Question about Creative Nail Design Brisa Uv Lamp 110 Volt Cnd
No power supply...the fuse is good - Creative Nail Design Brisa Uv Lamp 110 Volt Cnd
    Problem Solver:
  • 11 Answers
Check power cable and fix its connection properly or not
Posted on Nov 07, 2012
My power outlets have no power. The fuses are good under the hood and inside fuse boxes. Any suggestions?
Year/make/model?? To have two defective power outlets would be uncommon. Suspect a power supply issue ( most common ) to outlets. You may have missed the fuse that supplies these outlets. Supply me with make/model and I will give exact location of fuse that needs to be checked
Dec 06, 2015 | Cars & Trucks
Model Yamaha ME-50 no power
John
With AC power off.
Use a meter (on Ohms scale) to check internal fuse for blown (open) fuse.
If you feel qualified & safe with AC Power On.
Check input to internal power supply on AC Scale (Caution when AC is on) for volts in.
Use meter on internal Power Supply for "probably" DC volts leaving internal Power Supply electronics to power the rest of the electronic circuits.
Switch mode power supplies can break down. They stop doing their high frequency switching so they don't convert AC to DC.
If this P/Sup is a separate box or circuit board, inside the unit, then it can have a part number & be replaced.
Good Luck
Jul 14, 2014 | Yamaha Music
Dear Guru my power supply of my computer with model enp-2120d doesnt work no power output so please gave me some idea or schematic diagram,thank you.
Do not try to fix this power supply. Better to replace with new or good used. I see many on ebay from 13.50 to 25.00. Also google that model for other options. Most likely fuse on the power supply has failed but if you bypass the fuse, with jumper wire or another fuse, will blow again. Probably capacitors. Good luck
Aug 28, 2011 | Enhance Technology ENP-2120D (ENP2120D)...
Computer was shut down and power turned off. When i restarted the system the printer and monitor came on but the tower is not getting any power. cords are all plugged in and checked outlet works. seems...
If the outlet is good and the cord is good, you may have indeed blown the fuse in the power supply. That is the only fuse. The fuse in the power supply is usually "hard-wired". Not necessarily, but usually. You would need someone familiar with them to replace it if it is blown.
Some computers have a green LED on the back of the computer near the power cord. Do you have one? Is it on? You can also look to see if the small green LED is on on the motherboard.
If you get no indication of power, the power supply is probably gone. A new on is about $25 and pretty simple to replace.
Hope this helps.
Thanks for using Fixya.
Feb 20, 2011 | HP Pavilion a705w PC Desktop
Power supply
As a rule TV Techs will inspect the power supply first. I would certainly see if the fuses are good or bad. Simple?...well yes and no. If you should find a glass fuse and the clarity of the glass internally is clean, no problem.. Now..if the fuse is open and the clarity is clean inside....replacement will cure the TV problem.Repair is still possible. If the fuse is smoky and black internally...major problems, see a tech. If repairs are possible,(good fuse) next suspect a weak power supply and check all grounds, capacitors and resistors. Check voltages if possible. If the power supply is good...and the TV will not operate...could be the signal board. Just a few hints to get you started!
Nov 07, 2010 | Televison & Video
MY PS3 WONT TURN BACK ON
Either power supply problem or blown surface mount fuse on the main board. First check all SMD fuses on the main board, and the fuse on the power supply board. If the power supply board fuse has blown replace it and try again, if it blows again you need to replace the power supply. If the power supply seems OK check all SMD fuses on the main board. There are 7 on the V3 and about a dozen on the V4 / V5 / V6.
Good luck...
May 30, 2010 | Sony Playstation 3 (PS3) Console
I have a LG 37lc2d and it suddenly turn off and wont come back on, the stand by lights doesnt turn on either. i was wondering if its just the power supply? or how can i troubleshoot this my self to see...
There is a fuse on the power supply close to where the A/C is connected to the board. If the fuse is blown, look at the board and see if there are any burned components and or swollen capacitors. If there are bad components, I would suggest getting a new board.
If the board looks OK, disconnect the connectors from the board but leave in the A/C connector (this way you can isolate the power supply board), replace the fuse, and power up the TV.
If the fuse pops after the power is applied to the unit, then the power supply is bad.
If the fuse is still good, then power off the TV, connect on the main board’s connections, and power up the TV.
If the fuse is still good, then power off the TV, connect the inverters, and power up the TV.
If the fuse blows now, then the inverters and or the panel are bad.
A working power supply will create 5vdc for the main board’s stand by source voltage. This can be found on the power supply at the main board’s connector and it is labeled in black text.
I hope this information helps you.
Good Luck.
May 28, 2010 | LG 37LC2D Television
360 won't power up power supply good is there a fuse
They dont have a fuse in side them , it could be dry solder joints on the main pcb where the power plug goes into the xbox, make sure you try your power supply on another xbox as well as your xbox on another power supply. Also check the led on the power supply is green when its running, if the light is orange or red(whislt running, the light will be orange when in standby) .If your led on the power supply is red , you have a faulty power supply. Good Luck.
Sep 24, 2009 | Microsoft Xbox 360 Console
Soldered in new fuse, blew it right away...whats a good upgrade?
A new power supply will fix your problem, and when the fuse blows do not replace it. It blows to protect your computer. please replace with a new power supply.
Oct 28, 2007 | Okia / 450-Watt / ATX / 80mm Fan /...
Repairing of power supply
Sorry insufficient detail...
Have you the power supply in bits?
Have you checked the fuses?
How do you know its the power supply?
Its very difficult to help with very limited information...
Is there power available on the wall socket?
Cheers YUBEUT
Feb 19, 2007 | Sony MHC-GX450 CD Shelf System
Creative Nail Design Brisa Uv Lamp 110 Volt Cnd Logo
63 people viewed this question
Top Creative Nail Design Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Creative Nail Design Health and Beauty Expert? Answer questions, earn points and help others
