Question about Dual XDM6825 CD/MP3/WMA Player
No sound comes out of speakers
After pulling out my old car stereo, I hooked up the wires from this one via the colors used by the old stereo. Now, no sound comes out of the speakers, but sound does come out of the subwoofer, but out of nothing else. The stereo works fine so far as I can tell (powers up, switches stations, etc.), just without sound. If anyone has the wiring diagram (which colors of wire do what) that would also be great.
  • 41 Answers
Yellow - +12V Constant Power Red - +12V Switched (accessory) Power Blue - Power Antenna Blue/White - Amp Turn-on White - Left Front Positive Speaker Wire (LF+) White/Black - (LF-) Gray - Right Front Positive Speaker Wire (RF+) Gray/Black - (RF-) Green - Right Rear Positive Speaker Wire (RR+) Green/Black - (RR-) Purple - Left Rear Positive Speaker Wire (LR+) Purple/Black - (LR-)
Posted on Sep 21, 2007
Where is the factory amp located?
Posted on Nov 22, 2008
On your no sound coming out of the speakers, I had the same problem on my car, I had to bypass the factory amp because it was blown
Posted on Oct 20, 2007
  • Anthony Wilkes
    Anthony Wilkes Sep 11, 2013
    Ok, how did you bypass the amp? Is there a plug to replace the amp or did you cut and tie the wires into each other?\
I have a 92 marquis, and ive just changed out the factory stereo with a aftermarket. How can i hookup the amp that came with the bose system??
If you bought a wiring adapter kit for the aftermarket stereo, the unit should hook up directly to the stock bose system. Note: If there is sound coming from the speakers after installation, the amp IS hooked up...the speaker wiring is routed to the factory amplifier, not the stereo itself, the stereo wiring is just signal leads to the amplifier. In some instances, you may have to connect the amp remote wire to the remote wire coming from the aftermarket stereo(blue wire). I hope this helps. Any other questions, just reply.
Feb 06, 2011 | 1992 Mercury Grand Marquis
Stereo Wiring Colours
2006 Ford Focus Car Stereo Wire Color Codes
Car Radio Battery Constant 12v+ Wire: Yellow/Green
Car Radio Accessory Switched 12v+ Wire: Orange/Black
Car Radio Ground Wire: Black/Green
Car Radio Illumination Wire: Orange/Black
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): White/Black
Left Front Speaker Negative Wire (-): Gray/Black
Right Front Speaker Positive Wire (+): White/Red
Right Front Speaker Negative Wire (-): Gray/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): White/Green
Left Rear Speaker Negative Wire (-): Gray/White
Right Rear Speaker Positive Wire (+): White
Right Rear Speaker Negative Wire (-): Gray
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jul 11, 2010 | 2006 Ford Focus
Speakers don't work
If you had followed the directions correctly and the old speakers worked as well, take the new radio back for exchange
Jan 18, 2010 | 1990 Nissan Maxima
I need to find the colors for the rear speakers to hook up a amp
2003 Mercury Sable Car Radio Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Blue/Red
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Jun 02, 2009 | 2003 Mercury Sable
Wiring problem
If you have an aftermarket stereo, the hook up is fairly simple. On your amp there should be a minimum of 5 terminals and an audio input. one is for remote which is connected to the blue wire on your stereo. Second is your ground which is your negative connection. it should be connected to the body of the car close to the frame. Third is your hotwire which is the positive lead, it should go straight to your battery. The fourth and fifth are speaker wires, you may have 2 or more of these that have + and - signs above or below them. When wiring the speakers make sure to match the positive and negative connections on the speakers. If your rewiring all of the door speakers to your new amp then the colors that you see once you have them out are the colors you route to the appropriate locations on your amp. If this is for a sub then you just the connect th positive terminal on the sub which is red to the + on the amp and the black terminal on the sub the the - location on the amp.
Lastley there should be an audio input that runs from your stereo to your amplifier. This wire should be ran as far away from the positive wire as possible to avoid engine noise coming through your speakers.
Jun 01, 2009 | Earthquake Sound XTREME 900W.5 Car Audio...
Can get the stereo to work but no sound comes out when its hookd
All you have to do is make sure the wires are hooked up to the right color and if they are then your speakers might be blown!!
Mar 14, 2009 | Virtual Reality Sound VR3 CD Player w/ USB...
97 dakota installed radio harness have power no sound
If you still haven't fixed this, look at your wiring harness. The blue wire that comes off your factory harness is the external amp in the Infinity stereo. I found this out when I hooked my Pioneer head unit up. Coming off the aftermarket stereo should be a blue wire that says remote. Hook those up and you should be good to go.
Jan 18, 2009 | 1997 Dodge Dakota
08 ford fusion need to know the colors of both rear doors speakers
well first to decode the wire corlusthe darkest one is all wayz negtive. and a 18, or a 16 gauge wire should would work fine run it to ur amp from the fuse box let me no if that works
Apr 06, 2008 | Pyle PDS442 Coaxial Car Speaker
Car Audio & Video Logo
519 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
