Question about Acer Aspire 7741z
My Acer laptop won't power up but charger light is on
    Novelist:
    Champion:
  • 233 Answers
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the laptop charger and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Posted on Nov 08, 2012
parrotheadpc
  • 2600 Answers
SOURCE: acer aspire 5920 wont start. light in AC chrger
This is a sample of what you can try to do to diagnose a non-starting computer, If these don’t work, realize that most likely a system board (motherboard) has failed or the actual power trim strip above the keyboard has failed.
  1. Unplug the computer, then take the battery out, push the power button and hold it for about 30 seconds. Plug the system back in (leave battery out) and push the power button. If it starts, Great! If not unplug go to the next step.
  2. You should still have the battery out and the power unplugged. Now turn the laptop over. Take off all the covers and pull out the hard drive and ram and wireless card. Find the screw that has a symbol kind of like this its the CD rom drive screw. Now pull the drive out. Pick one stick of ram and put it back in the computer. Flip it over open it plug it in and hit the power button. If it does not fire up then unplug it and switch the ram. Plug it back in and hit the power button again. If it doesn't start up, unplug the computer and go to the last step.
  3. Pull the memory out and find the screws that hold the keyboard on. There are symbols in the plastic there should be 2 screws holding it in. Now in the battery compartment, there are several screw at the back edge of the computer take them out and also the ones in the battery in the center strip. Some are silver and some are black. Once you have the screws out of the battery area flip the computer over and open the lid. The strip just below the LCD with the power button and controls will now be able to be lifted up. You will probably have to lightly get an edge started before it will come up. There should be several little cables hooked to it. Flip the control panel over and look for some screws holding the keyboard in. I think there's 2. Lift up the keyboard. Making sure there's nothing touching anything important and then plug the computer in. Carefully hit the power button and see if the computer tries to start. If it does try it will probably beep at you. Unplug it and put a stick of ram in it. Plug it in and try to start it again. If not, unplug the computer and Go to the next step.
  4. Carefully put the keyboard and control strip in place. Flip the computer over and loosen all the screws that hold the computer together. Flip the computer over again and pull the keyboard and control strip up again. Flex the inner aluminum plate that was under the keyboard lightly. Plug in the computer and then hit the power button. If it tries to start, Great! put it together again in the reverse process.
If it does not, there are 2 possible things I would suspect the Control strip or the mainboard. If you don't get the computer to start back up please put it back together so you remember where all the screws go. Even if you plan to get another mainboard put it back together.
Posted on Oct 12, 2009
  • 31 Answers
SOURCE: Acer Aspire 5538 Won't power
It sounds like your computer's charging port is disconnected from the motherboard. The charging port cable probably has to be re-soldered to the motherboard to be fixed. If you are not skilled in computer hardware repair-ale I would suggest going to a computer technician.
Posted on May 13, 2011
  • 11800 Answers
SOURCE: My Acer Aspire One Netbook
Massive hardware failure on the motherboard - the netbook will have to be opened and its components tested by a repair shop. Take it to one.
Posted on Jun 05, 2011
tbirdfan1
  • 3051 Answers
SOURCE: Did system restore on acer aspire 5532 and now it
Hello there and thank you for choosing fixya
This is a fairly common problem
Ok what you need to do is first turn off the laptop
then remove the battery from the laptop then after the battery is out
press and hold in on the power button for 45 seconds (this allows for the esd to be released)
Now get the power cord and plug it in *** NOT HE BATTERY YET***
NOW try to start up the computer it should start up ok now if so great let it boot fully then attempt to shut down normally then replace the battery and you should be ok
If not then immediately unplug the machine then you will have to try 1 of 3 things first is to remove all the memory and then see if it will start if so replace the memory 1 at a time then start up after each memory module has been installed you may find it wont boot with 1 of the memory modules if so that module may be bad ok?
Please try these things first let me know so i can proceed on if i have to
ok?
Best regards Mike
Posted on Oct 20, 2011
gregmen83
  • 199 Answers
SOURCE: cursor won't move on my Acer laptop
Dear Friend,
On your desktop press the following key conbination: Fn + F7 if not, there must be a problem with your mouse pad. It might also be that your OS takes time to load or freeze and it make it look that the mouse is not working. You can also try and external mouse.
Good Luck!!!
