Question about NEC Dth-16d-1 Dterm 80 Elite Ipk Phone W/lcd & Warranty
NEC Dterm Series I phone not displaying name or phone # properly
For the display there are 3 lines of text: 1st line: Time and Date displayed 2nd line: Station name and ext not displaying correctly ex should read: 100 Boardroom But shows up as: m100 Boardroo Also when you call out using the phone it shows up like this: 3 111-222-333 instead of: 111-222-3333 It's like there is an extra space before the station name and the phone number when dialing. Help!
4 Suggested Answers
SOURCE: NEC dterm series II phones-name desplay
This works on the series E phones. It may or may not work on the series II.
  1. Press the Speaker key (do not use the handset).
  2. Dial the Name Assignment access code and wait for the special dial tone.
  3. Using the key pad spell the name. Press each number until the letter appears.
  4. When the correct letter is displayed Press the HOLD key. Pressing the HOLD key will lock the letter in place and advance to the next position.
  5. Repeat steps 3 and 4 continue to spell the name.
Pressing the TRANSFER key will change the current letter to lower case.
Example to enter the name “Pat” press:
77 HOLD 22 TRANSFER HOLD 88 TRANSFER HOLD
Posted on Sep 23, 2008
danielwil316
  • 21 Answers
SOURCE: How to Change Time on NEC Dterm Series E phone
Press the "Speaker" button and enter 728 on the key pad. Then enter the correct time.
Posted on Mar 14, 2012
  • 277 Answers
SOURCE: how to change name on nec dterm 80
You need to do this from the Admin phones, by default the lowest ext #'s on the system.
This is system programming not the phone itself.
Refer to the Attendant guide for the phone system model your phones run on.
Posted on Nov 06, 2012
How do i change the extension name on the display of NEC Dterm Series i?
Which NEC system is the Dterm Series i connected to? Normally you change the ext name in system programming, but I need to know which system it is.
Oct 14, 2016 | NEC Lands Phones
How to fix display on Dterm80
Ribbon cable inside phone to display sometimes gets jarred loose. If you can remove the base, then unscrew the 2 screws holding the display in place, then slide it out and look for the ribbon cable being loose. If you have small hands maybe you can get that back to its spot. Better yet buy a replacement phone on eBay for 25 bucks instead of hoping it'll go back in and work properly. Some displays go bad line by line, in which case there's no help for it.
Jun 03, 2014 | NEC Dterm DTP 16D-1 Corded Phone
How do I chance the names on an NEC phone
NAME DISPLAY
NOTE: Display Dterm
A name with up to 16 characters can be entered to display the name on
other Dterm telephones when making a call.
• Press Speaker key, Receive dial tone.
• Dial the Name Assignment access code and receive special dial tone.
• Using the keypad, depress the key with the desired letter to display the
first letter on the key. The
display will indicate the
numerical designation.
Subsequent depressions will
advance through the letters
on that key. The Dial Pad Key
TABLE can be used as a
guide to indicate the key and
the number of depressions required to display numbers, letters, spaces
and periods.
• When the desired letter is displayed, depression of the Transfer key will
change the letter to a lower case letter (default is upper case). Depress
the Hold key to enter that letter and advance to the next entry.
• Repeat the previous two steps until the desired name is displayed and
entered
Apr 05, 2010 | NEC Dterm DTP 16D-1 Corded Phone
Name Display NEC DTerm Series i
It is changed via MAT or MOC programming. See you PABX Technician.
Mar 27, 2009 | Lands Phones
Trying to change the name on the display on the phone
Dial 700>dial your ext #>enter name>press Hold & press Speaker
Feb 13, 2009 | NEC Dterm DTP 16D-1 Corded Phone
Lost the time and date line in the display
Unplug the phone, wait one minute, then plug it back in and see if the display comes back on. Press the program button, press 22 on the dial pad, press program button again ( if the phone is ringing on the incoming call and not just flashing).
May 31, 2008 | Panasonic KX-T7630 Corded Phone
Apr 16, 2008 | NEC Dterm DTP-2DT-1 Phone
Nec dterm80
Another solution is to pick up on intercom and dial 4 then 2 and hang up. That is the default DND cancel code. It can be used form single line phones within the system as well.
Oct 03, 2007 | NEC Dterm DTP 16D-1 Corded Phone
NEC Dth-16d-1 Dterm 80 Elite Ipk Phone W/lcd & Warranty Logo
60 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
george  peters
george peters
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
