Question about Fahrenheat Built-In Baseboard Thermostat Heater
How to wire fahrenheat hydro baseboard with marley t1 & T2
hotuna
  • 288 Answers
SOURCE: Electric baseboard heater
You need a meter, it will be hard without this! If you have 220v in the wall, then think of it like this; each wire is 120v. Test to each other, you get 220v. The thermostat is a double pole, you said. So think of it like this, its an adjustable temperature controlled switch that lets electricity through at the temp. you set it at. If you have 120v from one wire connected to one end of the element, and the other 120v connected to the other end of the element, then it will work. DO NOT CONNECT THE 120V TOGETHER. IT MUST GO THROUGH THE ELEMENT FIRST. The thermostat should be between the power from the wall and the element, to control the temperature.
Posted on Jan 09, 2008
hotuna
  • 288 Answers
SOURCE: How do I wire up a F2544 baseboard heater with a single pole themostat
It sounds like you are not getting the correct voltage for the heating element. If you wired a single pole thermostat, and its a 220v unit, then it will not get hot enough, like you are saying. If its a 220 heater, you need a 2p2t thermostat. The parts supplier will know what this means.
Posted on Mar 20, 2008
wbwill
  • 68 Answers
SOURCE: Baseboard heater connect
A longer explanation is needed on these questions or I am not finding the whole question. I volunteer on allexperts.com and it is much clearer what help someone needs. Write to me at wbwill@sbcglobal.net or through allexperts.com and I will help you wire this. A baseboard heater should not be that complicated to wire up.
It should wire up like a 240 volt dryer, with the proper wire size and proper double pole breaker.
The heater will have the amperage and voltage rating on the unit, take that information and then measure how far from the breaker box you will be, to a hardware store. They can tell you and sell you the wire and breaker. aLSO TELL THEM WHAT BRAND BREAKER BOX YOU HAVE, it is written on the box somewhere.
The wire size will determined by the amps and the distance, the breaker will be sized to protect the wire, there will be either 2 hots and a neutral, or 2 hots and a neutral and a ground, older 240 devices were all three wire, now days most are four, the hardware store can tell you. You might have a red, black and white and green wire. Red would be one hot lead, black another hot, white neutral, green ground. The device will have either have the wires in a connection box or lugs labeled for hot, hot, neutral and ground. One way you wire nut the wire to each, the other you place under the lugs, at the breaker the hots are both ran through their own breaker, called a double breaker, the white will go on the neutral buss, and the green ground will go to the ground bar.
Hope this helps, it should not be a difficult job. or write me at wbwill@sbcglobal.net
Posted on Nov 15, 2008
SOURCE: Fahrenheat electric baseboard heaters are not safe for children
A few companies sell child-proof covers that prevent little fingers and small objects from getting into the radiators. Try searching Child-safe baseboard heater covers in a google search or PexSupply.com.... we use them in daycare centers.
Posted on Jan 30, 2009
  • 10865 Answers
SOURCE: I'm replacing a non-hydronic electric baseboard
Hello. The red and the black are the hot wires. Therefore, connect one of your conductors to the red and the other conductor to the black. Use wirenuts. The bare ground wire should be solidly attached to the new unit's green wire using a wire nut.
Regards, Joe
PS: please rate my answer. Thank you.
Posted on Jan 06, 2010
Testimonial: "Excellent Reponse"
Hello Fixya Guru ! I am in the process of installing several Marley PLF series 2000 watt/ 240 volt electric "Hydronic" baseboard heaters. I am using 10/3 bx with a 30amp breaker. To my...
You are correct that these heaters use a two-wire 240 volt supply, and the neutral is not needed.
2000 watts = 240 volt x Amps ==> Amps = 8.3 amps
30 amps x .8 safety factor = 24 amps
24 amps / 8.3 amps = 2.9 heaters per 30 amp breaker (3 heaters should be okay)
More info, pls let me know.
Charlie
P.S. Where does the 2880-watt number come from ?
P.P.S. There has to be a ground bus-bar in the panel -- if it's a main panel (not a sub-panel) the ground buss and the neutral buss are connected in the panel. Could you clarify what you have in the panel.
Jan 11, 2011 | Fahrenheat Electric Convector Baseboard...
Looking for a wiring diagram for a fahrenhear model FTA2a
I found this VERY helpful step-by-step pictorial direct from Marley (manufacturers of the heater and thermostat).
Worked like a charm for me.
www.marleymeh.com/en/assets/pdf/F2500wiring.pdf
Nov 21, 2010 | Fahrenheat Built-In Baseboard Thermostat...
Electric Hydronic Baseboard Heater, 240 Volt: WHEN I TURNED ON MY ELECTRIC BASEBOARD HEATER THER...
My PLF504 detonated this morning (11-25-2010). It worked fine for two years then BANG. Room was lit by flame coming from center (left to right) of unit. I wrote Marley asking them to honor the 10 year heater element warranty. Also, no burnt wires at thermostat connection, no dust bunnies on the fins. Source of fire was the fluid filled encapsulated heater core. Thank God, circuit breaker tripped and wall was tiled.
May 17, 2010 | Fahrenheat Electric Hydronic Baseboard...
We are enclosing a porch and would like to hard wire Marley baseboard heat. Found that Marley is going out of business and have been advised to buy P C. Do you have any thoughts on this. WE thought that...
that is up to u only problem is after they go out of business u wont be able to get parts so dont be surprised if u have to replace it after a while good point is most parts are universal and u can get some parts for it so i think u will be fine
Feb 23, 2010 | Fahrenheat Electric Hydronic Baseboard...
I can not figure out the wiring for my thermostat. this wiring diagram is worthless to me. I have a fahrenheat single pole thermostat model fta1a. Where do the wires from the breaker box go? It almost seem...
do not purchase Marley Fahrenheat products as they refuse to provide useful installation directions to the home owner. return product to store for a refund in protest of their totally bogus installation directions total junk thanks for wasting my time. I will be sure to smash it before I return it to the store to show my gratitude for the waste of a time web site!!!!!!!!!!
Dec 21, 2009 | Fahrenheat Built-In Baseboard Thermostat...
Need wiring diagram for 3 phase electric motor
motor leads on a three phase are T1, T2, T3, T4, T5, T6, T7, T8, T9. for high voltage [480] L1 to T1, L2 to T2, L3 to T3, connect together and tape - T4-T7, T5-T8, T6-T9. For LOW voltage [240] L1 to T1 & T7 & tape, L2 to T2-T8 & tape, L3 to T3 & T9 & tape. T4-T5-T6 together and tape.
Oct 20, 2009 | Saws
Parts for Fahrenheat lfp6152e
Contact supplier Marley @ 1-800-642-4328
Dec 29, 2008 | Fahrenheat PHH15002 Oil Filled Baseboard...
Marley electric 3ft. basebord ,wiring w/thermostat
If your baseboard heater is rated at 220 VAC and you have wired it to a 120 VAC source then the heater will only produce about 1/4 of its rated output wattage. So, if you have a 2000 W / 240 V heater it will only produce about 500 W at 120 V. You may want to have an experienced technician wire it for you if you are not sure what you are doing. Please be careful and smart when dealing with electricity!!
Nov 24, 2008 | Fahrenheat Electric Convector Baseboard...
Fahrenheat Built-In Baseboard Thermostat Heater Logo
134 people viewed this question
Top Fahrenheat Heating & Cooling Experts
butch welch
paulcarew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
