WONT DRY WATER COLLECTING IN BOTTOM OF MACHINE
  • 4 Answers
Hi there, if your dryer is a condensing dryer then perhaps you need to empty the collector bottle , its is a compartment on the side of machine , open this and remove the bottle , this must be done after at least two sessions of drying. On the other hand if your dryer is of the vented type with a 4 inch flex vent it must be vented through the wall to the outside with no kinks in it , the reason for this is the water turns to vapour , and must exit the machine or you will have clothes that are still wet and water will collect at the bottom, its the same principal for the condenser machine only you have to empty the bottle of condensed water or the same result will occur.
Hope this is of some help to , Cassyjoe.
Posted on Nov 07, 2012
After one min. flashes 'f1 wrench' and tuns off
Water is collecting at the base of dishwasher housing (under the bottom drawer). Need to dry it up and find out why. Make sure the dishwasher is disconnected from mains supply when you work in it.
Jan 03, 2014 | Fisher and Paykel 23 in. DD-603SS Built-in...
Kenmore 54351 Dehumidifier is leaking -- water isn't going into the tray, but seems to be leaking out into the floor.
Mine is doing the same thing. The bucket is dry and the floor is flooded, so it is not an inability to condense, and it is not that the bucket has overflowed, and the bucket does not have a leak. It had been working great and then this suddenly started happening, it's as if the water is not flowing along the proper route and instead is gathering behind the bucket.
Nov 27, 2012 | Kenmore 54351 Dehumidifier
The fan is on but no water is collecting
Check to see if compressor is operating.
Apr 08, 2010 | Haier 45-Pint Dehumidifier
Water collecting at bottom of fridge. GE 17 Model 34769-3
pull bottom tray and look for hole in the back on the bottom try a clothes hanger straightened out and push thru hole
Feb 06, 2010 | Refrigerators
Dishdrawers just started flashing F1. What do I do?
Looks like the flood switch at the base of the dishwashwer has actuated. This is likely to have been caused by moisture collecting at the base under the bottom drawer.
Try to extend out the bottom drawer as much as possible to expose the back part of the base. Turn off the power. Use towels and hair dryer to dry the base and switch on. If still not ok then you may have to take out the bottom drawer and dry out the base.
the likely causes are - too much foam in detergent, a kink or crack in the water hose or a broken actuator arm that supports the water hoses when the drawers are pulled out and in.
Hope this helps.
Dec 17, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Everything seems to work but it is not collecting any water. Two years old, FDL25P11. Has worked perfectly until now, 25 qts every two days
Apparently the room humidity was too low (we were in a long cold dry spell) now that the rains have returned the machine works fine.
john
Dec 14, 2009 | Frigidaire Dehumidifiers
Machine flashes f1 and won't turn off
I believe this error code is due to flood switch at the base of the dishwasher housing getting activated. You will have to look behind the bottom drawer after pulling it out as far out as possible. if water is visible then after turning off the power, try to dry the base of the housing with towels and hair dryer. Make sure the power supply is turned off.
There are many causes of the water collecting -ranging from cracked hoses, broken actuater arm or too much foam due to incorrect dishwasher detergent (tablets can cause this). Need to fix the cause.
Nov 15, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
ASKO D3432XLB keeps running, draining but hasn't gone into the wash cycle yet. won't turn off even when I turn the power button off.
Water on lower bottom. Leakage or blocked drain pipe. Is common error. The machine will act like this so that water wont get on your kitchen floor, in case of fault on inlet valve. The machine indicates overflow. Dry out water on bottom, and than the machine will work normaly. But check for leakage. Just in case.
Jul 18, 2009 | Asko Dishwashers
Dehumidifer stopped collecting moisture, blows air w/ empty tank
Possible cause it's out of gas.
you might have to get a refridgeration mechanic to regas it, or/and fix any gas leaks
Apr 02, 2009 | Maytag M3DH30B2A Dehumidifier
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
