What is code 55 on lennox m/n lga088sh1y - Heating & Cooling
Could you please give me the code for a Lennox HG31ES air conditioner? I have just bought a universal remote and haven't got the code. Regards Lynda
I doubt a 'universal remote control' will work for air conditioning. They are for televisions and DVD players.
If it is one of these, it should work out of the box.
Over 2000 CODES, OPERATES ALL LENNOX MODELS.
Full function universal remote control for all brands of air conditioners.
Large electric blue LCD backlight display. A product to satisfy all exigencies, with an attractive design and a full range of original brands covered.
Extremely easy to program with auto-search feature.
With over 2000 codes in the memory it makes this product the most complete on the market.
The big display with Backlight and clarity of indication of the functions complete the huge success of this product.
User manual included.
Supplied with wall mount bracket.
Remote control is gold in colour.
*Requires 2X AAA Batteries.
REPLACEMENT UNIVERSAL LENNOX AC AIR CONDITIONER REMOTE CONTROL FULL...
Or you could ask Lennox direct?
http://www.lennox.com/help
Dec 06, 2016 | Heating & Cooling
Help, I need to replace three remote controls for my Lennox 36,000 btu model LXG RCF. The remote control is LCD5A id#11260508A. HELP, Linda
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Universal remote controls are available at most of the electronic spare part selling shops. Visit some on-line sites too, which deals with electronic spare parts.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 25, 2016 | Universal Televison & Video
Lennox model 80MGF3-75A-2 Furnace will not come on. Where do I start
http://www.ehow.com/info_12194827_led-codes-lennox-80mgf-furnace.html
May 15, 2014 | Heating & Cooling
Lennox elite heat pump throws cold air
The unit should give you an error code if something is wrong.
Here's the manual:
http://instalacionesindustriales.com.gt/pdf/Lennox_Minisplit_HE.pdf
Mar 25, 2014 | Lennox 7 Series MS7-HO-18P MS7-HI-18P Heat...
Lennox codes
I have a gas Lennox elite furnace & code light is not turning on
Jan 13, 2014 | Heating & Cooling
Lennox codes
e5: open or short circut of outdoor yemp. sensor or outdoor unit.
see more Air Conditioning Fault Codes
May 11, 2013 | Lennox 7 Series MS7-HO-09P MS7-HI-09P Heat...
Furnace computer won't let furnace light
What is the model number? I have an SLP98 (installed on 11/29/2011).... and if I take the cover off the front of the furnace the panel that has the fancy "Lennox" badge on it) you will see two clear round windows about the size of a half dollar (one high on the furnace box and one lower on the blower box.) If you look downward into the window on the blower box you can see a red LED display that will sometimes flash error codes like E228 (one character at a time). If your model has something like this, let me know. I've done some DIY fixes recently out of necessity....and their easy.....and several technicians confessed they didn't know much, if anything, about the newer high effieciency Lennox gas furnaces.
Mar 01, 2013 | Lennox Heating & Cooling
Lennox 8 series ms8-z0-2ap3a error code H1, defrost operation
h1: defrosting /normal operation/ normal defrost operation.
see more: Air Conditioning Fault Codes
Jan 16, 2013 | Lennox Heating & Cooling
Replace thermostat
What is the model number of the old tstat and furnace?
Aug 07, 2017 | Heating & Cooling
I am trying to change Lennox to Honeywell
Just remember what wires went to which terminal. Usually color coded, red =R, white = W, etc, Shouldn't be too hard. Let me know if you run into a problem.
Jan 02, 2010 | Honeywell Electronic Programmable...
Heating & Cooling Logo
74 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
