Question about Tomtom GO 920T
Tomtom go 920 circuit board
No power
4 Suggested Answers
homemender
  • 158 Answers
SOURCE: Tomtom Go 920 failure
The power light only shows that power is getting to the TomTom. It proves nothing else and doesn't even confirm that the internal battery is charging. If you have tried a reset ( by inserting a paper clip into the reset hole at base of your TomTom and that hasn't worked then it's likely you have blown internal components . Usually caused by faulty charger. I hope the reset works ... good luck
Posted on Nov 15, 2008
SOURCE: I broke off the power connector inside my Tomtom
I finally managed to pull back the rear cover by inserting a thin piece of metal at the top of the rear cover. It snapped off by pulling it backwards and then downwards. And I soldered the connector back on. I only had to solder the 4 feet of the small metal shield, the contacts are just pressing on the circuit board.
Posted on Mar 31, 2009
  • 171 Answers
SOURCE: Current time on TomTom 920
Turn on your tt. On the map screen tap the screen then tap the wrench (change preferances. Tap the forward arrow until you come to set time. Hope this helps.
Posted on May 24, 2009
Hi my tomtom 920 keeps shutting down .when programing it has been set not to shut down and allways does it just when you want it most. can you help. regards roger.
It has to be one of two things: bad battery or your charging circuit does not work correctly to charge the battery. We see this all the time. www.nabilselectronics.com
Sep 29, 2010 | Tomtom GO 920 GPS Receiver
Display flickers and goes dark on my tomtom go 920
We've repaired it dozens of times and it's usually caused by a defective screen (backlight power circuit broken). Screen is easy to replace, part is available on ebay. Free DIY guide is here: http://www.portatronics.com/guide. Third party repair Service is here: http://www.portatronics.com
Apr 25, 2010 | Tomtom GO 920 GPS Receiver
I have a tomtom 920. It is not able to aquire a
Are you INDOORS? GPS do not work indoors. You need to be OUTSIDE.
Also, install TomTom Home in your computer and plug your tomtom to your computer via a USB cable. Update your TomTom and try again
Mar 19, 2010 | Tomtom GO 920 GPS Receiver
I have a tomtom go 920 my sreen turns sometimes black after it flickers but it stil tells me where to go ! Is there something loose insite ?
The TomTom has a power-saving scheme. If enabled, the screen may be dimmed or turned off if you are travelling straight ahead and no left or right turns are imminent. It will come back when instructions are given.
Check the preferences and look for battery power-saving.
Jan 20, 2010 | Tomtom GO 920 GPS Receiver
How do I open the TOM TOM GO920 to change the battery?
You need to have a special tools!
Torx T7 and small flat head !
On the back of unit, using torx unscrew 2 screws!
Using small flat head screwdriver pick the front panel!
Carefully disconnect cables on the back of the display!
Unscrew circuit board!!!
Carefully disconnect speaker wire, and battery wire!!!!
Battery is glued to circuit board, carefully pill it off!!!!!!!
Place new battery on the same spot, and revert all the directions!!!!
Good Luck!!!!!!
Roman
Aug 12, 2009 | Tomtom GO 920 GPS Receiver
Tomtom only charges on fast charger base. Why?
if it is not charging in the car then the socket in the car is dead, blown fuse or defective socket..
Aug 09, 2009 | Tomtom GO 920 GPS Receiver
Tom tom 920T need to swop battery ?
Good Luck!!!!!!
Roman
Aug 07, 2009 | Tomtom GO 920 GPS Receiver
May 22, 2009 | Tomtom GO 920 GPS Receiver
Tomtom 920 bluetooth disabled
repair both ...start fresh from start.....do a hard restart on the TomTom...this is located on the last menu of your tomtom...Factory reset...it will erase recent destinations and favorites....but it usually clears the tomtom....Now try to repair both the phone and the tomtom
May 10, 2009 | Tomtom GO 920 GPS Receiver
Oct 20, 2008 | Tomtom GO 920 GPS Receiver
Tomtom GO 920T Logo
Top Tomtom GPS Experts
k24674
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
