Question about Epson Workforce 610 All-In-One InkJet Printer
Epson Workforce 610 feeds paper crooked then gets paper jam does anyone have a service manual or remove and replace instructions?
Looking at the printer from the front it starts to feed crooked left side first?
SOURCE: Printer will not feed paper correctly
I had the exact same problem and it was a foreign object (*** end lol). I fiddled about abit then turned the printer upside down, gae it a few taps and it was fine.
Posted on Aug 21, 2008
SOURCE: paper feeds through crooked and comes out crunched
Hi - googled and found a good Epson site with info on this - reproduced below - the part that worked for me was allowing a small bit of room between the paper on both sides and the paper guides (counterintuitive...) rather than flush up against them.
From the Epson instructions:
You can try using the Epson cleaning sheet (has a sticky side) to pick up any excess paper residue. It's available from the Epson Store.
Try loading heavier stock paper, such as 24 lb. paper, if you haven't done so already.
Make sure there is 1/16 to 1/32 inch space on each side of the paper in the paper tray.
Move the paper type selector back and forth 5 times, to make sure it is not stuck.
Feed the tray with a minimum of 20 sheets of paper and try to see if it loads paper through.
The paper thickness lever has two settings, one for plain paper, (thin paper 20# to 24#) and one for envelopes and thick paper.
It should be on the 0 setting for thin paper and on the + setting for thick paper and envelopes.
The paper adjustment lever may be adjusted in between the two settings to accommodate paper that is not standard or that the operating/environmental conditions have changed.
Make sure the paper is loaded far enough into the printer to ensure good contact between the paper and the paper feed mechanism.
Posted on Sep 07, 2008
  • 3 Answers
SOURCE: paper won't feed into printer. Always gets jammed
you must have objects foriegn objects inside your printer. i.e. paper clip or some other object . Get your printer and move it side to side see if you can here anything moving about. once its out then perform alignment of rollers using epson maintenance menu.
Posted on Jul 19, 2009
SOURCE: My CX9400Fax printer has a paper jam every time it
hi
hey i had the same prob til about 5 minutes ago ,, i kept pulling and playing with the jammed paper under the lid where you change the ink,, and finally on the left side ,,a blue piece of soft plastic material came out ,,now it works great ,,i have no idea where it came from but maybe it will help you lets hope
Posted on Dec 23, 2009
SOURCE: My epson workforce 600 won't feed card stock, 4 x
cmoreno8 - I wish I could provide some positive feedback, but I am having the same issue myself. Any resolution on this?
Posted on Jan 27, 2011
How to clear Epson WF3640 paper jam?
Hello, the only way to clean the jam is to first unplug the power, take off the back and look for the paper, pull all the paper out and if you can see the jam pull that out, you may have to get twizzers or plyers to do it. If you can't get the printer to paper feed out.
Dec 05, 2015 | Epson WorkForce WF-3640 Wireless Color...
Why is my printer in error state
Can you Clarify which type of error are you facing ?
Sep 21, 2014 | Epson Workforce 610 All In One Inkpr...
Workforce 630 paper jam
Epson Workforce 630 has two paper loading areas. One at the bottom and one at the top, back of printer. Make sure you set the printer to correct paper source, or just make sure paper is loaded in both trays to see if it starts taking paper in either one.
Jun 17, 2017 | Office Equipment & Supplies
I have a Epson Work Force 610 series printer that had a printer jam, how can I reset it?
There may be a scrap of paper still jamming the printer. It needs another look
Mar 24, 2013 | Epson Office Equipment & Supplies
Torn paper- how can I disassemble epson workforce 610?
Before you do a complete teardown, use a flashlight to examine every possible point in the paper feed path where the paper is jammed. There may be an easier way to clear it. In some cases I have had to clear a paper jam bit by bit using tweezers.
Oct 15, 2012 | Epson Workforce 610 All-In-One InkJet...
PAPER JAMS ON EPSON 615
Hi, Disconnect the printer completely from the PC and from power.Reboot the PC.Check through the paper paths for any obstructions and remove any stuck papers manually.Connect printer to power and PC and turn it off and on.Avoid filling feeding tray to capacity.Try printing now. Hope this helps.Thanks!
Dec 26, 2011 | Epson Workforce 615 AllInOne Printer
My Epson 610 workforce says it has a paper jam. But I have searched everywhere inside, even using a flashlight and twisting and turning the unit in every possible way. I don't see even the smallest shred...
Epson Workforce 615 problem started with a paper jam, got the paper out without any problem, then an error message to turn off the printer, which didn't work & when I did turn it back on there was a grinding sounds. I got the printer cartridge box moved over to the far right & there was a small white button that moved,so I used a Q-tip to hold it upright while turning on the printer. Woo Hoo, I'm back in business. Did have to clean the print heads.
Jan 06, 2011 | Office Equipment & Supplies
Epson workfroce 610 prints crooked
then you have to adjust the paper, it might be that the printer pulls one side of the paper in first making it look tilted.
Aug 02, 2010 | Epson WorkForce 600 All-In-One InkJet...
Epson Workforce 610 All-In-One InkJet Printer Logo
327 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
