Question about Amana Dryers
PROBLEM WITH AMANA DRYER
I have an Amana Dryer model #LE4307W. The drum will not rotate when the switch is on unless you sort of give it a push with the door open. Close the door quickly and it continues to rotate, but will not start by it's self. If you try and load cloths while it is turning it will stop. I can hear a humm coming from inside. I have replaced the belt and the rollers are free to turn. Any ideas?????
    Top Expert:
  • Amana Master
  • 9,472 Answers
If you have to"push start" the motor to get it going, you will need to replace the motor. The windings have become weak and cannot get the initial start cycle going. Here is the motor to order.
The part comes with a 365 day, any part, any reason return policy.
Posted on Nov 09, 2012
  • 1 more comment
  • John Towner Nov 09, 2012
    Thanks, that's where I was headed. How difficult is it to replace the motor. I am pretty mechanically able.
  • Richard Roth
    Richard Roth Nov 09, 2012
    It is really simple to replace the motor. It just involves a couple of screws and the belt removal. If you order the motor thru that link I supplied, they have a 365 day, no questions asked return policy. Other parts distributors have 30 days and most won't cover the electrical components at all. Let me know if you run into any problems while you are installing the motor. I am pretty much here 12 hours a day.
  • John Towner Nov 12, 2012
    I have ordered the motor and hopefully that will correct the problem. Thanks for the help.
  • 92 Answers
SOURCE: amana distinctions dryer
motor is probably locked up or you have a sock in the blower wheel or mabe even a little critter if you outside vent doesnt have a screen
Posted on Feb 10, 2008
SolutionGuy
  • 331 Answers
SOURCE: Amana gas dryer buzzes and won't start
Jeff, what you are describing is a drive motor that is locked up. The only cure for this is to replace the motor. This is probably the most difficult repair to perform on a dryer. You will need to have a lot of patience if you choose to proceed.
I looked up the motor for you, it's a part number 511629P and it lists for ~$145.00. That's alot of clams for a motor! And I presume this unit has some years on it, right? Which means that if you replace the motor, there's a good chance that another component will fail soon.
I'm not trying to dissuade you from a repair, I'm just mentioning possible options. But, if you want an opinion on this, mine would be to replace the dryer. I know this isn't what you wanted to hear, but I hope it helps you decide what to do.
If you choose to repair, write back and I'll do my best to walk you through the procedure.
Posted on Dec 24, 2008
  • 40 Answers
SOURCE: My GE Dryer model DWSR483EA1ww will not stop & doesn't dry quick
first thing you should do is check the flow of your vent, a clogged vent can cause all your problems check it outside while the unit is running you should get really good flow compare it to the flow of the dryer with the vent hose off the dryer completly. they should be fairly close or just run it with out the vent hooked up to the vent if you have an electric but not with a gas dryer
Posted on Mar 09, 2009
SOURCE: When turning the knob to start dryer, buzzing sounds but drum doesn't start to turn unless you gently push atart the inside drum
The problem is either a faulty start winding in the motor, or the circuit which energizes the start winding is failing.
A dryer motor has two windings: start & run. The start winding gets it going and a centrifugal switch disconnects the start winding when the motor gets up to speed.
Check the dryer start switch -- then the motor connections and the centrifugal switch inside the motor.
Posted on May 05, 2009
protek480
  • 1714 Answers
SOURCE: Amana Heavy Duty Dryer turns on and gets hot but wont turn inside
watch the video
Posted on Jul 10, 2009
My Amana distinction started making a loud sound like maybe the belt and I have to take cloths out of it. Now it stopped altogether. Is it the belt or drum?
Amana Dryer Makes Noise - Model DLE330RAW - Repair ...
www.repairclinic.com/...-/Amana-Dryer-makes-noise-DLE330RAW
When the drum rollers are worn out, they can cause the dryer to make a loud rumblingnoise. To determine if the rollers are worn out, inspect the rollers. If one or ...
Nov 26, 2015 | Amana Dryers
What could possibly the reason my amana dryer wont tumble and just buzzes when you push the start button
Could be a broken belt spin the tumbler by hand it if it spins real easy the belt is off or broke another thing to try if you have resistance when turning the drum have a helper for this one open the door and hold the door switch in set timer to a cycle and press start while holding switch and buzzing spin drum and see if it will continue to rotate while holding switch if so motor going bad
Feb 17, 2015 | Amana Dryers
My Amana gas dryer Model NDG7800AWW heats initially and then stops.
Hi Mohit , you need a new set of valve coils . It's part # 5303931775 GOOD LUCK APPLIANCES R'EN
Jun 17, 2014 | Amana NDG7800AW Gas Dryer
Dryer not running, just getting a click.
check you drum belt. if belt is broken nothing will come on.
Feb 25, 2014 | Amana NED7200TW Electric Dryer
I have an Amana LE4307W. The problem is the squirrel cage is rubbing against the front cover at one point. What would cause this? How do I fix it?
the drum (squirrel cage) is guided by wheels that have bearings. They are generally located at the bottom of the drum and more than likely you will have to pull the front of the dryer off to see these bearings. they are not very expensive on most older models but are a fair pain to get to. You should probably replace your belt at the same time.
Apr 06, 2011 | Amana Dryers
Loud squeaking noise from dryer model number LE4307W amana
There are a number of things that can cause noises from your dryer...
Here is a tip that I wrote about this problem...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Mar 31, 2010 | Amana Dryers
I have to manually get drum turning...
Yes, there is a "startup" switch. It's the button you push on the panel (but I'm sure you know about that).
This switch energizes the start winding in the motor -- when the motor gets up to speed, a centrifugal switch in the motor disconnects the power from the start winding and switches to the run winding.
Either the start winding is not getting power or the winding is bad. If "no power" is the problem, it could be the button on the panel or a loose/dirty connection between there and the start winding. Lot of possibilities which need to be explored.
But if you know about pushing the safety switch on the door and spinning the drum by hand to get the motor started, you can probably fix this.
May 04, 2009 | Amana NDE2330AY Electric Dryer
Gas dryer won't run when pushing start. Motor not comming on.
There is a small resetable fuse athe back under the top cover being held by a plate that has a screw holding it in place. To test just connect the wires together. I see this all the time on those modeles.
Mar 15, 2009 | Amana NDG7800AW Gas Dryer
Dryer work turn on, buzzes when start is pushed
It may be just your timer switch. Look at all the wiring first. The receptacle to the plug, cord and into the back of the dryer.
Feb 15, 2009 | Amana Dryers
Amana gas dryer only heats first 20 minutes
Check your ducts that the heat blows out through. make sure there is no plug up in the dryer or in the ductwork.
You may have a problem with the termosensor or the high temp cut out safety switch/sensor. This sensor would be somewhere in the exhaust of the dryer.
Feb 04, 2008 | Amana ALG331RAW Gas Dryer
Dryers Logo
336 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
