Hi, my 42inches polaroid definia lcd tv switches off itself and after a while i have to switch it back on from main board. any idea how can i fix it....
SOURCE: LG TV
There is probably a bad capacitor on the power board, I had the same thing happen to my 42LB1DR after 2 years. T.V. would turn on and white power light would blink, no pictue and no sound. If your'e a diy'er, it is not that hard of a fix. Take all the covers off of the back of the tv(UNPLUGGED!!!), then look at all the capacitors on the power board. lcd_repair_4_bad_capacitors_lg.jpg
These are the capacitors, look to see if any of them appear to have a bump on the top of them. They are supposed to be flat, you can also tell if one of them has gone bad if there is an oily substance on the metal cover that was removed. If one of them is in question, carefully remove the board, and take it to an electronics store to have them sotter ?sp on a new capacitor. It ended up costing me around $40.00 to have this done. Good luck and if you are not comfortable trying this, than take it to a repair shop, but I was quoted around $450 to take the T.V. in. No Thanks
Posted on Nov 21, 2008
SOURCE: LCD LG42LC55 TV switching OFF
THIS IS CAUSED BY THE MAINBOARD AND NEEDED TO BE REPLACED.
Posted on Nov 30, 2008
  • 636 Answers
SOURCE: Philips LCD TV Matchline series keeps switching off!
heating up issue, try unplugging it and if you can clean the dust from within the unit. Try reversing the vacuum and blowing excess dust out.
Posted on Sep 09, 2009
Testimonial: "I will try your solution...sounds logical and may well do the trick. Thank you for taking the time to sending me your advice...much appreciated. CJ"
SOURCE: If anyone is in need of Polaroid lcd tv parts contact me
usually capacitors are the problem on the TDA03211c power supply. 450v (volts) @ 10uf. change both. beside inverter filters.
Posted on Mar 31, 2010
SOURCE: Sharp Aquos 46in LCD AV Mode switching to Dynamic(fixed) by itsel
Sorry I´cant help you, but I´ve got exact the same problem.
I´m from germany. I searched the german web, but nothing.
Did you have an answer right now?
Posted on May 20, 2010
POLAROID P40LCD12 SCREEN AT BOTTOM COMES ON BLUE FADES THEN GOES GREEN ABOUT 5 INCHES LOST ON BOTTOM TV WORKS OK BUT THE SCREENS STARTS BLUE ABOUT 5 INCHES FROM BOTTOM THAT FADES AND TOP HALF PIC OK BUT...
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
May 02, 2017 | Polaroid Televison & Video
Wharfedale TV power problems
the problem occurs in ur main board...check all tge resistor in board...the faulty resistor will; allow high voltage to the main board and affect it
Oct 31, 2008 | Televison & Video
I have a 40 HD widescreen LCD Polariod TV. I was watching tv when the picture froze and then went black. I still have sound and can switch channels, but no picture Other household TV's are fine
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jan 01, 2017 | Polaroid Televison & Video
Samsung pn51 continuously cycles on and off (clicking).
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
Easy fix for new Samsung TV switching on and off power cycling.... My tv turns on and off by itself the ...
Samsung 46" LCD TV (LNT4665F) turns off and on over again -
Dec 09, 2015 | Samsung Televison & Video
Samsung LCD TV backlight switched off
Apr 24, 2017 | Samsung LE-46A566 46 in. LCD TV
TV Polaroid Definia 32 pollici
you need re-channel..you need to call a Tv tech to re-channel your TV
Jul 18, 2012 | Polaroid Televison & Video
Why does my tv go black afer 5 m but i still hear sound
Possible errors in the main board , it can be due to failure of a solder joint in the set.
Remove the back panel and switch on the TV to work. when the fault appears then the main boarrd can be tapped lightly to see if there is any switch on of the picture. If so the fault is confirmed and you can continue further. Remove the power connection and solder.
Use these tips below for help:
Check for board faults
Tips on Soldering
Nov 06, 2010 | Polaroid FLM-4034B 40 in. LCD HDTV
''crease lines'' on Polaroid 32'' Definia LCD
I am currently looking into the same problem with my Sony Bravia S-Series (52").
Nov 12, 2009 | Televison & Video
I Think NO expert can help this problem because it free answer
I think I may finally have the answer for the "black screen of death" for the 42" Polaroid LCD televisions. I was having the same issue with the screen going black after a couple minutes of being on. I would shut it down then turn it back on and it would work again for 5-10 minutes. On the "power board" which is the board on top, there is a little red light that turns on when the screen would go black. above that there are 4 little switches, the lower on says BURN. I simply switched that over and the television has been working for 2 days for 8 hours + each day. Hope this help. Let me know
Mar 20, 2009 | Polaroid FLM-3225 32 in. LCD Television
No manual
Here is the link to the manual. You have to register on this site but it is only 3 lines and takes 2 seconds and is totally free.
Enjoy the manual,
Lee
Jun 13, 2008 | Polaroid FLM-4201 42 in. LCD Television
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
Electro Med Services...
