Question about GE Dryers
DRYER NOISE BELT SLIPPING OR DRUM RUBBING - GE Dryers
Lumpy816
  • 246 Answers
SOURCE: Maytag Dryer Loud Shrieking Noise
Here we go. First unplug the unit. Remove the front panel by removing the 4 phillips screws just inside the door (on the hinges and just opposite). Next remove the greenish/ brown 5/16 screws that hold the front panel in. There are wires still connected (door switch and moisture sensor) but if you swing it to the side, you can leave them connected and still procede. Next, you have to reach underneath (very difficult to see this so you will have to do it by feel) There is a belt that wraps around the drum. On the underneath side of the drum as you follow the belt it wraps
around the motor pulley (small wheel) and the tensioner pulley (bigger wheel just to the right). Now with one hand, move the larger pulley towards the msaller one. This will give you slack and you can take the belt off both pulleys. Now pull the drum
forward. There you have the inner workings left. Now, there are 3 wheels. 2 black and 1 white. I would check the white one since you've already replaced the black ones. This is the pulley that provides tension when the motor is running (hence no noise when you take the belt off) I'm betting you'l find it does not turn freely (you should be able to spin it with your finger and have it coast to a stop insdead of stopping as soon as you take your finger off). You can get the replacement wheel from your local appliance parts store or on line from the manufatrues web site. However, if you do have to wait for the part, take the wheel off the shaft and wipe off the inside race of the wheel and the shaft for temporarily relife and useage.
Posted on Jul 09, 2008
SOURCE: dryer makes noise as drum rotates on ge profile gas dryer
Solution: the drum slides were worn out and needed replacement.
Posted on Jan 14, 2009
mikesagenius
  • 24 Answers
SOURCE: frigidaire FER211AS2 dryer drum belt
the washer has to be tipped forward. can access from bottom (and back).
Posted on Jun 03, 2009
dragonsthatk
  • 547 Answers
SOURCE: Belt/Drum Noise
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Posted on Jun 19, 2009
SOURCE: lg dryer - front load - making a grinding noise
I also have the same problem as klrlesimmons, exactly as described. Sounds like sand is rubbing as the drum turns, and also sounds out of balance.
Repairmen replaced upper and lower glides and also the plastic bearing but not the entire bearing assembly.
Frigidaire Gallery, Model Number 417.49012890
Posted on Nov 02, 2010
Dryer runs but makes loud screeching noise like a fan belt or similar. Does some drive belt need to be replaced?
yes most likely it is the drive belt. pretty easy replacement. go to repairclinic.com or appliancepartspros.com for very good videos to show you how this is done. good luck
Jul 11, 2015 | Dryers
Squeeking noise are the barron going bad
Squeaking noises are NOT necessarily an indication of bearing failure - but could be an indication of a slipping belt or something else rubbing. The machine itself may be rubbing against a washer, wall, door jamb, or anything really.
Look around the machine. See if it is in contact - or close to ant of these things. When it is running - it could be bumping against something. If nothing is found - have a look inside the the dryer. Inspect the belt and clean the drum where the belt tracks. Repl;ace the belt it is ready to break, missing parts or de-laminating. If you find shiny metal filings - that indicates metal is rubbing somewhere and is likely to be the cause of the squeak.
Good luck.
Apr 14, 2011 | GE Dryers
My tumble dryer makes a screeching noise
Something is rubbing against the drum or the belt is slipping, either case you will have to remove the top cover to carry out further investigation. There are usually screws at the back of the machine to allow removal of the cover. Take care of live wires when operating the machine with the cover off.
Jan 17, 2011 | Washing Machines
My dryer was squeaking really bad, so I sprayed WD 40 on the pulley & belt, squeaking stopped but the dryer also stopped turning. The pulley still turns but the dryer drum doesn't
The belt is slipping now. Need to clean the WD40 off, use methylated spirits, isopropyl or rubbing alcohol on a cloth.
Jan 02, 2011 | Dryers
Thumping/rubbing sound in drum
The belt tensioner roller has a flat spot caused by a worn bearing that catches and stops whilet the drum is turning. This causes the flat spot and the noise its making. You can purchase a new roller by itself and do change the belt the same time too
Apr 08, 2010 | Frigidaire Electric Dryer
When we turn on our Whirlpool Supreme electric dryer, it heats up and dries clothes, but it is making a loud squeaking noise throughout the cycle...sometimes louder than others.
The squeaking noise can be caused by any of the following.
Location High:
Belt slipping on the dryer drum
Worn Drum seals but would sound more like a dragging noise
Location Low:
Belt tensioner pulley bearing frozen and the idler pulley shaft is spinning inside the belt tensioner assy.
Belt slipping on the motor bearing
Motor bearing is dry
Thanks for using FixYa!
Kelly
Mar 04, 2010 | Whirlpool LER5636P Electric Dryer
Slipping noise on starting the dryer. Belt noise?
belt is probly starting to be worn. and slipping on the drum of dryer make be a weak belt ten.
Dec 03, 2009 | Maytag Dryers
Dryer squeaks while drying sounds like drum rubbing on something
A squeak can also be a slipping belt or something caught between the drum bearings usually the front but could be the back one.
Jun 14, 2009 | Dryers
Squeeks loadly when running
The drum belt is slipping or a support wheel bearing is worn.  Spray some belt dressing on the belt or replace the belt.  Lubricate the wheel bearing or replace it.  It is also possible that the seal between the drum and the housing (at the back) is worn and the drum is rubbing metal-to-metal on the housing.
May 28, 2009 | GE Profile Harmony DPGT750EC Electric...
Rubbing noise
Try checking the glide's under the front of the drum, the drum rest on the glide's to help it spin with little or no friction.
Apr 06, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
97 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
