Question about Hotpoint Dishwashers
My hotpoint hydrocare slimline 7801 is not washing the crocks water goes in but the tablet is still intacked
It doesant wash the crockery water goes in , when cycle is finished the dishwashing tablet has not desolved, we have put salt in,
SOURCE: dishwasher does not stop
MY DAM DISHWASHER KEEPS ON RUNNING AND WANT NEVER STOP WHAT IN THE SAM HELL SHOULD I DO? H E L P M E!!!! I AM SO SICK OF MY DISHES PILING UP IN MY SINK..
Posted on Sep 17, 2008
SOURCE: Hotpoint BF1620
What you will find is that the plastic nut fixed on the back panel that the top drawer pushes into has lost the rubber inner layer. Replace and your problem is solved
Kamal
Posted on Mar 12, 2009
  • 3 Answers
SOURCE: Dishwasher tablets not dissolving
It may just be the way you are loading the machine.  If the dishes are not allowing the the detergent door to open fully, the tablet sits in the dispenser until you open the dishwasher, letting the dispenser door open and the half dissolved tablet falls out!     Try being more careful how you load the machine or just chuck the tablet in the bottom of the machine instead of the dispenser!
Posted on Aug 26, 2009
SOURCE: hotpoint aquarius fdw20 fault lights
yeah i had same problem turns out its a blocked outlet hose
Posted on Nov 22, 2009
SOURCE: I have a nardi dishwasher
nardi dishwaser water will not drain away after wash cycle.
Posted on Sep 08, 2010
What is code H20 on hotpoint washing machine
Check to make sure that the water valves are open and water is getting to the machine.
May 29, 2012 | Hotpoint Washing Machines
Can i put the crock pot bowl in the oven and cook in it
A Crock Pot is made of crockery and is OK to bake in the oven. Don't let it get into contact with cold items, water etc, when it is straight out of the oven or it will crack, like any other crockery utensil. Treat it like glass.
Dec 30, 2010 | Microwave Ovens
I have a Hotpoint Slimline 7801 and am looking for an explanation of the programmes it offers. The programmes 1, 2, and 3 are explained, but not all the symbols on the left-hand control. A manual would be...
The manual is available at this site - but cannot see any more programs but 1,2 ,3.
Hope this helps. Please rate the solution to help fixya serve you better.
Oct 14, 2010 | Dishwashers
Is there a micro switch on a dishwasher to let the water in hotpoint hydrocare super plus model no 7822 my machine dosent seem to fill
Most Dishwasher have a flote switch for the water level. You need to check it as well as the water inlet water valve.
Jul 04, 2010 | Dishwashers
Won't agitate
Hiya,
these noices are often caused by a water issue the rince cycle is a cold water intack so i would surgest turning of the cold water at the mains or shut off valve then disconnect your cold intack hose & check for any clogging it could be a build up of lime scale or lint & the simple removal & cleaning of this hose could fix your problem.. alternativly ensure the cold water supply is turned to the on position to allow the water trough to rince
Hope this helps
Apr 22, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
My Ignis dishwasher ADL 348 is not dissolving the dishwasher tablet properly leaving the crockery still dirty. It is also making a really strange noise during operation. I have cleaned the filters and the...
My adl 348 is 3years old. Made strange noise and didnt really wash now it doesnt appear to be washing. What would it be and is it easy fixed?
Feb 13, 2010 | Dishwashers
Dish washer not filling with water when put on
There are a few things that can cause this problem, it could be a defective water inlet valve, it's usually located behind the lower kick plate on the left or right hand side of the dishwasher, When the washing cycle is started it sends voltage to the water inlet valve to open which allows water to enter the machine, or it could be a faulty float switch, when water enters the machine the float switch raises up which signals the water inlet valve to shut off, the float switch is located inside the dishwasher at the bottom, you can check the float switch by raising it up and down to see if it's stuck in the up position. Good luck.
Mar 21, 2009 | Dishwashers
Hotpoint aquarius dwf30 dishwasher
you can plumb into hot but there are some snags
first hot water pressure is often a lot lower than cold so the machine may take a long time to fill
second if the water is too hot it will destroy the resin of the water softener and you will see brown marks on the crockery.
third it a bit uneconomical as you will use a lot of hot water
May 18, 2008 | Hotpoint 24 in. DWF32P Free-standing...
Dishwashers Logo
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
