Question about Hunter Vaulted Ceiling Mount - Antique Brass Fan
Hunter ceiling fan
I have 3 wires for a ceiling, 2 white and 1 black. I have a single switch on one wide of the room for the light and a double switch on another side of the room - 1 for the light and 1 for the fan control. I have 3 wires coming out of the fan - 1 blue, 1 white and one black. I have 5 wires coming out of the receiver - 1 blue, 1 black, 1 red, and 2 whites. I understand to connect the blue wire out of the receiver to the blue wire out of the fan, the white wire out of the receiver to the white wire out of the and the black wire our of the receiver to the black wire out of the. Then connect the red wire out of the receiver to the black wire out of the ceiling. I have one white wire left coming out of the receiver. Do I connec t it to both of the white wires coming out of the ceiling and if I do, how. By the way, one white wire coming out of the receiver says ACINNand one says COM. Which one goes into the receiver and which one goes to the ceiling?
  • 34 Answers
SOURCE: lost the instructions. Where does the blue wire go
Posted on Jan 24, 2010
  • 351 Answers
SOURCE: ceiling fan and light wiring, 2 switches, 1 romexHunt
If you have only one black and one white in the ceiling to connect the fan / light to , then you have only one switch for this ceiling box. The fan / light will connect the white wires together and then the two colored wires on the fan to the black ceiling wire. In order to use separate switches for the fan and the lighht a 4 wire cable must go from the switches to the light so you have a red and black wire to switch the two separately .
Posted on May 04, 2010
  • 834 Answers
SOURCE: I purchased a ceiling fan
That is kinda confusing, but it sounds like the blue wire for the light kit should also be connected together with the red supply wire for the fan motor from the ceiling wires, and not the capped black wire. That is if the two wires to the fan motor are the white and red wires from the ceiling. Normally the white wire is a neutral wire and the black is the field wire and they both are alternating current "hot" wires, and the green wires are grounded to earth ground only.
Let me know if I understood that right about the wires from the ceiling, and let me know if you require any further assistance.
See if this diagram is correct
Posted on Sep 27, 2010
  • 403 Answers
SOURCE: I have a ceiling fan
so what is your question
Posted on Mar 25, 2011
SOURCE: Wiring Hunter ceiling fan into old house. My house
Your copper, green wire are the ground. I beleave that the white is the power, and the black is your neg. to make sure i would use a wire tester to determen the power. From there white goes to white, black to black, and green to copper. I am not sure on the white/black wire it maybe another power. Look at your instalation manual it should tell you.
Hope this can help.
Posted on Mar 20, 2012
I removed a Hunter ceiling fan with a light that was installed about 30-40 years ago. There are 2 white wires and one black wire coming out of the ceiling. There is one single switch on one side of the...
The black wire is most likely your neutral. The wall plate should have one light switch and a fan control. If you connect an incandescent or halogen bulb to one of the white wires and the black and you flick the light switch or turn on the fan switch the light should light, you can then determine which white wire is doing what.
Mar 30, 2017 | Dryers
Box in ceiling has black wire and white wire & the ceiling fan has white wire, black wire and red wire.
BEFORE YOU PERFORM ANY CONNECTIONS BE SURE THAT THE CORRECT CIRCUIT BREAKER FOR THE BOX HAS BEEN TURNED OFF! You must check for voltage between the white and black wires at the ceiling box with each of your two wall switches toggled up or down ONE AT A TIME!
The green wire in the ceiling box (or bare copper wire) is your ground wire and should be connected to the green wire of the fan, and also should be mechanically connected to the electrical box by a screw or clip. If your system was wired correctly you should find that it already is connected to the box.
The white wire in the ceiling box is your neutral wire, so any and all white wires from the fan should be connected to it. You may have one for the fan motor and one for the light kit if there are two separate whites from the fan. Again, they may already be connected together in the fan/light assembly.
The black wire in the ceiling box is switched on and off from either of the two switches in the room, which I assume are located near two different doors to the room. These are called "three-way switches". They are not marked "on" and "off" on the toggle like any single-light switches in your home. That is why you must check for power at the ceiling box with the switches in each position one at a time to make sure that the circuit is de-energized.
Now for the connections:
You will need to connect both the red and black wires from the fan to the black wire from the electrical box. The black wire in your ceiling box is your "hot" wire and will provide power to both the fan motor (black wire) and to the light through the red wire--(sometimes this wire is blue, for others who are following this post).
With this arrangement, your fan and light will only operate with one or the other of your three-way switches completing the circuit from your breaker box. You will have to use the pull chains on the fan to control the fan and lights. So you will probably want to leave the light "pulled on" so that you can control the room lighting from either of your three-way switches, and operate your fan speeds from the pull chain. However, if you want your fan only on at night you will have to "pull off" the fan's light switch.
