Need Help Changing Belt For 2002 Toyato Camry
Can't take the belt off
    President:
  • 948 Answers
One of the six pulleys on your belt is a tensioner. All you have to do is put a ratchet on that and put a little pressure on it and you will be able to have an assistant remove the belt. Pay attention to the routing diagram under your hood, you must follow that when installing the new belt.
Another way (and the way I prefer) is get a crowbar or similar metal object with one flat end and use that to move the tensioner, then have your assistant remove the belt.
Posted on Jan 06, 2009
How to replace 2002 camry drivebelt
to replace the serp belt you'll need to release the tensioner in the system remove the old and install the new the issue always is the proper routing for the belt follow the diagram under the hood watch the routing as you remove the old belt if a diagram isn't available under your hood request one upon the purchase of your new belt sometimes the parts store will loan or rent you the tools you need for belt replacement
Sep 18, 2012 | 2002 Toyota Camry
Need help with 2003 toyota camry 4cyl idle
Changing the belt on your car will not make it idle rough, it would not matter if you put it on backwards, upside down, or inside out. The car would just spin the belt off or chew it up. I think that possibly a sensor wire or a vacuum line was broken or knocked off when you were installing the belt. Look for something like that and I think you will find your problem.
Apr 08, 2010 | 2003 Toyota Camry
Need a diagram
This is a drive belt routing for a Toyota Camry 2002 with a 2.4L four-cylinder engine. I hope this will help you out.
Oct 04, 2009 | 2002 Toyota Camry
Changing the alternator belt
Google "changing alternator belt on 2000 Camry" and I think you will find what you need.
Mar 28, 2009 | 2000 Toyota Camry
Help!
Look carefully under the hood, car manufacturers place a decal w/ the belt routing diagram somewhere under the hood in the engine compartment. If u can't find it, check your owners manual, if u don't have one, let me know and I will research further to find it for u.
Nov 01, 2008 | 2002 Toyota Camry
DRIVE BELT ON 2002 TOYOTA CAMRY
If you are referring to the vehicle having a "Timing Belt", no, it does not have one.
The 2002 Camry 4 cylinder has a Timing CHAIN, and does not need to be replaced.
Oct 28, 2008 | 2002 Toyota Camry
How do i remove serpentine belt to change water pump?
There is a pulley thast moves around a little when the engine is running, this is the belt tensioner pulley, you will need either a special wrench or a ratchet to release the tension on the belt.
Jul 05, 2008 | 2002 Toyota Camry
Computers & Internet Logo
93 people viewed this question
David Payne
David Payne
