Question about Tacsew BLST-2
Need help threading my model blst-2 - Tacsew BLST-2
  • Tacsew Master
  • 7,365 Answers
Try contacting acesewvac.com and ask them about a manual
1-800-992-4739
or you can check youtube, they do have some tacsew but I
couldn't find anything for your model.
Posted on Nov 08, 2012
How do I thread double needle
You need 2 spools of thread. Thread one needle all the way through the path. Then thread the other needle. NOTE: Some machines (newer models mostly) will have 2 separate tension units for separate threads. On older models, you will just have to use the same path for both threads. The reason you thread each thread separately is to keep the threads from becoming twisted in the path and causing knots that will affect the stitch quality and tension.
HINT: ALWAYS RAISE the presser foot when threading the top thread on your machine.
Mar 23, 2017 | Sewing Machines
White model 935 maintenance help
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Jul 27, 2013 | White Sewing 935 Mechanical Sewing Machine
Hi :) Just got a Hobbylock 788 and need to thread
Here is the trick: If you look at your thread spools, left to right, thread machine beginning with thread from spool 3, then 4, then 1, then 2.
Thread 4 is tricky. You must line up the purple line on the big wheel on the right end in order to do this. Thread the machine according to the diagram on the inside, then, making sure you lined up the purple line, push the lever at the bottom of the machine (below threading guides) to the left while holding on to the thread end. This will push the thread up and along the horizontal arm you just threaded.
Mar 21, 2010 | PfaFF Sewing Machines
Owner's manual
I found a website for you that might help. They have a lot of kenmore manuals including one similiar to your model#148.12051. The manual opened as model 1205 so maybe searching for your model as the 1201 might help too. hope this helps! =)
http://homeappliance.manualsonline.com/manuals/mfg/kenmore/kenmore_sewing_machine_product_list.html
Feb 04, 2010 | Brother PC-420
I HAVE A SINGER SEWING MACHINE MODEL 2732 AND NEED TO KNOW HOW TO MAKE THE BOBBIN COME UP. I AM LOOKING FOR THE MANUAL FOR THIS MODEL. PLEASE HELP.
When threading your needle make sure you pull enough thread through...a good 4 inches will do..hold the end of the thread and turn your hand wheel by hand until needle comes back up...you should have a loop around your upper thread ...pull this loop out towards you..you should now have two threads..cut threads till about 2 inches and make sure you position threads through the center of your sewing foot and towards the back of your machine. Good Luck
Jun 13, 2009 | Singer 2732 Mechanical Sewing Machine
Upper thread keeps breaking bobbin thread grtting cut on bobbin,
you need to change your needle first. then if that does not work you may have a small area on your bobbin case that has been damaged
May 22, 2009 | Baby Lock Esante
Threading a bernina serger
Here is a little jingle to remember as far as the order of threads to thread...
Upper looper, lower looper, left needle, right.
Usuall if you give numbers to the threads from left to right as 1,2,3,4 , you would thread it in the order of 3, 4, 2, 1 . Also when threading the loopers be sure the lower looper thread goes over the top of the upper looper thread as it goes out the back.
Hope this helps.
Sep 02, 2008 | Bernina 1008
Threading a husqvarna huskylock 1001L serger
Solution taken from "Handbook for Huskylock Sewing Machine Models 1001L/1000L/1000"
1. Raise the presser foot by using presser foot lever. When the presser foot is raised, the two thread tension discs in the thread tension control panel are released so that thread passes freely between them. Otherwise thread tension may not be correct.
Important! When threading the needle, always be sure to lift the presser foot lever, and also take care to thread in the proper order.
Threading order:
1. Upper looper thread (green)
2. Lower looper thread (blue)
3. Double chain stitch looper thread (purple) in case of 5 thread stitch or double chain stitch
4. Right needle thread (red)
5. Left needle thread or double chain needle thread (yellow)
Caution!
Because the left thread tension dial (yellow) is used for either the left needle or the double chain stitch needle, these needles will never be used at the same time.
Upper looper (green) sequence:
1. Thread holder (silver triangle openings attached to thread holder stand)
2. Thread guide (flat silver clips just behind thread tension disc)
3. Thread tension disc (circular knobs with numbers for tension setting)
4. Pull thread around upper looper guide and upper looper
5. Pull thread into hole of upper looper
Lower looper (blue)
Repeat 1, 2, 3.
4. Pull thread around guide (see color coded chart inside front serger cover).
Easy threading mechanism (for lower looper)
1. Pull out the lower looper threading lever
2. Thread the lower looper and position the thread on hook of the lower looper
threading lever.
3. Push the lower looper threading lever back to its basic position while
holding the end of the thread.
Caution:
When returning the lower looper threading lever, always make sure that the two
blue triangle marks (directional arrows) meet each other.
Left needle thread (yellow)
Important: Thread the needles after threading of lower looper and upper looper.
First raise the presser foot lever, and then thread the needle threads in order shown in color coded thread guide.
Jun 24, 2008 | Sewing Machines
Threading & bobbin won't pick up
Make sure the needle is inserted all the way in with the long groove to the left.
Threading is through 1)the thread guide 2)The tension 3)The take up lever 4) The needle eye (left to right).
Remove the needle plate, thread the machine. Turn the hand wheel and watch the thread in the needle to see if it is above the eye of the needle. If it is, the machine needs to be retimed.
Sewman7
Apr 27, 2008 | Consew 1118-3
Sewing Machines Logo
19 people viewed this question
Top Tacsew Sewing Machines Experts
Rommel Balcita
Shehu Pro
Shehu Pro
Nick Olsen
Are you a Tacsew Sewing Machine Expert? Answer questions, earn points and help others
