Question about DEI Python 990 2-Way Security System/Remote Start with SST Technology
My battery died in my transmitter for dei python 990. i replaced it but the alarm does not recognize the remote. oh and the alarm is still active so i cant start my car!
How do I program my viper replacement transmitter for my car.
Dear Marta,
Here is a hands on to watch and program as you go. Follow to the link. How To program DEI Viper Python Avital Sidewinder Valet Hornet Alarm...
Here is another look. 1f Responder LE Remote Pairing
For your direct contact to Viper follow this link for any question. Viper Support
Fare. Well.
Dec 12, 2014 | Viper Vehicle Parts & Accessories
Tip
Dei viper python valet hornet boa transmitter programming help
DEI REMOTE PROGRAMMING INSTRUCTIONS
Need a DEI Remote Replacement Now? Try our all New Remote Quick-Find
Not sure what type of Replacement Remote you need?
In order to enter Learn Routine, the Valet/Program push button must be plugged
into the main brain's Blue 2 Pin Port (Look for a small black push button located under
the drivers dash or drivers kick panel somewhere). If you do not have the Valet/Program switch, you may order it at www.lesscoelectronics.com or www.lesscosales.com
1)
Open a door and make sure the dome light is on.
2)
Turn the ignition on to the RUN position or you may also start car.
3)
Within 15 seconds press and release the Valet/Program push button
to select the channel you wish to program. For example, press and release
once for channel 1 (arm/disarm channel).
For Channel 2, press and release twice (trunk release).
For Channel 3, press and release three times (remote start).
(Some DEI systems require different programming for different channels. You
can get specific installation manuals with remote programming instruction)
Press and hold the Valet/Program push button once more. You should get a
confirmation chirp/horn-honk or a flashing LED light (If installed).
If you do not get a chirp/horn-honk the alarm may have a jumper in
the alarm that has the programming feature turned OFF (disabled).
4)
Once the alarm chirps/horn-honks keep holding the Valet/Program push button.
5)
Press the button on the transmitter that you would like to control the selected receiver
channel. A chirp/horn-honk will confirm that the code has been learned. If programming
more than one transmitter repeat step 5. Old transmitter codes will be dropped only
if programming 4 new transmitters.
6)
Once the code(s) are learned, the Valet/Program push button can be released.
Learn Routine will be Exited if:
Ignition is turned off
Door is closed
Valet/Program push button is pressed too many times
More than 15 seconds elapses between steps
One long chirp/horn-honk indicates that Learn Routine has been exited.
on Jul 29, 2010 | Car Audio & Video
Set up the car remote
A 7701P is a remote transmitter. It is not an alarm. You must know the alarm's model because different models have various ways of programming transmitters. In other words, you do not program the 7701P. The frequency is already fixed. You must program your security system to teach it that transmitter's code. Look up the manual for your security system. Instructions will be there. This typically involves turning the ignition on/off a specific number of times and pressing a valet/programming button (or switch) a certain number of times and then pressing a button on the transmitter.
Jan 31, 2013 | 990 And 950 Responder SST Remote - 7701P
Need to see a picture of the toggle switch since this is my sons car and I do not have the remote start just the ignition key and alarm is gong off
the toggle switch will not disable it. you need to turn the key to the ON position WHILE the alarm is sounding (so if the sole virtue of turning the key triggers the alarm you will need to turn the key off and back to on), then press and release the valet switch once.
see the picture below to know what you're looking for.
http://www.carstereoneeds.com/images/dei-8631.jpg
Mar 06, 2011 | 990 And 950 Responder SST Remote - 7701P
How do the reprogram python 990 replacement remote
turn ignition on and within 10sec push the valet switch once then push and hold again. the siren will chirp once then push the lock button on the transmitter and the siren should beep once then let go of the valet switch and turn ignition off and remote should function properly
Jun 12, 2010 | DEI Python 990 2-Way Security...
My Python 990 system is acting up.Installed several months ago. Now doors wont lock or unlock and alarm goes off every time the door is open even in the unlock pososition. The vehicle is a 2002 Escalade...
Sounds like you have a bad remote, bad battery in the remote, or it needs to be reprogramed to the alarm. If the alarm has been set with the remote, it will need to be disarmed with the remote as well, unlocking the door with the key and getting in, will set off the viper. If you know where you valet switch for the alarm is(small black push button), just turn the key forward till everything on the dash lights up, push the valet switch for about one second and let go. The alarm should shut off in a couple seconds. This will allow you to drive the car until you get you remote checked out.
Aug 15, 2009 | Directed Dei Valet 561r Remote...
Python 990 isnt locking or unlocking my doors .
Its going to be either the wires going to the locks or the programming in the alarm. The only way to tell is to get the wiring tested. A plug could have just pulled out also. Do many variances for one straight answer.
Jun 04, 2009 | DEI Python 990 2-Way Security...
Intermittent arm/disarm of Python model 560XV
this "could" be a bad ground, however, usually when these units lose ground, they activate the siren at a really low level, because they are trying to ground through the siren.
I would say to check where the antenna plugs into the main unit,(brain) but honestly, in 17 years of dealing with DEI alarms, 99.9% of these problems are due to the transmitter - it may blink the LED like it is supposed to, but that doesnt gaurantee it is sending a signal. I would recommend buying a new transmitter and programing it to the brain.
Jan 15, 2009 | DEI Python 1400XP Remote Start/Keyless...
Reprogram python 990 remote
The P stands for programming. It's used when setting up the alarm system, you would need the manual for the system to tell you what can be done. I have a Python 990 and I can change pretty much everything from sensor adjustments, amount of time it turns over for starting, disabling the siren and many other settings. I found out the hard way one time when I accidentally pressed it and turned the key off and it disabled the siren. I think that's how it happened, been a while since it happened. I would have to get the manual out to be exact. You can also do the programming by pressing all 4 buttons at once and hold for 2 seconds. But you still need the manual to know what your doing. Hope this helps
Nov 11, 2008 | DEI Python 990 2-Way Security...
DEI Python 990 2-Way Security System/Remote Start with SST Technology Logo
Top Directed Electronics Vehicle Parts & Accessories Experts
Kevin Daniels
Joe Taylor
Joe Taylor
Are you a Directed Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
