Question about Garden
Stihl 036 leaks bar oil - Garden
4 Suggested Answers
SOURCE: stihl 180 chainsaw,lack of oil to chain and bar
hi there i had this problem check bar studs make sure there tight bar must be flush on chainsaw body not on stud flange if bar is on stud flange there is a gap so oil leaks out near sprocket and not in bar oil channel
Posted on Apr 24, 2009
  • 14 Answers
SOURCE: Stihl MS 250 16"
take the bar off and give it a good clean, get compressed air and blow it into the oil tank, making a seal around it first
Posted on May 10, 2010
snowghost1
  • 784 Answers
SOURCE: I have a Stihl .029
I have owned and use Stihl saws for the past 18 years and I have seen both these problems many times. as for the chain 'getting tight' -- when you go to adjust the chain, make sure you are lifting up on the tip of the bar as you set the tightness -- you should be able to only pull the chain away from the bar about 1/8th of a inch. now, while tightening the bar bolts make sure you still are pulling up on the tip of the bar,, and make sure the bar bolts are nice and tight -- not to tight though, the bolts that Stihl uses are a very weak point on their saws and I have broke more than just one. but make sure after one is tight that you tighten the other one and then give the first nut one more 'little' nudge tighter. new chains do have a break in period and they have been known to tighten up and loosen as they are running,, just keep your eye on it for awhile and thighten or loosen as needed.
now I am kinda confused on your next problem -- you say ' winter mix bar oil ' -- using this oil should not have anything to do with it stalling out, ( enless you are mixing bar oil with your gas ?? ),, make sure you are using Stihl 2-stroke oil to mix with your gas at a ratio of 50:1,, ( you can buy small bottles that mix with 1 gallon or a bottle that will mix with 5 gallons -- use 'em ). one thing that I have had troubles with when my saw wants to stall out is the fuel filter inside the fuel tank in the wrong position and is sucking air. also I have had fuel lines that crack and/or split and they **** air.
now the winter bar oil -- please,, I have been running Stihl saws in temperatures ranging from minus -5 to 100 degrees above and I have always used the SAME bar oil year round and had NO problems. on the side of the saw there is a bar oil delivery speed screw and you can adjust it to flow more or less -- your manual should show you the exact location of this screw,, make sure you clean out any debris that might be blocking the weep hole for the oil delivery. you need to make this adjustment with the bar and chain off the saw and you will see the flow of the oil and you can adjust to a good flow.
I am a firm believer in buying and using Sthil chainsaws,, I will never buy anything else,, they are great and out last any other saw I have used or seen,, and your Farm Boss is a great saw and should give you many years of trouble free use.
one suggestion that I would make real quick is to ' change your saw mechanic ' -- find one that has been ' WORKING ' on chainsaws ( not just selling them ) for along time,, someone that has your interest at heart and is there to help you,, not just to take your money.
(((( I am still laughing at the ' Stihl Winter Mix bar oil :-) )))).
good luck with your saw,, and if you have anymore questions about this please feel free to write me back here and I will do my best to walk you through what it is that you need to know and do. again - I have been using and working on chainsaws for most of my life.
have a great night,
c...
Posted on Feb 10, 2011
Need to know what kind of oil is used in 2.0 cid gas chainsaw?
Chain oil for the chain
STIHL Bar and Chain Oil - Chainsaw Accessories ' STIHL USA
www.stihlusa.com/products/oils--lubricants-and.../oils...lubricants/chainoi... Rating: 4.5 - ‎6 reviews Don't let friction cut down your chainsaw's performance. STIHL bar and chain oil is specially formulated to adhere to your chainsaw's bar and chain, providing ...
2 stroke oil for the engine
XP® Professional Peformance 2 Cycle Engine Oil 50:1 ...
www.husqvarna.com > ... > Accessories > Lubricants & Fuels XP® Professional Peformance 2 Cycle Engine Oil 50:1. Our best ... 610 00 01-31, 6.4 oz. bottle for 2 1/2 gal. mix (50:1 Mix), $ 3.29. 610 00 01-32 ... Chainsaws.
Oils and lubricants STIHL
Feb 08, 2016 | Garden
How do I disassemble bar oiler and tank on unidentified chainsaw?
Stihl 017& 018 repair to bar oiling system, showing oil pump ...
? 12:36
www.youtube.com/watch?v=lJFAmUz49DQ
Jan 1, 2014 - Uploaded by Andy Reynolds A common fault with the Stihl 017 and 018 is low or no oil getting ... 018 repair to bar oiling system, showing oil pump feed andoil tank removal.
Sep 30, 2015 | Garden
Leaking oil when not in use
There's an o ring on the bar mount. It seals the oil passage from the tank to the bar. It will leak there. The tank itself may have developed a crack that will leak. The rubber lines from the tank to the pump can leak if they are cracked ir gummy.
Jun 29, 2015 | Stihl MS171 12" Chainsaw
Hi what kind of oil pump is on my stihl chainsaw 036 pro
here is the part number for your oil pump 1125 640 3201
Mar 14, 2015 | Stihl Garden
What is the gas-oil mixture for a stihl 036 chainsaw?
The gas / oil ratio should be 50 to 1. The manual calls for Stihl or equivalent oil with the classification TC, and gasoline with octane rating 89 or above (USA/Canada).
Sep 30, 2014 | Stihl Garden
My stihl ms390 chainsaw leaks bar oil, so i put a threaded plug in the hole, and when i get the plug far enough in, it impedes the oil flow to the bar.
Take the bar off and clean all the pieces and parts where the bar mates to the motor. Make sure the hole on the side of the bar, where the oil gets onto the chain drivers, is not plugged. Make sure there are no burrs, on the edge of the bar from chain wear, which will push the bar away from the chainsaw body leaving a gap for oil to leak. If your bar is worn, most bars can be flipped over and used either way. If it is made to be used in on either side it will have a hole for the oil to get into the bar on both sides. Alternating or flipping the bar will make it last a lot longer.
Something else to check is if your saw has a breather hole and if that is what is leaking or it is plugged and is not allowing the tank to breath. Not all saws have this feature.
When you store your saw it is best not to store it on its side with the bar hanging down as these position will cause more oil to leak.
Even if you have a perfect fit/seal, between saw and bar, oil will still leak if it is stored in a place with temperature fluctuations. This happens from the oil expands, when it warms up, creating pressure in the tank causing oil to leak out. I always put a piece of cloth on top of a plastic base to prevent seepage onto any surface. I run chainsaws professionally for over 35 years and they all will leak when stored in place with temperature changes. Some are worst than others. Hope this helped.
Sep 29, 2013 | Stihl Garden
Chain oil leaking on 025 stihl chainsaw
Their is a oil passage that has a plastic plug in it by the muffler. It might be gone like mine is.
Nov 29, 2011 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Stihl MS 250 16"
May 09, 2010 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Stihl 180 chainsaw,lack of oil to chain and bar
Apr 14, 2009 | Garden
Garden Logo
321 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
