Question about Samsung SyncMaster 913V 19" Flat Panel LCD Monitor
It is 7x3cm big, and its like dark green with bright green lines. I can see underneath it my screen, but only if i look deep.
    Genius:
  • Samsung Master
  • 2,432 Answers
If you can hooked up with other monitor just to ensure if the problem is only with in the monitor. after you replaced with other monitor then the display is clear or good picture, that was mean the only problem is the monitor. if the upper portion is black screen or the picture not so clear the cause is busted screen back light. to see the back light you will need to remove the back cover of the monitor. then the back light is a thin cold cathode flourescent tube, it was covered with a metal shield cover protection attached at the upper portion of the screen panel display.
Posted on Nov 08, 2012
SOURCE: monitor dark
I had a similar problem with this monitor, mine was dim all the time to the point you cant use it, but the MENU icon was bright as new... also if cable was unplugged the box would float around as normal.... anyway I fixed it by taking it all apart and pushing in the socketed chip.. it clicked like it moved, I also pushed on the variable resistors on the power supply... now it works!!! First time since it quite working long time ago
Posted on Mar 01, 2008
SOURCE: Samsung Monitor Syncmaster 913V Montior Screen shows patches of screen on desktop and playing videos
try to reset the monitor to its default settings.
Posted on Aug 24, 2008
stabelabel
  • 51 Answers
SOURCE: Samsung SyncMaster 730B monitor green color problem
video controller card has gone bad need new video controller card.
Posted on Mar 16, 2009
  • 67 Answers
SOURCE: i have a blue line in my monitor
line driver element defective. no repair possible, to my knowledge. replace LCD or ignore line.
Posted on Mar 31, 2009
davesoucy
  • 148 Answers
SOURCE: It has a very dark screen, I can barely see my
Check the pins on both end of the connector, make sure they're straight other wise, reposition it with fine long nose pliers. Make sure the connectors are push and screwed tight also. Let us know!
Posted on Oct 10, 2009
Screen is too dark
try turning up CONTRAST or COLOR or TINT or HUE hope this helped..... how bright is the room is the tv easier to see at night if the sun is hitting the screen that will make a big difference..
Nov 18, 2012 | Samsung HL-T5676S Television
Our Mitsubishi WD 52525 goes to blue screen and shuts off.
It sounds like you TV is overheating and the video is suffering and the lamp is overheating as well. Also, if your TV is over 2-3 years old, the mirrors (behind and below the big front screen) desperately need to be cleaned. Clean all filters and fans as well. (Look on side and behind the unit). Is the TV in a "hot" environment and/or dirty environment? DLP TV's are NOT sealed units. They need to be cleaned every few years to work well to have a good, clear, bright picture.
Jun 24, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Blue, green, red parallel curved lines at top of screen
hello sorry but it sounds like the chip have gone again when you replace these chips you might have to change the resistors and the 2 capacitors as well
shaun
May 08, 2009 | Mitsubishi WS-55905 55" Rear Projection...
Screen slowly turns blue...
I had blue lines showing up on my screen, then the other night my screen started to flutter the blue, bright to dim and back. So I followed this link to resolve the blue lines and the blue flutter was resolved as well. Hope this helps.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Jul 26, 2008 | Sony KP-51WS500 51" Rear Projection...
Brightness on VS-50605
The darkness shouldnt be that exspensive some trouble shooting and a few dollars should straighten that out. The screen however will cost a couple of hundred dollars, although that would still be cheap for a big screen, and that model does play exceptionall well when operating properly.
Jul 12, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Big Green Bar
Hi Tom017
Does this green bar show even when there is no signal inserted into the Projector ?
If it doesn't then you can try using a different cable - that should solve this for you.
If it doesn't then you might be in for a quite expensive Mainbaord repair or replacement.
Good luck and thanks for using Fixya !
May 06, 2008 | Canon LV-LP12 Projector Lamp for LV-S1,...
Hp laserjet 1100
When the paper gets low in the storage tray the printer starts pulling several sheets at one time.
Mar 28, 2008 | HP LaserJet 1100 Printer
JVC AV27320 Screen too dark
Check the lumans circuit. may be jungle IC
Nov 02, 2007 | Samsung HC-P4241W 42" Rear Projection...
Zen V plus display
screen would have to be replaced
· For parts email: arnoldjin@hotmail.com see if he has one.
Sep 18, 2007 | Creative Labs ZEN V Plus MP3 Player
Samsung SyncMaster 913V 19" Flat Panel LCD Monitor Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
