Question about Logitech X-540 Multimedia Surround Sound Speaker System (6-Piece)
Logitech x-540 conroller has no cabel inside how to conet again right way? any foto inside controller
  • risto kanninen Nov 09, 2012
    Back side the controller is code numper PID: R640. I allso called Finlandhelp service, but they can not sen any picture orprepairin help for me!? It`the logitech company law. They cently promice 50%accaunt to by a new one. may be i`ll have to chance all my many logitech systems a nother more helpfull inporter in in finland. I andestod the law is same all around the world
How manage volume headphones in x-540
headphone Volume is controlled by the music app. Logitech Support
Feb 03, 2015 | Logitech X-540 Computer Speakers
Controller has no cabel inside any more my child take all off. any conectin clour foto inside the controller? can fix it a right way
If in a hurry take to a repair shop to see if it can be saved or you need to buy a new one. I would also look on EBAY as can get it fast or Google the number on the remote or unit with "remote".
Nov 08, 2012 | Logitech X-540 Computer Speakers
I have a new dell inspiron. I just purchased Logitech x-540 surround sound speaker system. The right front, left front, and center speakers don't work. Everything seems to be hooked up right. Any ideas. Is...
Yes there has to be a configuration for the 5.4 surround sound... look if the hardware came with a CD to update the sound driver. or Check if the its correctly configured. on the control panel then click Sound, then depending what windows you have have to lookk for the configuration or properties area and configure as 5.0 or sorround etc.
Feb 21, 2010 | Logitech X-540 Multimedia Surround Sound...
How to connect logitech X-540 to LG 42
Hi, You should have an Audio outpout RCA behind your TV. Plug it 2 RAC then the cables to an RCA/ 3 mini JACK adapter. Plug the 3 mini jack to the X-540. You have your audio output settled up on your X-540. Thanks and have a nice day !
J -
Jan 23, 2010 | Logitech X-530 Computer Speakers
Logitech x 540
Following is a diagram showing how to connect the speakers. a1d5e61.jpg This was taken from the logitech x-540 user manual. You can download the manual from http://safemanuals.com/user-guide-instructions-owner-manual/LOGITECH/X-540-_M
May 11, 2009 | Logitech Z-2300 Computer Speakers
Logitech x-540, front right & left speakers not working
Turns out my soundcard wasn't fully inserted into the motherboard, so I just took it out then put it back in and everything works fine.
Mar 30, 2009 | Logitech X-540 Computer Speakers
Feedback sound, hissing , in speakers logitech X-540
You may want to try disabling/muting the microphone volume in the volume control. If it doesn't help please post back.
Feb 19, 2008 | Logitech X-540 Computer Speakers
Connect DVD Player to logitech X 540 Surround System
Bad connection on that one speaker, if you have tested the system with other equipment and it works thn you MUST have a bad connection INSIDE you DVD player. If your DVD had a whole channel out on your output amplifier I beleive then 2 speakers would not work so more than likely you have a bad solder joint inside system for DVD output
Feb 11, 2008 | Logitech X-540 Computer Speakers
X-540 Speakers
go into sound device on control panel. make sure digital is unchecked.
Feb 08, 2008 | Logitech X-540 Computer Speakers
Use the logitech sistem with lcd tv
hey no it wont work in full 5 .1 cuse samsung tv has rca outs use rca to mini sterio jack but your speakers syetm for pc is set up for fronts rears center chs 3 sepret sterio plugs for pc so u can only use one of these sets front with woof not all 5 nope unless ther was a controller in it that ran off 1 sterio plug to controll all 5 built into the logitec speakers but i pretty sure 3 sterio plugs right ? u understand best best dvd samsung x 40 those rock
Jan 09, 2008 | Logitech X-540 Computer Speakers
Open Questions:
See all Logitech X-540 Multimedia Surround Sound Speaker Questions
Logitech X-540 Multimedia Surround Sound Speaker System (6-Piece) Logo
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
