Question about Dryers
I removed a Hunter ceiling fan with a light that was installed about 30-40 years ago. There are 2 white wires and one black wire coming out of the ceiling. There is one single switch on one side of the room for the light. There is a double switch on the other side of the room-one for the light and 1 for the fan. I have one black wire and one white wire coming out of the receiver for the ceiling. Do I attach both white wires out of the ceiling to the one white wire coming out of the fan? Also, there are two white wires on the receiver. 1 says ACINN. The other says COM. Which one is for the fan and which one is for the ceiling? The new fan is a Harbor Breeze Crossroads with light.
    Problem Solver:
  • 15 Answers
You need to get a voltmeter to figure this out. I've never seen the black wire be a neutral - ever. The way it "should" have been wired is one of the white wires is neutral, the black is hot for the lights, and a different color wire is hot for the fan. Usually blue or red. Whoever wired your house just used what they had and ran a white wire up from the fan switch to the box.
So - what I would do is isolate the three wires from touching each other. Then I would turn the fan switch off and the light switch on and probe the wires. The combination between one of the whites and the black should give you 120 volts. That white wire is your neutral. Just to verify, test between the black and the uninsulated ground wire - that should also give you 120 volts if the black is indeed hot. Then, turn the light switch off, the fan on and retest. Between the two white wires will likely give you 120 volts. You can verify the non-neutral white wire is the fan hot by checking it with the uninsulated ground which should give 120 volts with the fan switch on.
As to the wires on the fan - the manual should list those. COM would be the common neutral between the fan/lights. Are you sure the ACCIN wire isn't white with a black stripe?
Posted on May 01, 2017
    New Friend:
The black wire is most likely your neutral. The wall plate should have one light switch and a fan control. If you connect an incandescent or halogen bulb to one of the white wires and the black and you flick the light switch or turn on the fan switch the light should light, you can then determine which white wire is doing what.
cheers
Posted on Apr 28, 2017
5 Suggested Answers
worldvet
  • 859 Answers
SOURCE: Trying to replace 3 speed ceiling fan switch
The black goes to the L connection the others are a guess. You can do this two ways. Connect the colored wires in any sequence and then see what switch sequence give you high and lowest, the other one will be medium. Once you determine that, mark the wires with a piece of masking tape as high, medium and low. Otherwise you connect them, turn power on and use a multimeter to see which color gives you the highest voltage and which gives you lowest. Since you aren't comfortable using live wires and a meter, go with the first option and use the process of elimination to find the wires giving you the speeds you need to find the highest and lowest. Next, you need to determine how your switch sequence works. First pull has to give you highest speed. so you may end up wiring them in reverse if your first attempt is backwards. There is a reason the first pull needs to be highest, it powers up the motor so you can then chose a lower setting. A low setting first will over tax your motor and wear it out eventually as it has to work harder at first.
Let me know if you need further clarification and perhaps this is all you need to get fixed.
Regards,
Worldvet
ps I checked on the Internet of a wiring diagram and I bet you did tok all to no avail.
Posted on May 27, 2008
SOURCE: Trying to hook up a
Did you get a solution to this? I am having the same issue
Posted on Mar 04, 2011
intower18
  • 957 Answers
SOURCE: i am installing a harbor breeze ceiling fan i
Please try this link below because this might help you. You will see lots of link from the site just select the better solution that can give you.
Just click HERE so that you will be directed to the site:
Thanks
Posted on Aug 02, 2011
SOURCE: Wiring Hunter ceiling fan into old house. My house
Your copper, green wire are the ground. I beleave that the white is the power, and the black is your neg. to make sure i would use a wire tester to determen the power. From there white goes to white, black to black, and green to copper. I am not sure on the white/black wire it maybe another power. Look at your instalation manual it should tell you.
Hope this can help.
Posted on Mar 20, 2012
Hunter ceiling fan/light unit install with 3 pole switches. there are 2 white, 2 black and one orange wires coming out of the electrical box. How do i handle the installation?
Not understanding, three pole switch is a wrong switch, wires in the ceiling or wall electric box.
Needed: What switch is existing and what wires are in the switch box and runs or groups in each run coming in as wire groups. Same for ceiling box, colors and wires in each run coming in.
Basically, remove the existing ceiling fixture and connect the ceiling fan replacing the fixture to the same wires the fixture was connected to. White to white, green or bare to green or bare, colored wire to fan's blue and black. Wired like this one switch controls both fan and light, on and off at same time. Use fan pull chain switch for individual fan or light control.
Oct 22, 2017 | Hunter Dryers
Remove light governor
I installed my Hunter Ceiling Fan a little over a year ago. A few nights ago my wife told me the lights in the ceiling fan blinked a few times when she turned it on. Over the next few day the problem got much worse. When I turned on the light switch, the lights would not turn on. After a few minutes the lights would begin to flash, like a strobe light. This flashing would last for about a minute.
This morning I removed the light kit. I noticed the watt regulator, part 98480-02. I connected the wires directly that were wired through the regulator. So far, the light now works fine!
Jun 11, 2014 | Hunter Ceiling Fan Light Switch Control
We had the Hunter fan installed in April and have been very pleased with its performance. About a week ago whenever you turn on the fan light it flickers nonstop. Can you help me?
this is caused by the watt governor or the black box in fan to the lights. remove the watt governor and wire the lights directly. when removed, hook white wire to white wire, and black wire to red wire. black and red wires are always the hot wires. governor part number- 98480-02, have a good day !!
Jun 19, 2011 | Hunter (25417) Ceiling Fan
We purchased the Hunter Ceiling fan over a year ago and it has worked fine up until a couple of weeks ago. When we turn on the light it just continuously blinks on and off.
there is a watt governor, or black box for the lights to cut down on wattage or energy use. you can remove the black box for the lighting, and wire it directly to the main wires. white wire to white wire, and black wire to red wire. black and red are always a hot wire and white is a neutral wire. the part number on black box should be 98480-02. this should stop the lights from blinking. have a good day !
May 28, 2011 | Hunter 21871 56'' Ergonomic Brushed Nickel...
Im installing a remote to Hunter fan w/light. A White n Black coming from fan, Remote has Red,Black,White n Black n White to go to ceiling.Where do the red,black n white from remote go to on the fan? Thank...
Black goes to the black on the fan white goes to the white on the fan and the red will go to the blue wire on the fan for lights. Now if you have a black wire with a white stripe on it from the fan that is the light wire.
Apr 20, 2011 | Hunter (25417) Ceiling Fan
Ceiling fan and light wiring, 2 switches, 1 romexHunt
If you have only one black and one white in the ceiling to connect the fan / light to , then you have only one switch for this ceiling box. The fan / light will connect the white wires together and then the two colored wires on the fan to the black ceiling wire. In order to use separate switches for the fan and the lighht a 4 wire cable must go from the switches to the light so you have a red and black wire to switch the two separately .
Oct 30, 2008 | Hunter Vaulted Ceiling Mount - Antique...
Wiring connection ceiling fan
copper to green , white to white , seperate the black and the black with th white tracer you wired together connect the black to the black and the black with white tracer to the red in ceiling , without looking this is my best advise ,good lk
Mar 24, 2008 | Hunter 20531 Vista Brushed Nickel Ceiling...
Dryers Logo
193 people viewed this question
Top Dryers Experts