You may find all this switch flipping and chain pulling an inconvenience. If so, hire an electrician to install wiring so that the ceiling box will be "hot" all the time to the fan's black wire and the fan will therefore be operated by the pull chain only, and the light kit will be controlled by either of the three way switches, via the fan's red (or blue) wire.
One other caveat before you begin: you must make sure that the ceiling box is rated for and mounted sturdily so that it will support the weight of the fan and light kit. Many ceiling boxes are designed and mounted to support only a light-weight fixture. You don't want your fan to come crashing down from the ceiling!
Oct 15, 2012 | Hunter 52" Ceiling Fan With Light And...
Light switch wiring
The code is maximum 12 boxes per circuit breaker.
You can connect a 12-2 NM W/G cable to one of the outlets. Black-to-black and white-to-white and ground-to-ground. Black is hot, white is neutral, and ground is ground. And bring that cable into a hollow-wall box you install 50" high on the wall. Then run the 12-2 cable up to your light fixture.
You can also replace one of the outlets with a combo switch-outlet. The run singe 12-2 cable up to light.
This wiring diagram shows half way down how-to-wire-switches page.
Outlets have wide blade on neutral side, and narrow blade on hot side.
The black hot wires from old outlet connect to side of combo device with narrow blade.
The white neutrals from old outlet, and new wire going to switch, all connect to silver screw on wide-blade side of new combo device.
The black wire going to new light connects to screw next to switch located on wide-blade side of device.
Aug 28, 2012 | Electrical Supplies
I have a single pole switch that currently controls a bedroom outlet. i am installing a fan and light in the bedroom. i have a new triple switch that i want to control the existing outlet, the fan and the...
Wiring is not fully described: Location of hot wire and neutral wire from breaker box are unknown.
If Hot wire arrives in ceiling box first, the switch box will not have white neutral wires that are twisted together and covered with wire nut. Neutrals will be in ceiling box.
What is known: You are replacing single pole switch attached to one 14-2 wire going to light.
You are replacing light with a fan-light and replacing switch with a 3-pole TM8111 switch.
You have replaced 14-2 wire with 12-3 wire.
TM8111 wiring shows following link:
Fan pull-chain wiring shows following link:
Assume neutrals in ceiling box.
Assume Hot wire in ceiling box: Connect 12-3 black wire to black Hot wire. Connect 12-3 white wire to black wire on light. Connect 12-3 red to red wire on fan.
White neutral from fan and white neutral form light connect to other white neutral wires and covered with wire nut.
Wiring at switch:
Black Hot wire from ceiling box connects to A COM terminal.
White wire to ceiling light connects to A SP2
Red wire to fan connects to A SP1
Jun 21, 2011 | Pass & Seymour Legrand TM8111 Three Single...
I am attempting to install my Hunter 21095 Westcott fan and am unsure of the wiring. Power is at the ceiling fixture which in turn feeds the next rooms fixture and the switch wire is also in the ceiling...
Black is for the fan motor which you connect to black(hot), black/white is for the light which you connect to the switched lead in the ceiling, the white lead from the fan goes to the neutral lead in ceiling, and tjhe green wire is earth ground and goes to the box screw in the ceiling
Jan 20, 2011 | Hunter (25417) Ceiling Fan
I'm using a Leviton 1755 combo 3 switch for a bath light/fan combo and then onto a vanity light. Basics: wires from ceiling light/fan: black, red, white, ground. Wires to vanity light: black, white,...
remove white switch one and connect to incoming white ground--all whites should be connected [hooked] together these are grounds-- switch 1 black from fan ,leave switch 2 red from fan ,switch 3 vanity black
Feb 22, 2010 | Leviton 003-1755-W Three Rocker Switches
Ceiling fan pull chain switch replacement
OK, this is easy, it just seems hard. First off, take all the white wires from the light fixture's clusters, and hook them to the white feed wire. Now take the black side of the cluster of wires, and attach them to one side of the switch. It does not matter which side. The other side, goes to the feed wire that is black or what ever feeds the light. The switch only acts as a valve for one side of the loop. I could explain why some switches have a black and white, but I will leave that alone, so I do not confuse the issue.
Jan 22, 2009 | Solar 2-wire Pull Chain Light Switch For...
Ceiling fan and light wiring, 2 switches, 1 romexHunt
Oct 30, 2008 | Hunter Vaulted Ceiling Mount - Antique...
Ceiling fan wiring
blue would be your earth.
black and white are phase and neutral.
for the wiring in your roof you need to call a local sparky. just ask which is which and connect them appropriately.
Sep 01, 2008 | Hampton Bay 24002 Ceiling Fan
Ok i have a problem. we are add a fan and a light kit t the ceiling. the builder olny put one light in a corner. the light switch is a sing. and we are putting in a duble. we have to run a wire from fan to...
home run and rec wire together with a jumper to one side of each switch. black wire to corner light goes to other side of switch 1, black wire of fan goes to other side of switch 2
Aug 09, 2008 | Hunter Ceiling Fan Light Switch Control
Dryers Logo
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
