Question about Electrical Supplies
Why does my 15 kw carrier propane generator backfire and sputter oil into th air filter
CarlGehrke
  • 169 Answers
SOURCE: Generator pulsates when its running 12-KW natural gas
You've described the symptoms of a dirty air cleaner, surging throttle (the pulsating), oil getting sucked up thru the breather into the intake (the why you have to add oil).
When you check/change the air cleaner you should also have a look at the spark plug, the dirty air cleaner forced the engine to burn some oil and that may have left junk on the plug.
To make it easier to read the oil level on a dipstick, try dipping the stick into a little water. When you draw it back out of the water the contrast between the oil covered part of the dipstick and the water covered part will be a little more obvious. Sometimes looking at the backside of the dipstick is better too.
Carl
Posted on Dec 03, 2008
CarlGehrke
  • 169 Answers
SOURCE: have a 16k propane guardian generator have to manually start and
Is this an RV generator?
If you have to really choke an LP engine but it runs more or less normally once started you need to troubleshoot the demand regulator and the fuel supply lines (look for air leaks). I'd also check the fuel inlet pressure before the demand regulator.
Rate me,
Carl
Posted on Dec 05, 2008
  • 5 Answers
SOURCE: generator 30
fuse are meant to protect the costlier part of the machine thereby damaging itself.  there is probably overloading of your circuit. call the electrician and find the actual power required by your house.  there is a possibility of having a short circuit in your generator. your local electrician can check it.
Posted on Jan 24, 2009
  • 26 Answers
SOURCE: Attempted to start Generac Guardian 15 kw air
I work on these every day. Its either gonna be the rotor or stater, the voltage regulator, but most likely its a bad stepper motor which is the throttle motor, or control board. Thats all that could be causing that so its one of those. If its the rotor or stater thats bad it causes the generator to RPM up because it thinks its not producing enough power due to that. I had the same problem with the same one we just fixed and it was the slip rings on the end of the rotor so bad rotor.
Posted on Jul 09, 2009
  • 583 Answers
SOURCE: How do you check the oil level in the 7.5 kw
GENERATORS DO NOT HAVE OIL IN THEM THE MOTOR ATTATCHED TO IT DOES WHAT TYPE OF ENGINE,? IF ITS A HONDA THE OIL LEVEL IS THE BOTTOM LIP ON THE BUNG AT THE BASE OF THE ENGINE
Posted on Sep 21, 2009
Why does it crank and almost start on 1st try?
Generac Generator Troubleshooting - YouTube
? 1:39
https://www.youtube.com/watch?v=AKN2dc59cxY
Dec 20, 2013 - Uploaded by Appliance Princess
I want to learn about Generac generator troubleshooting. ... I have a 16 kW propane fueled standby air-cooled generator. ... I have a brand new generac 20K guardian Evolution and the first time my power went out my generac ...
Generac Power Systems - ConsumerAffairs.com
www.consumeraffairs.com > Homeowners > Utilities
Rating: 1.3 - ‎26 votes
Hey, Generac, make a change and start making generators that work, don't cost .....Standby generators are not supposed to be used as a primary power source ... and three months ago, I spent $4,000 to have a Guardian generator installed at ...
Generac standby generator - Propane - wont start?? - DoItYourself ...
www.doityourself.com/.../487838-generac-standby-generator-propane-w...
Feb 4, 2013 - I have a Generac 4LM41A standby generator that I need help introubleshooting and repairing. It is about 12 years old and hasn't been used ...
141 GENERAC complaints and reviews @ P'ed Consumer
Dec 12, 2015 | Generac GUARDIAN Standby Generator 10 kW/9...
Replace a kfceh3101c15 with a 20 kw. 15 kw just is not keeping up in this weather
The best answer would come from Carrier. Here is their contact info-
Feb 23, 2015 | Carrier Heating & Cooling
Bought new. No problems until two weeks ago. Now has 252 HRS. Starts all the time, runs 10 seconds then shuts down. I have removed wire an oil pressure switch. no help. Found connector off on switch p
It shuts down because it's not making power. You are probably getting a failure to start error code. If it doesn't make power it doesn
t know its running. Rotor has lost residual magnetism to start the voltage regulator. Replace the voltage regulator. The new one is designed to overcome this.
Dec 10, 2014 | Briggs & Stratton Briggs Stratton 7 kW...
I have a Kohler 12 RES home standby generator. Once in a while when the power goes out the generator will start and then immediately shut down with no fault codes. When I flip the control in the unit
Check the inlet fuel pressure, on exervise there is no load, when power is out it is loaded and demands more fuel. Also check for bugs blocking gas regulators vents etc
Nov 12, 2012 | Kohler Generator. 12 kW and 14 kW Home...
Can some one tell me what oil and air filter to buy for a Kohler 12res LPG generator?
Lowes sells air filters for Kohler engines . As far as the oil a SEA 30 or 10w 30 would be fine.
Dec 01, 2010 | Kohler 12 kW Emergency Power System -...
Briggs and Stratton propane gernerator will not run.
The engine is starved for fuel. Check fuel flow. Possibly a dirty fuel filter someplace in the line or the regulator has low flow.
You can verify this by putting an UNLIGHTED Bernz propane torch into the intake. If that improves it, then low fuel flow is the culprit.
Fuel filters for propane are very fine and can plug up easily. I am not sure where yours are, however I would check at the inout of the regulator for one there for sure.
Mar 31, 2010 | Briggs & Stratton Automatic Home Standby...
Kw for Carrier 42G150H
this is the m# of the air handler take frunt panel off an were the wires go into the unit there sould be another sticker with the kw usally there are 10to 15 kw is an averge house
Mar 15, 2010 | Carrier 38CKC042 Air Conditioner
I have a new Kohler 12kw res generator on propane - backfiring
Is the outside air temp cold. These generators will backfire if it is real cold and if the propane pressure is low. It is suppose to be 11 to 12 inches of water colume at the generator fuel input. drygwals
Feb 18, 2010 | Kohler 12 kW Emergency Power System -...
Electrical Supplies Logo
80 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