Posted on Nov 08, 2011
Acer Aspire 5552 won't power up, charge light flashes on and off
Remove the battery and plug in the Cord/charger, will it boot? If no, try another Cord/Charger with the EXACT same power specs. Replace battery if necessary.
Mar 02, 2013 | Acer Aspire 5552-3691-24271 Laptop
Acer laptop 5551 wont charge
The solution to your problem lies in one of the following three areas:
1.) Your charger is faulty and is therefore not able to pass power to your laptops battery.
2.) The charging connector on the laptop has come loose from the contacts. Therefore a bad connection.
3.) Your battery is faulty.
I think possibility 2 is the most likely, although you will have to test possibility 3 by removing the battery and plugging in your charger and seeing if the laptop powers on.If it does power on then that rules out possibility 1 and 2 leaving a faulty battery.
Replacement Acer Aspire 5551 AC Adapter 65Watt 19V 3.42A
Feb 17, 2013 | Acer Aspire Computers & Internet
My Acer KAV60 laptop won't turn on. When I push the power botton, it blinks green once then nothing.
Has the laptop been damaged? Dropped? Same on battery? Remove battery, try AC only. Try another cord/charger with the EXACT same power specs. Reseat Memory mods. Test the DC volt output, at the laptop plug in, with a multimeter. Power issues are difficult to diagnose long distance.
Jan 31, 2013 | Acer Aspire One PC Notebook
My acer aspire one notebook won't boot up.
Is the new cord/charger/transformer the EXACT same power specs? When your "dog ate your charger", it may have shorted out something in the Laptop? Was it plugged it when your dog ate it?
Jan 16, 2013 | Acer Aspire One PC Notebook
Acer emachine s525.it will not power on,it refuses to charge.the charger lights up but nothing.I have tried using a different charger for another laptop it also shows that there's current coming...
The AC jack may be damaged due to pulling on the cord. Make sure the other cord/charger/transformer is the EXACT same power spec before plugging in, it may fry the laptops internal PSU.
Jan 15, 2013 | Computers & Internet
Battery won't stay charged
Bring the power cord/charger to a pc shop and have them test it. It might need to be replaced. Otherwise you need to replace the battery.
Jul 21, 2012 | Acer Aspire 55155879 Laptop Charger...
Not charging Acer Aspire 5732z, now won't turn on!
If it does not work with the Charger while the battery is out then I would say either your charger is bad, the dc power jack where the charger plugs into the laptop is bad or you've got motherboard issues. Does the charger have a light on it to indicate that it is on when plugged in the wall? Do you see any lights when you plug the charger into the laptop?
Take an ink pen and see if the little pin inside the computer where the charger plugs is loose and moves a bit. If so that is probably your problem. If the pin is tight and the charger works, then you've got motherboard issues.
Mar 29, 2012 | Acer Aspire Computers & Internet
ACER ASPIRE ONE D255E POWER CORD WON'T CHARGE BATTERY PLUGGED IN THE POWER CORD WON'T CHARGE THE BATTERY ALL THE TIME ...
Hi: Acer chargers have a very short life time, in the past 2 years I had bought 2. Just buy a new one from amazon they're very inexpensive. Here's the link: http://www.amazon.com/Laptop-Adapter-Aspire-AOA110-AOA150/dp/B0028LK6IU/ref=pd_bxgy_e_text_b
Regards,
Sep 25, 2011 | Acer Computers & Internet
Hiya i have an acer aspire 5920 which doesnt turn on when you connect the charger the charger light turns off and to get the charger light to turn back on you have to unplug from the wall for 5mins and...
Howdy ,
Sounds like the power pack or the battery is going out.Unplug, remove the main battery and put laptop on flat surface (board on the table)as a precaution.If your laptop runs normally then take it to Office Depot and they will check it for free to see if you need a new battery.I have done this and they just let you know what's wrong.Thank You for choosing FixYa.com. P.S.It won't hurt to run without the battery because they are two separate systems.
Re: Can I run an Acer without a battery? I NEVER have the battery in my 6930G. My laptop cooler then blows cool air in keeping it ultra cool.
A reputable computer magazine recommended that when using the Mains you should REMOVE your battery since one of the biggest killers of batteries is heat.
Jun 06, 2011 | Computers & Internet
Acer Aspire 7741z Logo
112 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
