Indesit widl126 turns itself off
My Indesit machine is suddenly stopping after a minute or two of any program. (Usually use the daily clean no. 11) I have turned it off, then on again - it just puts a bit of water into the drum and turns once or twice then freezes at that point with no further activity. I have tried holding the execute program button in case it can 'reboot' but each time it just starts the same very short process again and stops. Anyone got any ideas? Much appreciated in advance.
  • 1462 Answers
SOURCE: Wash starts it fills with water then stops and wont wash
problem may just be that drum is not turning so you think program is stopped. try cancelling and select spin program and see if you get spin
Posted on Apr 01, 2007
SOURCE: samsung smart wash b1245s doesn t work
motor brushes are worn and nead to be replaced easy job if you turn washer on to its side remove the 2 screws at the bottom and take off the plastic panel you can see the motor and the brushes are red plastic bits remove them and replace with new ones that should sort out the problem and cost about £25.00 to do .
Posted on Jun 27, 2008
SOURCE: Indesit wd125 drum wont turn
check your pump it may not be working
Posted on Dec 18, 2008
  • 4 Answers
SOURCE: how to repair a F 11 fault on a DYSON CR01 flow check
f11 fault code is a problem with the main power board (could be blown fuse) or a blown board check the fuse the board is behind the back plate in the bottem right corner (looking from the back of the machine.(!unplug before you take apart!)
Posted on Sep 17, 2009
SOURCE: I can hear the water
Not an answer to your problem but i am having the same problem with me 20 month old beko machine - a different machine to yours. I have had an engineer out twice already paid for by myself to rectify the problem and now it has happended a third time. The engineer seems to think it is poor quality wire used. Good luck let me know how you get on.
Posted on Oct 05, 2010
Does not drain
is it not blocked at the sump as some time this happens as it got a little door on the front if so it could be blocked hear
Dec 07, 2009 | Washing Machines
My Indesit WIDL126 washer/dryer doesn't dry clothes
You have an air flow problem. This usually happens when the exhaust pipe/vent gets clogged. Clean/inspect the vent outlet, the pipe, the inlet, and the filter/lint catcher area.
Improper air flow prevents the moisture from being vented out of the dryer.
Sep 26, 2009 | Washing Machines
My Indesit Washer dryer WIDL126 will not work all the LED lights are flashing continually.I have tried turning off at the plug and then on again, but no good. Any answers please?
My guess without seeing the machine is - The motor has gone / failed.
You could get someone to check the brushes on the motor, it's only a 30 minute job.
If the brushes are ok i.e more then 10mm long, I suspect the motor has burnt out if the machine is a number of years old.
Hope this helps
jb
Jun 22, 2009 | Indesit W 123 Front Load Washer
Indesit widl126s humming noise on spin cycle and doesnt drain
Your drain filter is clogged with debris. Usually small items like dirt, paper, money, and much more. Clean the filter and you should be set to go.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Mar 06, 2009 | Indesit WA 125 Front Load Washer
Ido not have a manual for this machine (WIDL126 ) and don't know
http://www.instructionsmanuals.com/u2/pdf/lavadora/Indesit-WIDL126-en.pdf
Nov 20, 2008 | Indesit Washing Machines
Indesit W103 On program 7 starts to work then controller just clicks round and round by itself.
I've found you need to reset the program cycle for this. It's annoying to lose the soap and conditioner but generally, if you download the manual and follow the reset instructions (which for me also involved turning the machine off at the mains aswell as holding the power button down with the machine on stop setting) it usually works ok.
Nov 12, 2008 | Washing Machines
I have a indesit WIDL126. Half way through through the drying cycle all the lights on the buttons start flashing and it stops spinning. I can still hear the motor working but all I end up with is a machine...
I have had the same problem and this has worked in the past:switch off the machine, then unplug it at the mains. Leave it unplugged for about a minute then plug it back in and try again.
Mar 04, 2008 | Washing Machines
Indesit w123s on daily wash program no8 it starts to fill stops and emptys then starts clicking around on the selector knob the only way to reset it is to switch off and leave for a few minutes all the...
you need to open up the small door where the filter is and clear it out. Mine does this everytime my son puts his trousers in the wash and forgets to empty the pockets! we've had all sorts, elastic bands, wrappers, and money. Usually the machine still has water in it as the filter is blocked it won't continue the programme until this is clear and thats why the continuous clicking happens.
B. Green.
Nov 03, 2007 | Indesit WA 115 Front Load Washer
Indesit widl126s
Suggestion: Possible your outlet filter is blocked; this needs periodic cleaning, depending on your usage. Clean this out and re-fit. Refer to your users' manual re. where the filter is....
Jun 15, 2007 | Indesit WA 125 Front Load Washer
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
