Question about Braun WK200 Cordless Electric Kettle
How to reassemble
How to put the handle assembly back correctly
Same problem ,please help
Posted on Oct 03, 2013
How to stop leak in coffee carafe
Remove plug on top of handle to expose set screw. Remove screw. The top handle assembly will screw off (1/8 turn). There is a silicon gasket inside. Clean everything and put plumber's grease on gasket (optional). Reassemble making sure the handle top part is screwed on snug.
I did not put the set screw back in to make future dis-assembly easier.
Feb 18, 2015 | Mr. Coffee Coffee Makers & Espresso...
How do you put door back onto Electrolux wall oven......Been trying for hours, no success!
Hello paulascor549 - I completely understand that you took the oven door apart to clean it, therefore you must have took the following steps to do so. According from my research you would have to reassemble in reverse order. If you have already tried to do so and it proves to be ineffective, contact a professional to move forward accurately.
Door Removal and Cleaning of Interior Glass
Tools needed: Phillips head screwdriver or small quad bit driver.
A. Open Door remove 2 screws and washers on door lining at door hinge area.
B. Refer to owners guide? With door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner, Windex, bon ami, fantastic, etc
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
Nov 24, 2012 | Electrolux 30" Built-In Single Electric...
I have a moen posi-temp shower valve and it says "up" on 1 side. when it is installed this way the hot is on the wrong side. the hot is hooked to the left side but the handle points to the cold...
you need to pull apart the handle and rotate the cartridge 180 and reassemble and that will put the hot on the left and the cold on the right before you put the screws all back in test it to make sure its correct then reassemble IF THIS HELPED YOU PLEASE VOTE FOR ME AND LEAVE GOOD FEEDBACK
Aug 27, 2011 | Moen & Posi-Temp Single Handle Shower Or...
Rope needs rewound, got tangled up , had to remove the 4 nuts, now need to get in back on wound tight
I assume that you are speaking of a pull start mechanism.
I can not imagine how to put a put pull starter back on "wound tight". Your pulling on the cord tightens a spring which pulls the cord back in. They go back together with the cord fully wound onto the spool.
Usually, I only take these apart to replace the cord. Wind the new cord onto the spool without handle. Reassemble, then pull out on the cord a little when attaching the handle to the cord. This is the only way to get tension onto the spring at the fully retracted position because the catch for the spring is on the machine and the spring itself is on the underside what you are assembling.
If you do not wish to shorten the cord or replace it, then remove the handle, assemble enough to catch the spring, wind one turn tighter then feed rope through hole and reattach handle. Easier said than done.
If your spring is broken, then you will be needing a new one.
:o)
Jun 03, 2011 | Craftsman Garden
We purchased a Radio Flyer Stroll and Go but during assembly the front wheel was put on but was put on 90 degrees the wrong way. We are not able to get the wheel off so we can correct the wheel.
Where you inserted the handle bars into the bearing assembly on the frame there is a fork clamp you had to tighten to secure the handle bars and front fork. Loosen this and you should be able to disassemble the front end. While reassembling be sure the you line up the notches on the fork with the grooves in the bearing assembly and that the handle bars are properly aligned before tightening the fork clamp.
Apr 03, 2011 | Cycling
Disassembled handle and initial pieces under handle to find leak source. Single handle shower assembly. reassembled. Cold water only, no hot water. What did I not assemble correctly?
Take handle back off and see if it has a dial that can be removed and repostioned. take off and move it about 1/4 turn counter clockwise and reinstalled and try to see if mixture is correct.
May 18, 2010 | Kohler K-T10335-4-CP Lyntier Rite-temp...
I need to reassemble my rainbow e series electrified hose handle
Yes, it is a ground wire. When you put it back together, make sure that the two halves of the hose handle are holding the wire up against the metal. I just had one apart the other day for the first time and if I recall correctly, the wire goes near the center for reassembly. Hope this helps!
Mar 15, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Where is schematics online to replace lower hose assembly part
There is no schematic that I am aware of. I can tell you that from experience that this repair is very difficult. Basicaly the upper and lower handle unscrew along with the tank base, the hood comes off. the lower handle will split but not comes completely apart to remove the hose section. When reassembling, be sure to put the back hose gasket in the correct position. Look at it (take a picture) prior to repair first.
Feb 02, 2009 | Hoover F6212-900 / F6215-900 SteamVac...
Fan comes on when slight opening pressure is exerted on door handle.
The door frame and seal damage has put the relation of the door latches and the interlock assembly out of adjustment. If after disassembling the door it is found that the latch assembly is good, replacement of the door frame/seal might be all that is required to return the oven to normal operation. After reassembly, it is highly recommended to have the oven's emissions checked at an authorized service center for any leakage around the door seal area. The service center might also need to adjust and set the interlock assembly for correct operation also.
Oct 31, 2007 | Sharp R-1610 Microwave Oven
Braun WK200 Cordless Electric Kettle Logo
163 people viewed this question
Top Braun Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Braun Kitchen Appliances - Other Expert? Answer questions, earn points and help others
