Question about E-Machines eMachines Desktop PC
Need Help !! D865GBF / D865PERC Intel Motherboard No Pictures
I have a used D865GBF / D865PERC Intel motherboard installed on my computer. I don't have AGP video card installed. After installation, cpu is running. But no picture on monitor. I heared 6 beeps during BIOS booting. I found from mb menual that 6 beeps indicate memory failured. I use a pair of 256 mb DDR 184, 533 and I strictly followed mb menual to installed memories on mb.
I don't know why no video on mb.
My questions:
1. Do I have to use a AGP video card instead mb video card?
2. Do I have to switch another pair of memory?
3. Any suggestions to fix the problem?
Thanks very much.
  • Anonymous Mar 22, 2009
    hi. i have the same board D865GBF my question is if i can upgrade to a better video card say ddr2 or ddr3? there are 6 pci slots & am asking if it is compatible with the current pci video cards that are out now. thanks!
  • 32 Answers
While the system may be emitting a memory error beep code, that obviously is not the only issue here. If there is onboard video and it isn't working, try this:
1: Unplug system
2: Open case
3: Look for the CR2032 flat watch-style battery located on the motherboard, usually around where the front panel connections are
4: Remove this battery using a flathead screwdriver to push on the tiny 'hook' of metal holding it in. DO NOT PRY THE BATTERY OUT.
5: Let system sit for 10 seconds and put the battery back in.
6: Power the system back up
What this does is drain the system's memory completely. If it was perhaps set to use the AGP video card (which isn't installed, hence no video), this setting should be cleared and you should get onboard video.
Failing this, really, your only choice is a new motherboard, or to install an AGP card and see if it works. If you don't feel like hunting down a replacement board, I'd just order a cheap AGP card. If the AGP card works, use it. If not, then your motherboard is really pooched and you'll need a new one anyways.
About the memory beep issue:
You can google memtest86 and download that program. Burn it to a bootable CD and run the memory test; it should tell you if the memory is good or not.
hope that helps!
Posted on Jan 05, 2009
  • 82 Answers
Try installing only one memory module and check the display.
Make sure you have connected the P4 connector of SMPS to the Motherboard.
When you Switch ON the PC just check if CPU is getting too much heated.
I hope this steps will help you resolve you problem
all the best
(Do rate on fixya, thanks in advance)
Intel D865GBF/D865PERC does this mother board support 450W SMPS or higher. If heigher how much Watt does the mother board support
You can install a 450w or higher wattage switch mode power supply.
The total wattage of the power supply you require depends upon the power consumption of all the devices that are installed on your computer and any additional devices you may wish to install in the future.
I suggest you need not exceed the total power requirements by more than 10%.
It is like putting a jet engine in your car when it does not need this much power and it would cost more money.
May 08, 2011 | Intel D865GBF Motherboard
How to dowanload sound max driver of intel desktop board d865gbf / d865perc
You can download the motherboarddrivers from Intel WEB site. Select your model motherboard/device, and makesure you select the Windows XP or Vista version of the drivers that matchesyour Windows
operating system. Please click on this link andselect your model motherboard : -
Feb 24, 2011 | Intel Desktop Board D865GBF (MBIND865GBF)...
I am facing problem regarding BIOS, Therefore i want to update BIOS, My bord is Intel Desktop Board D865GBF/D865PERC. Please advice me to get free download
Go to the Intel site and enter the required details
Jun 16, 2010 | Intel D865GBF Motherboard
Sir, i have lost my motherboard cd sir ,my
Go to intel side or chipset web add . see your motherboard . nere the processor they will mension the motherboard no ( i.e d845 / d915 )
Jun 11, 2009 | Intel Desktop Board D865GBF (MBIND865GBF)...
I need audio driver for Desktop
Here you go. follow this link, choose your OS from the drop down list, then choose your drivers.
You'll have to agree to the terms and conditions before the download.
good luck
May 19, 2009 | Intel Desktop Board D865GBF (MBIND865GBF)...
Where can i download free intel d865gbf motherboard drivers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You may have to install or update drivers Most of the drivers/software I get are from a web site you need to fill out a free registration then search for the driver you need download it in a format you can use install it and then most times reboot the computer
Please leave Comment or Rate answer for me to improve in the future
Jan 26, 2009 | Intel D865GBF Motherboard
**System randomly hangs**
Electrolytic Capacitor Failure on some Intel mobo. Products Affected:
Intelreg.gif Desktop Boards D865GBF, D875BZL, D865GLC, D845EPI, D865PERC, D865GRH, D865PERL, D845GVSR, D865PESO, D845GLVA, D865GWV, and Intelreg.gif Entry Server Board S875WP1-E.
Should replace the capacitors shown in the photo attached. 73d0b16c-0d36-4176-be42-6dd73b32fb65.jpg
Oct 24, 2008 | Intel D865GBF Motherboard
Identify motherboard
U Can download the drivers from
Pl try it
Was this soultion useful ?show ur appericiation by rating it
Apr 10, 2008 | Intel Motherboard
E-Machines eMachines Desktop PC Logo
676 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
