Question about Zanussi FLA1101W Front Load Washer
Zanussi aquacycle 1100 fla1101w bearings
The machine is verry noisey on spin how do we replace the bearings
SOURCE: i think the bearings have gone on my zanussi
I have just done this myself and to be honest it was quite easy.
you will need bearings l replaced both front and rear as the cost of each was nothing, a new bearing seal and a drum gasket as the drum has to come apart.
Tools are a digital camera ,socket set, torx key set, set of spanners a cold chisel and a hammer. And you need the old bearings to put the new ones in
Posted on Aug 19, 2009
beltronic205
  • 1474 Answers
SOURCE: Zanussi Aquacycle Washing Machine wont spin?
Assuming its pumping out ok, sounds like motor brushes..if not pump clear filter..
Posted on Oct 06, 2009
  • 57 Answers
SOURCE: noisey drum, can bearings be replaced on zanussi zwf 1421 w
Yes they can. Search for a service manual for instructions, on the net. Parts are not usually exspensive, Repairmen are. I did mine in less than an hour.
Andy
Posted on Nov 09, 2009
barkencoa
  • 3463 Answers
SOURCE: Zanussi Aquacycle 1050. My washing machine seemed to stop spinnin
Locate the filter at the botton front right of washer, behind a drop down cover.
Unscrew anti- clockwise to remove and clean.
If still no go, then you need to check the brushes in the motor.
Hope this helps.
Posted on Dec 31, 2009
SOURCE: zanussi electolux aquacycle 1200 w/mc wont spin
Try new bushes and make sure where bushes run is clean and free from carbon H
Posted on Mar 04, 2010
My Zanussi aquacycle 1100 is not spinning continually (very weakly) and leaving the clothes very damp.
Motor coupling or equal. Most likely. This happens by over filling washer or placing carpets. Bed blankets etc
Feb 16, 2015 | Zanussi Washing Machines
Zanussi aquacycle 1200
Sounds like the bearings have collapsed. If you are intent upon doing this yourself check out How to replace washing machine bearings on youtube.
Sep 13, 2013 | Washing Machines
Broken bearing
not sure whay you wish to know, replacing the bearings is quite a big job/ expessive if over 5 yrs old suggest new machine....
Feb 23, 2010 | Zanussi FLA1101W Front Load Washer
Location of bearings on a zanussi fla100w
how do you change bearings on zanussi fla 1101W
Jan 11, 2010 | Zanussi FLA1101W Front Load Washer
Zanussi electolux aquacycle 1200 w/mc wont spin
Jan 09, 2010 | Electrolux Washing Machines
When my zanussi aquacycle 1200xc is on the fast spin cycle the spinning drum seems to be getting noisier of late.
Probably the main bearings are going, spin the drum by hand, there should be little or no noise at all, if it feels rough, or noisy, then bearings are failing.
Please rate my solution.
Thanks.
Oct 10, 2009 | Zanussi F1245W Front Load Washer
My zanussi aquacycle 1100 is making a very heavy clonking noise on spin cycle.Have you any suggestions? Thanks Craig
Sounds like the main drum bearings have gone.
Turn the drum by hand and if it feels rough or noisy , the bearings have gone.
There should be little or no noise when you turn the drum by hand.
It is quite an involved repair , as it entails a complete strip down.
Plz rate my comments.
Tanks, and merry xmas.
Dec 20, 2008 | Washing Machines
Washing machine noisey on final spin
this isn't a problem usually every washing machine is very noisy on a final dry its normal
Oct 15, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi aquacycle 1000 washing machine spin problem
this is possible due to a bearing collapse or bearing spider broken. this causes drum pulley to be out of line and the belt comes off
May 29, 2008 | Zanussi FJS1225W Front Load Washer
May be the Bearings.Open door and try moving drum, hold at top of drum and pull foreword and back if drum loose main bearings gon. Replace bearings.
Slim Jim
Oct 28, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi FLA1101W Front Load Washer Logo
419 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
