Question about Maytag Refrigerators
Icemaker ice sticks to the comb teeth and wont reseat
    Top Expert:
  • Maytag Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 09, 2012
  • 1 more comment
  • james m roney Nov 10, 2012
    model mtf 1955 grw
  • Richard Roth
    Richard Roth Nov 10, 2012
    The heater on the bottom of the ice maker has malfunctioned and will need to be replaced. Here is the icemaker to order. http://click.linksynergy.com/fs-bin/clic...
  • jwenger220
    jwenger220 Nov 11, 2012
    I had a similar problem. The ice was not full-sized. I pulled the fridge forward and checked the plastic water line and found it was crimped. Fortunately I could correct it by straightening it and squeezing the sides slightly to get it back to original form. Then I wound 2" wide masking tape around the area several times to support it so it wouldn't resume the crimp. I also taped the line to the back of the fridge so it wouldn't get trapped between the fridge and the wall and get crimped again. I carefully pushed the fridge back in place; then I checked the ice bin when I heard the ice maker dump. Problem solved - ice is full-sized and does not get caught in the teeth.
2 Suggested Answers
  • 1891 Answers
SOURCE: icemaker wont make ice. Any ideas?
tempt in freezer not cold enough or water inlet is frozen . defrost it with a turkey baster and hot water .. this may be caused by the water valve not closing complety and if so replace the water valve .. mm
Posted on Aug 10, 2010
Why doesnt ice come out just clicks
Sounds like it's not going into thaw or defrost mode before the dump cycle. Or you may have ice built up on the teeth and comb section of the scraper that pushes the ice out. When it clicks try and push it with your fingers and force it to move towards the ice.
Apr 26, 2014 | Freezers
Adjustable icemaker not making ice
Note that the temperature in the freezer must be below 10 degrees F for the icemaker to cycle. The icemaker line is the smaller line (1/4") located in the back of the machine that runs from the valve to the filll tube. To test the valve and icemaker you have to manually advance the ice maker and wait for it to call for water with the 1/4" line disconnected from the valve. You can do this by getting a jumper wire, removing the cover of icemaker, which you jsut grab and pull off, and using the jumper wire insert one end of the wire into the cirle marked "M" and the other in the cicle marked "N". Leave there until you hear a click and sometimes see a little spark behind the modular head wheel. Also if you see ice in the maker that hasn't dumper and the teeth of the icemaker are facing any direction other than two o clock position, the icemaker is bad. Before doing any of the above though check the fill tube to be sure the no ice is blocking water from coming in.
May 11, 2012 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Icemaker making noise
check that there isn't any ice stuck inside the icemaker teeth.
Apr 24, 2012 | Whirlpool Ice maker 4317943
Ice maker is not making ice through the door water is working
first thing to do is check to see that water is getting to the icemaker simply stick your finger inside the ice maker and check that there is water in there usually icemaker can be removed by three screws 1/4" against the wall if you have water and can feel ice on the inside remove the icemaker and flush with hot water then reattach the ice maker and wait 24 hrs to see if you get ice if it still does not work then your in need of a new icemaker which uyu can get from marcone appliance parts they willship the unit directly to your door and you wont have to pay a technicain installation charge hope this helps
Jun 26, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
I have a ge fridge it got a icemaker on it it works good but the flap wont let the ice fall down in the glass
ice sticks together, what pushes the ice out? gravity ,
hyperlink for the danby dcr412
http://www.ajmadison.com/ajmadison/itemdocs/dcr412productmanual.pdf
Nov 15, 2009 | Danby DCR412 Compact Refrigerator
Ice maker not freezing the water. teeth still appear to be turning but water only freezing due to cold freezer. water mostly overflowing and forming icicles all over the freezer section. have removed ice...
the freezer is supposed to freeze the water, the icemaker is just the form for the ice and the motor is to free the ice from the form, make sure water supply is cold water and not hot
Oct 10, 2009 | Whirlpool Refrigerators
Icemaker is not making ice. after reinstall, icemaker runs with no water and is not making ice. seems timer and relay are not in sinc.
remove the white cover on the icemaker may come off hard do you see a white round cam there should be no broken retainer holding it on if it is broken motor moldule is req ..... doe's it have an metal plate under the white cover if so check the cams 1 small 1 large to see if any of the teeth are broken if so replace the icemaker
Aug 19, 2009 | Kenmore Refrigerators
Ice not ejecting led flashing
Open the freezer door look at flashing led. Now on the left side is a flapper push that in with your hand be sure to keep your hand out of the way of the hole . where the led is now should be solid red. If it isnt then you need new optics. If it is then open the flapper in front of the icemaker at the top of the freezer. You should see the icemaker running width wise in the freezer. You may need a step stool for this next step. The icemaker should have what i call teeth pointing upwards at a 45 degree angle towards you. If these teeth are pointing down in the ice then you need a new module. which is behind the white cover of the icemaker on the left.. Hopefully this helps. Usually the gear head is broken on the module but of course you will have to remove it to find out. Happy hunting
May 27, 2009 | Refrigerators
My ice maker wont make ice the water is not going in the tray
First, make sure the arm on the ice maker not in the up (off) position.
Second, pull out the refrigerator from the wall and make sure there is no crimp in the line from the wall.
Third, check that ice is not frozen around the plastic teeth. Pull out the whole ice bucket and thoroughly check that something is not blocking or frozen in the wrong place.
This will get you started.
Jul 11, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker.....one of the stationary fingers on the ice maker is broken. Can I just replace this Comb? or do I need to replace entire ice maker?
On some icemakers you can just get the stripper. It would depend on the brand and model of the unit.
Apr 18, 2008 | Refrigerators
Refrigerators Logo
263 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
