Question about Bryant 95 Afue Gas Furnace Evolution355cav Plus 95 Multipoise
My Furnace is making a clicking noise only when on heat, and during the initial start up after that it is silent and runs good
We have had this furnace for about 4 years now and it has made this noise every since we bought it. We have had dial one heating and air come out every winter to look at it and try to fix this sound but they can never figure out what is making the noise. It usually doesn't make the sound for them and they leave thinking nothing is wrong. last June they even replaced the blower motor and it started making the sound again this winter.
    Master:
  • 571 Answers
Sounds to me like it is a spark ignition which clicks to light the gas and then drops out. This would be normal. If it is hot surface ignition, then the only thing I can think of that would make a noise on a call for heating would be the inducer motor (burner motor) making a noise on a cold start, then heats up from the combustion flue gas. Have someone pull the inducer, & move the squirrel cage position on the motors shaft slightly & see if that makes a difference.
Posted on Dec 06, 2013
3 Suggested Answers
shastalaker7
  • 1515 Answers
SOURCE: Bryant-Carrier Furnace Fan Stays On
Hi, you have replaced the stat several times, and adjusted the anticipator so its not the stat.This is a split gas/elect unit, and working on these for many years and looking at some of the solutions given, they are right.You need to be looking at the Furnace fan control.Units of that age they do tend to stick open and run constantly.I doubt its the fan relay, maybe if you were in the cooling mode.Fan controls are not that expensive. You probably have a Honeywell 7" to 11" Probe, with the auto/manual button, with a temp dial to set you're on off temps. I would inspect the heat exchanger for any signs of cracks or bulging being its that old. If you find any, you are looking at carbon monoxided and should be thinking about an upgrade soon.Also flame roll out.I am thinking of you're safety is all.If you do have this type of fan control, there is a tab that has to be cut before you install for 24v. control.It comes set for 120v. and will burn out all of your 24v. componants.Those old Bryants will run for years. Good Luck!
Shastalaker7
Posted on Nov 14, 2009
SOURCE: I found the Bryant furnace 395cav048090 calling
If you do not see a bright light before the gas releases, your ignitor is probably out. If you disconnect, you should measure ohms from the two ignitor leads. If you do not measure any, it is open and will not work. You will usually see a mark of white on the ignitor. Another possibility is the circuit board may not be sending the required voltage to ignite the ignitor so you'll want to check that too.
Posted on Jan 11, 2010
Model 393 Bryant furnace fan or motor makes noise when first starting. Then it's quiet.
https://www.repairclinic.com/PartDetail/Bryant-Furnace-Dual-Run-Capacitor/P2914553RS/2386586?ss=a36b380&mr=0
That part is probably going bad. The motor uses it to get moving and when it fails then the motor wont start, makes buzzing or humming noise due to phase loss.
Jan 28, 2017 | Bryant Heating & Cooling
Tractorman44 thanks but misunderdstood husband! When thermostat turned up the fan comes on before flames ignites. Plenum heats and furnace runs.
If the fan comes on first, then the flame ignites, it USUALLY indicates there is a problem in the ignition process of the furnace. Most new manufacturers have the adjustable 'time off' sequence for the blower, and most initiate a call for the blower to run within a pre-determined amount of time AFTER a call for heat has been established. ALSO, and this is where I think the problem is, the ignition sequence starts immediately upon a call for heat. If there is a heat ignition failure, it will attempt a restart. USUALLY, they allow 5 restarts within a certain timeframe then the circuit board locks out the heat sequence until it is reset by cycling the power or cycling the thermostat manually.
What I think is happening with yours it that your ignition sequence is experiencing a 'flame failure' upon a call for heat....then it re-establishes the ignition sequence, which takes another 30 to 45 seconds. During this time, the blower automatically starts (because the allotted time has expired) and blows COLD air because of the initial flame failure. In the meantime the ignition sequence establishes a flame on the second or possibly the third try and then you feel the warm air.
IF this is the case, ultimately what will happen is that the furnace will continue to experience 'flame failure' and eventually fail to the point of 'flame failure lockout' and you will have no heat, but the fan could possibly run continuously.
At any rate, without being able to be there to troubleshoot and test components physically, this is just a calculated and reasonably reasonable guess. What it is telling you is that you probably need to contact a reputable, reliable service organization to give your furnace a good going over before it lets you down on a good cooooold night!!!
I hope this helps you understand the basics of what happens within the system and bear in mind, this is a 'generic' sequence and possibly NOT the exact sequence of your particular furnace.
Oct 01, 2015 | Heating & Cooling
Model DGAA070BDT SER# 0112o6717 Colman Mobil home furnace My furnace makes a internal thump when it's in the cool down cycle after the burner shuts down and only the fan is running before the furnace...
