Question about Zebra Office Equipment & Supplies
Need to center barcode on barbel label
We have a Zebra TLP 2824 Plus that prints barbell/butterfly labels with the black stripe on them. It prints all the labels we need, however, the first few (3 to sometimes half of the labels) come out completely off center and un-scannable. We usually have to print our orders twice just to get enough usable labels (meaning labels with barcodes that will scan). How do we adjust this label printer so that all the barcodes are centered properly on every label printed (not just the last half of the order)? We have tried re-calibrating and updating the driver which has not worked.
3 Suggested Answers
bartech9
  • 155 Answers
SOURCE: Labels not printing properly
El problema es que la impresora tiene diferentes parametros de impresion, de oscuridad o velocidad. Ajustalos para que sean iguales en el print server como en workstation. The problem is that the printer has different printing parameters, or speed or darkness. Adjust to be equal in the print server as workstation.
Posted on Jun 04, 2009
  • 2976 Answers
SOURCE: MY ZEBRA TLP 2824 PRINTS IN THE MIDDLE OF MY LABELS.
Don't shoot it, they're too hard to cook.
Make sure your program is set for the label size you're using. Also, there is a photo eye under the paper path that picks up the labels. It will, in time come out of adjustment. It can be cleaned with a swab and alcohol.
Posted on Sep 01, 2009
Zebra TLP 2824 Plus does not print barbell labels
You need to run win7 in XP mode. I am not sure the Zebra software will run in 64bit.
Feb 27, 2017 | Zebra Office Equipment & Supplies
Just one of the double tags is printed on
I assume by double tags you mean 2 labels across the roll.
You need to tell your software that the roll is 2 across.
If using the software that comes with the printer, Zebra designer.
Set your label width to twice the single label and copy the barcode so that you have 2 across the label, then print
Feb 10, 2010 | Zebra Eltron TLP 2844 Thermal Label...
Sep 01, 2009 | Zebra TLP 2824 Printer
Send a .txt file (zpl language to COM1) to theTLP 2824-Z.
Help!!! I can not print barcode with DOS-command "copy barcode.txt com1". DOS Version is 6.1.7600. The printer zebra TLP 2844 does not recognize the EPL commands.
j.zh
Jul 28, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Zebra TLP 2824 Print Orientation
check on the driver, unther the advance tab, if some seting is tick.
if cant check the problem, install the driver again.
Feb 03, 2009 | Zebra TLP 2824 Printer
Cant print on butterfly label with Zebra TLP 2844 printer
This is a problem of label sensing.
You are probably using the Gap sensor on the 2844, unfortunately the shape of the butterfly labels means you are sensing the wide gap between the labels in the centre, so it will not print anything in the apparent gap area on both ends of the label.
What your label or system supplier should have done is supplied you with the same labels but with a 3mm wide black mark on the underside of the label backing paper, centred between the labels. You can then change the printer sensor setting in the driver to Black Mark. You will then be able to print anywhere between the black marks.
Any problems with this contact us directly at Lancer labels Ltd
Nov 28, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Zebra TLP 2824 Printer problem
How are you loading the labels in the printer?
Make sure they are secured underneath the black side guides?
Sep 17, 2008 | Zebra TLP 2824 Printer
ZEBRA TLP 2824 LABEL MAKER PROBLEMS
this happens with me also. it is random. could happen once a day or several for no apparent reason. I am printing thru Terminal Services though.
Jun 24, 2008 | Zebra TLP 2824 Printer
TLP 2824 Sebra
is the printer an EPL or ZPL model? i will need to see a hex dump of what you are sending to the printer to pin point the error but it sounds like a label layout issue.
is the barcode content the same on each label? if the barcode content is changing the barcode will grow and move to the right.
Nov 07, 2007 | Zebra TLP 2824 Printer
Zebra TLP 2824
are you able to give me 2 print dumps? change the printer port to file and post the files content here and I will tell you if it is a config/software issue, it sounds like the software is not setting the label home position correctly(R command)
53 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
