the data cable at the end of the printhead has popped out. Very common - we have hundreds of Okis at our corp and I've fixed this many times. Turn the power off, pull either the left or right plastic clip AWAY from the printhead, and carefully insert the data cable back into the connector on the printhead. Put one end of the printhead nearest the data cable back into its plastic clip, and make sure the spring is seated on its little post on the bar, and then click the rest of the printhead into the clip on the end opposite of the data cable, again making sure the spring is seated on its post. Turn the printer on - your error should now be gone.
Mar 01, 2011 | OKI Electric Industry B4600 Laser Printer
Oct 07, 2009 | OKI B4600 Digital Mono Printer - Black
Oki b4600 drum reset ?
Jun 19, 2009 | OKI B4600 Printer
Is there a menu thing on the screen somewhere
Feb 04, 2009 | OKI B4600 Printer
OKI B4600 Printer Logo
42 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
