Question about Honda Generator Eb4000x Eb5000x Eb6500x Spark Plug - Ngk Bpr5es
EB5000X SUT OFF WHEN HOT WILLNOT START NO SPARK UNTILL COOLS DOWN
NO SPARK WHAN TRY TO RESTART HOT WHEN COOLS DOWN SPARK AND RUNS OK
    Problem Solver:
  • 11 Answers
CHECK YOUR OIL LEVEL
Posted on Jul 12, 2014
Why does my 2003 pontiac sunfire lose all power while driving
That can be the symptom of a bad Ignition Control Module, or also a bad crank position sensor. The ICM can be taken off and tested for free at any parts store. The crank sensor circuit can be tested on the car with a multi-meter. Also small motors (like a fuel pump motor) that are starting to fail can sometimes work until they get hot and then stop working until they cool down again.
Next time the car shuts down and won't restart, check for spark on a spark plug wire with the engine cranking over. If you have no spark, suspect the ignition control module or the crank position sensor. If you still have spark, but won't start, check if the fuel pump is putting gas up to the engine.
Sep 12, 2014 | 2003 Pontiac Sunfire
Why does tractor runs fine til it warms up then stalls and wont restart til cools down
Check to see if you still get spark at the spark plug wire when this happens, common problem is a "Hot Coil" the coil windings breakdown under high heat and causes a stall until it cools down, just pull a plug wire place it near engine ground with a small gap see if there is a bright blue spark when you crank the engine over. If no spark, or it is weak orange spark..let it cool down then try it again if it then sparks bright blue you have a coil issue and it needs replaced. I have also had key switches over heat and stall the engine as well check your wiring connections on the key switch if its burnt looking there is also a problem.
Jul 29, 2014 | Craftsman Garden
Starts but cuts off when engine gets hot
when it first dies check for spark or even better get a inline spark tester
Apr 06, 2012 | Garden
I have a yamaha EF2400IS generator that starts fine, but when i shut it down and try to restart it hot it will not start up again until it cools down. Please help.
If it doesn't start but turns over ok. It may be a problem with the magneto / wiring or spark plugs. It seems as though this unit has no automatic shut down. I would try replacing the spark plugs BPR4ES NGK or equivalent and gap to .030, oil 5/30 or 10/30 will do takes less than 1 quart, & air filter (basic tune-up) if not performed in some time. Yamaha recommends every 20 hours. Then try again. Here is a link to the owner's manual. http://www.poweredgenerators.com/yamaha/manuals/ef2400is.pdf
Jul 23, 2011 | Yamaha EF2400iS Portable Generator
I have a 19992 Subaru Brumby which loses ignition spark
its quite possibly the crank angle sensor as they do this when they heat up,the car wont start,till it cools down,you can get the resistance checked on it to see if its ok,but you will need someone with experience to do it but its not a hard job
Nov 11, 2009 | 1993 Subaru Legacy
Crafstman riding mower cutting off now won't start at all
The two most likely suspects for the symptom you describe are:
a) Ignition coil failure under high heat.
OR
b) Decompression failure due to normal wear.
For a positive diagnosis try the following:
For scenario a)
Run the engine until it shuts itself down. As quickly as possible, check for spark using a spark tester (availabe at local auto parts store). If no spark when hot, allow to cool down and test again. If good spark when cold and no spark when hot, change the ignition coil.
Proper part number (assuming your machine is still all original) Briggs & Stratton part #492341.
For scenario b)
Run the engine until it shuts itself down. Try to restart but pay close attention to the speed of the spinning starter. Next, remove the spark plug and spin the engine over (WITH SPARK PLUG WIRE WELL OUT OF THE WAY!!) If the engine spins super fast and free you can discount the theory of a bad battery and you will need to adjust the valve lash.
Determine which is the case and reply to this post. I will gladly give a detailed explanation of the valve lash adjustment procedure in another post.
Hope this helps!
Oct 01, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
96 ford explorer v8 wont start all the time
try replacing the fuel pump reley
they are a little bit funny in fords
i had a ford 1 time thet ran fine for hours in the driveway but go 2 blocks and the truck would die dam reley took me 2 monthes to diagnose once i did i had a great vechiale untill a dui hit me broad side
Jul 25, 2009 | 1996 Ford Explorer
1995 silverado 5.7 driving down road suts down. will not restart later will. have replaced fuel pump twice
I would advise diagnosing this problem when its in this no-start condition. I would not overlook ignition problems and the loss of spark as modules can break down and stop working once heated up,then work again once cooled off. Key on engine off will run the fuel pump for 3 seconds and you can hear the fuel pump running.I generally get concerned if it sounds abnormal like louder and whining which means the pump is failing.Bottom line this engine needs air/fuel/spark to run so check for these items while in the no start condition...good luck
Jul 14, 2009 | 1995 Chevrolet Silverado 2500
My mower starts and runs great when cold but dies when hot. It will restart but won't stay running until it cools off again.
How old is your mower ? Sounds like points and condensor if older model ,or ignition module if its newer , points tend to stick together when they get old causing no spark at plug when they cool they come appart allowing it to spark again , module is sort of the same except you have no way of replacing points you have to replace module .
May 11, 2009 | Garden
19.5 HP brggs engine (craftsman) shuts down after long runs.
Sounds like the coil,pull the shutoff wire off the coil and try it.if you still dont have spark replace coil.
Mar 17, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Honda Generator Eb4000x Eb5000x Eb6500x Spark Plug - Ngk Bpr5es Logo
70 people viewed this question
Top Honda Air Tools & Compressors Experts
John Trevino
Renee Knafel-Bullock
Are you a Honda Air Tool and Compressor Expert? Answer questions, earn points and help others