Coleman is known for this. I have seen many over the years make this noise during cool down. The heat exchanger is contracting and expanding. The heat exchanger is the part that the fire burns in. It surrounds the flame, and when the furnace is on, the metal they use for many of their furnaces has a tendency to make noise as it cools off.
One other thing, if you don't already have one, it would be good for you to buy a carbon monoxide detector and put it in the mobile home somewhere up high hopefully in the hallway close to the furnace return air. If the heat ex. is expanding as is sounds, it would be good to make sure it does not have a crack in it , in turn releasing dangerous fumes. Hope this helps.
Apr 18, 2011 | Heating & Cooling
THE BURNER WONT LIGHT
The failure of the appliance to start at all can be one of the most worrying washer dryer problems. However, this may often just be due to the door not being closed properly. Try opening and closing the door to see if this makes a difference. Otherwise, there is likely to be a fault with the sensor or pressure pad that detects when the door is closed. Try wiping the door and the corresponding latch on the machine with a clean cloth before testing it again. It is also a good idea to check the seal around the door to ensure that it has not sustained any damage.
  1. Before you attempt to fix a furnace that won't start, make sure you know what kind of furnace you have. This ehow is strictly for a forced air, gas furnace. Check to make sure the furnace filter is clean. If not, replace the dirty filter with a clean filter. Also, check to make sure power to the furnace is on. Finally, make sure the gas supply to the furnace is open.
  2. If your furnace clicks on or initiates the start cycle, but does not fire up, you likely have a faulty or dirty ignitor/sensor. This is one of the most common furnace problems. Under normal conditions, the furnace is notified by the thermostat to click on, the ignitor gets red hot and then initiates the entire process of igniting the gas and blowing the hot air. Check the error codes in your furnace user manual to make sure you do not have a more serious problem.
  3. To fix the furnace that won't start, turn off the power to the furnace-and turn off the gas. Remove the front panel and look for the ignitor/sensor. Refer to your user manual to locate the ignitor. It is usually located near where the flames shoot out of the burners.
Dec 24, 2010 | Dryers
FURNACE MAKES STRANGE INTERMITTENT CLICK SOUND
Measure the voltage to Terminals #2 and #3 on the main gas valve. If the voltage remains consistent while you hear the sound and the burners diminish slightly, the problem will be your main gas valve. If the voltage fluctuates, you will have to trace it back through the wiring to see through which switch you are losing it.
If this furnace has a hot surface ignitor with flame sensor, try cleaning the flame sensor with some emory cloth.
I hope you find this information to be very helpful as a good starting off point for you.
Please leave a rating. :-)
May 11, 2010 | Heating & Cooling
Explosive restart on almost new propane furnace
IF IN DOUBT AND NEW IT IS UNDER WARRANTY. THEY DO MAKE NOISE WHEN RESTARTING, BUT NO EXPLOSION
Feb 26, 2010 | Heating & Cooling
Furnace will run, put out heat, turn off and doesnt start again.
What is model # & serial # of this furnace, it may have a diagnosis led indicator light located on the control board, behind bottom door of furnace which will blink and tell you a fault code. Also check furnace filter, make sure its clean, check through out the house to see if all registers are open and not blocked by any objects, make sure cold air return grill is not blocked, the unit could be over heating and shutting off on high limit, good luck.
Feb 15, 2010 | York Furnace Draft Inducer Blower Fasco #...
Screehing noise when furnace is running
usuall a schreeching noise during blower opperation is bad berrings which would need to be replaced. Most unit warrentys for newer units cover five year parts and sometimes 10 for heat exchanger. But most do not cover labor. Or the blower may just be off balance and metals are rubbing. eaither way your proubly gonna need a tech. good luck
Mar 17, 2009 | Ingram GMS90904CXA Heater
Gas furnace wont stay lit
sounds like the thermocouple that senses when the burner ignites is faulty. when the burner is first lit it looks for a signal from the thermocouple telling it that it has ignition. i have had some luck removing the part (furnace off) and sanding it clean. this is located in front of one of the burners..Good luck
Jan 15, 2009 | Central Dual Temperature Heat Gun Kit...
Loud humming noise
when was last time furnace was serviced --air filter change burner area cleaned vacuumed the hum can be a few reasons ---fan bearing need service [ oiled ] fan bracket bushings damaged or loose --burner out of adjustment burning improper etc these are a few
Jun 03, 2017 | Heating & Cooling
Bryant 95 Afue Gas Furnace Evolution355cav Plus 95 Multipoise Logo
281 people viewed this question
Top Bryant Heating & Cooling Experts
christian nielsen
Dan Webster
Dan Webster
Mike Squire
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
