Heat for a 3 seasons room
I have a 3 seasons room on the back of my house, it is L-shaped with 3 walls of single pane glass, the 4th wall is the house. It is about 300 sq. ft. with a 9 ft. ceiling. I like to use the room in the winter and heat it with a electric baseboard heater a a couple of space heaters. This works but the electric bills are very high. I have figured out how I can run ductwork off my furnace using 6" round pipe and 3" x 8" oval pipe with a heat supply on one side of the room and a cold air return on the other. Would this work and how much heat would I get with this set up? Thanks, Alex
    Top Expert:
  • Heating & Co... Master
  • 49,327 Answers
Single pane glass is not thermally efficient as the glass transfers heat or cold
double glazing with a air space between is more efficient and will require less power to keep the temp setting
before you do anything , talk with a thermal engineer or you could be wasting money by doing what you suggest incorrectly
Posted on Apr 18, 2017
4 Suggested Answers
hotuna
  • 288 Answers
SOURCE: High Altitude Electric Heaters
I have never heard of altitude effecting the electric. Watts amps and volts are different than burning a gas, like propane. The high altitude has less oxygen thus requiring the combustion to be effected. If your wires are over heating when you use maximum wattage (amps) you need to install larger wire with the correct size breaker. Look up ohms law. Its a basic electrical formula and will help you get this right.
Posted on Dec 26, 2007
  • 10 Answers
SOURCE: oil baseboard heat v electric baseboard heat.
Two 8 ft baseboards will heat this basement fine. You should eliminate any sources of flooding before you invest in refinished your basement.
Posted on Mar 16, 2009
  • 22 Answers
SOURCE: electric baseboard heater
this is a tough call but with 2000 watts in each room there should be more than enough heat .the rooms should maintain a average temp of 73 to 78 degrees temp without weatherazation and that is of course there is no drafts coming from any windows or near a front or back door that opens and closes alot . Basiclly you have it covered but definatley get the house winterize/insulated real good.I would keep 1 or 2 space heaters on hand just incase the person in house feels there cold just to cover yourself ,usually it the female complaining its cold if its not warm enough but there have been some males that need that temp to be 80 degrees all the time.good luck but im sure it will be ok!!
Posted on Sep 29, 2009
Testimonial: "very thought out and helpful.... just hope he is right, lol"
How do wall arts enhance your house's beauty?
Various wall arts can be used to make our houses more beautiful and attractive.Temporary room walls can be used to make partitions in our rooms. Using wall arts can be used to make your house look attractive according to your taste and personality.It can be an inspirational and motivational one.
May 02, 2017 | Heating & Cooling
What is the comparison of heating 1500 cu. ft. to 1000 sq. ft.?
a cubic foot is a 12inch by 12inch square by 12inch depth its like stacking 1500 little sq. boxes in a room or two.a 12ft by12ft room with 8ft walls would hold 1152 cubic feet or little boxes.so in comparison 1500cu ft is little more than one room,1000sqft is a small house.
Feb 03, 2015 | Leisure HOMEPRIDE Electric Fireplace...
What size central a/c,heater do I need to cool-heat a 2400 sq/ft house in west Texas
You haven't included enough information to give you an accurate number. Things to consider are:
- R value of attic and wall insulation
-cubic footage of the living area
-are the windows single double or triple paned... low E ?
-how many hours of direct sun?
-how many points of return air do you have?
Its better to over size your system than to undersize.
One more thing to consider.... heat rises, cooled air falls and if you want to run your ducting under the house? insulate the crawlspace walls.
Nov 19, 2013 | Heating & Cooling
What size room will the rtnnai RHFE-551FT heat
Judging by it's Btu Output, it should comfortably handle heating up to 300 square feet. This is based on the room having average insulation and average energy efficient measures in place. All houses are different, so what may work outstandingly in one person's home, may only do an average job in another''s.
Rinnia makes a good product, but it's longevity is based on how wall the consumer maintains the product. No heater is maintenance free. They all require at minimum, of annual service. Usually, in the Fall, prior to the heating season.
Hope this helped you. Please let me know. Cheers!
Jun 16, 2011 | Rinnai RHFE-556WTA Direct Vent Heater NG...
I JUST WANT TO REMOVE THE OVEN DOOR TO CLEAN THE INTERIOR SURFACE OF THE DOOR GLASS
If you mean between the inner and outer panes of glass; you will regret it. It's likely that both are mounted with a fragile heat-proof mineral (non-asbestos) gasket material that may crumble once the panes expose it.
Apr 22, 2011 | Frigidaire 30 in. Electric Gallery Pro...
Is the back window a double pain or single and how thick is it?
if its a motor vehicle it will be a single pane of safety glass,if it has a built in heated rear window some models use two panes moulded together ,depends on who makes the glass
Mar 10, 2010 | 1988 Chevrolet K1500
Connection between harmon receiver and A-bus in wall speakers...
There is a CAT5/RJ45 A-Bus interface on the back of the HK AVR 435. That needs to connect to your A-BUS "hub". HK has two hub products: ABH-4000 and ABH-4 (older). Then CAT5 cable can be run from this hub to Wall-installed room-specific controls. HK has the AB-2 product, but any ABus compatible wall control will work. From the wall control, you wire regular audio cable to the speakers. So, some of the questions/issues to solve are: where do the existing wires go that are connected to the in-wall speakers? Typically that location is where to place your in-wall volume and source controls. Then the CAT5 gets wired from those controls back to the hub. And all that's required is a single CAT5 from the AVR to the Hub.
Apr 04, 2009 | Audio Players & Recorders
Back up electric heater required.
A bit late for you probably Steve, but other browsers might be interested...
Micathermics are faster to warm up the room than other resistive heaters, but otherwise they're no more efficient - so it depends whether you feel that the fast warm up is worth the extra money that the micathermic would cost.
If your ceiling is well insulated (including over the wall plates at the top of the internal walls) then the large windows are very likely the reason that your underfloor heating can't get the heat high enough. Have you considered double glazing? 3M have a very cheap, disposable window insulation kit that you could put on for a cold season to see if it's worth putting in some more permanent double glazing (and in fact that kit will probably last 2 or 3 cold seasons if you just leave it up).
The heater power (kW) required to get that extra 2 degC depends on how well the room is insulated. Your best bet would be to find out how much kW your underfloor heating is putting out and how much degC it is warming up the room, then keep the same proportions to work out how much extra kW you need.
Jan 13, 2009 | Soleus HGW-203 Micathermic Infra-Red...
I am suffering terribly with condensation on my windows; we have central heating and keep the rooms heated regularly before we go to bed. The windows are clear on going to bed but in the morning they are...
Heavy condensation on windows only means one thing single pane glass and very cold outside. Not much you can do on the cheap maybe put plastic on the outside of glass. Or install storm windows would be the best.
Dec 01, 2008 | Heating & Cooling
Heating & Cooling Logo
139 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
