Question about Sharp Aquos LC-22SV6U 22 in. LCD EDTV
Sharp lc 22sv6um POWER SUPPLY 13 V. - Sharp Aquos LC-22SV6U 22 in. LCD EDTV
  • 53 Answers
SOURCE: sharp aquos LC-37D4ou
What kind of connections are you using?
If component (red, green, blue) double check to make sure they are seated properly. I'm thinking it sounds like the blue one got loose.
Posted on Mar 27, 2008
  • 1779 Answers
SOURCE: Sharp Aquis LC 30Hv4U problems turning the light
It believe your on the right track...
Posted on Feb 21, 2009
  • 1779 Answers
SOURCE: power supply bad on Sharp Aquos LC - bad board - schematic to ID?
Buy the green light going on means Standby is ok. Next, would be to locate the plug coming from the main board to the power supply and find the post that says PO which means power on. With your meter on that post, press the power button as see if the reading goes High, if it does then the main board is able to turn on the power supply. Next, find the plug on the power supply that goes to the inverter( the long board on the side) remove it and see if you have 24 volts coming out of the power supply when you press the power. If you do, then the inverter board is bad, if you don't have 24 v, then the power supply is bad. There are NO diagrams available for these set other than a flow chart if you can find one. A regular svc tech does'nt need a manual for these anyway.
Let me know how you do Kathy ?
Posted on May 17, 2009
  • 8457 Answers
SOURCE: sharp LC-26d4u tv won't turn on/power light is off
Check ur power source,unplug replug if not work,Ur tv power board ic inverter it dead needed to be change.
Posted on Aug 17, 2009
  • 308 Answers
SOURCE: If my Sharp Aquos 37in LC-40C37U tv needs to be
Blinking light is an error code. Count the blinks before they repeat. Check your manual in the troubleshooting section. If you can't find it, contact a Sharp service center or try and get a service manual. Reset info is also in the user manual but you can't do it if your set doesn't power up. Are you sure about the power board?
Posted on Apr 30, 2010
Testimonial: "Thank you. I will get another board."
WHEN I TURN TV ON IT SHUTS OFF IN LESS THAN 10 SECONDS
These sets have a tendency to have bad power supply boards. They have to be replaced as a complete assembly. you should only call out, or take this set to an authorized Sharp repair center my friend. Good Luck
May 25, 2007 | Sharp LC-13AV4U 13 in. EDTV-Ready LCD...
My Sharp 13" turns off in 5-7 secods.
Likely power supply--bad caps etc----5 years and 13? inch---cheaper to replace most likely---if you manage to get it apart look in power supply for puffed up on top caps----age of set makes this possible and not real expensive or difficult to repair.
Oct 23, 2012 | Sharp LC-15AV4U 15 in. LCD Television
Power supply
it is called powerboard, you can buy one at EBAY or another online parts store, to order one you will need your tv model and product code, located in the back of the TV next to the serial number.
Jun 06, 2009 | Sharp Aquos LC-13S1U-S 13 in. EDTV-Ready...
Sharp agous .. no power
I have same problem, In Caribean and repairs and new TVs are extra costly. Bringing power supply back with me to USA to see if I can buy a new one.
Aug 30, 2008 | Sharp Aqous LC-26D5U Television
SHARP LC-13AZIU
power supply, or luminance driver boards need replacing $300? for the latter.
Dec 05, 2006 | Panasonic CT-32D12D 32" TV
Sharp Aquos LC-22SV6U 22 in. LCD EDTV Logo
113 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
