Windows could not detect any wired network card
  • 27,725 Answers
You will have to open up your network connections
click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled
If you are trying to connect through a modem/router you it should have come with a disk then
you might have to connect the usb lead to your modem to get a connection then
click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question / exclamation mark ? ! or a red X right click install drivers
the driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc
click start type cmd press enter you will be in DOS mode
type in ipconfig press enter
you will see all o fyour internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138
Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to
press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabledimake sure its enabledPci device arrows key scroll to nstalled.
hope this helps
Posted on Nov 08, 2012
How do I change from wired hookup to wireless? Bob
Instructions
Things You'll Need
Broadband modem
Router compatible with modem
Internal or external wireless network adapter
Phillips screwdriver
Suggest Edits
  1. Prepare the Network
  • Purchase and setup a wireless broadband router by interfacing it with your wired computer. Choose a router that is compatible with your broadband modem and that supports the wireless network type you desire.
  • Enable WPA or WPA-2 security, and change your router's default password. Give your SSID or wireless network a memorable name.
  • Connect your modem to the WAN (wide area network) port on your router.
  1. Install an Internal Card
  • Purchase a wireless network card that is compatible with the router you purchased and with your computer. For example, if you bought a 802.11 b/g router, do not purchase an 802.11 n adapter.
  • Shut down your computer. Remove all cables and peripheral devices.
  • Remove the left side panel while facing the front of the case. You may need to remove screws or to manipulate latches and notches. Consult your case or computer manufacturer's documentation if you are unsure of how to remove the panel.
  • Clip the metal part of the anti-static wrist bracelet to a metal object, and ******** the bracelet.
  • Locate an available PCI or PCI-Express slot. Unscrew the screw that secures the slot cover that corresponds with the slot, then remove the slot cover.
  • Line up the wireless adapter's pins with the slot. Insert the card until it clicks into place. Do not force the card into the slot, or you may damage the card's connectors. If you feel resistance, remove the card, line up the card with the slot again, and reinsert.
  • Secure the card with the slot cover screw. Reattach the side panel, and replace any screws you removed earlier.
  • Reinsert all cables, and plug in all peripherals. Boot the computer.
  • Allow Windows the opportunity to detect the card. It should automatically install the drivers for the card. If you have updated drivers, insert the disk and install according to on-screen instructions.
  1. Install an External Card
  • Boot up your computer.
  • Insert your external wireless adapter into the appropriate slot. For example, if you purchased a USB slot, insert it into a USB port.
  • Complete Setup
  • Double-click the network icon in the task bar.
  • Highlight your wireless network. Windows will display the name you entered when setting up your router
  • Click the "Connect" button.
  • Enter and verify the security key you created when setting up the router. Click on "Connect."
If you have further query then try to let me know. Thanks for using FixYa.
Aug 27, 2011 | Cisco Linksys Wirelessn Router Black...
Getting a no network adapter detected message after a nearby lightning strike. No Network folder listed under device manage either. Windows ex sp2
this network cards are the most commun problme on computer if the card is not detected on device manager remplace it
they cost about 10 to 15 dlls
May 04, 2010 | Dell Ethernet Card Network Adapter
PC Windows xp wont detect networks: PCI 802.11 WN5301A
hi, try to press the register/discover button on your router so as to make your computer able to detect the network or get the latest driver update for your wifi dongle/card
Jan 13, 2010 | Computers & Internet
Wireless card not detecting!!!!
I had simalar problems where I could not detect my wireless network even though I could get on the internet I could not see the other computer on my network. I finally after trying everyone else's advice which did not work, found a program called Network Magic. You can purchase it from www.purenetworks.com for $30.00. It took care of all of my network problems and even shows a nice map of how my network is setup and what computers are logged onto the network and even what software like Windows Xp or Windows Vista is on that computer. It will even generate daily logs if you want to show any problems with the network.
Mar 19, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
Cant get Wireless card to connect to netopia wireless router
There are some things you might try.
The Belkin card will come with third party software you can disable this utility by right clicking on the icon in the Taskbar and choosing "Use Windows Zero Configuration".
Then you will need to go into Control Panel >> Administrative Tools >> Services >> Wireless Zero Configuration >> Right click and check that the service is starting automatically >> click on Start >> Apply - that should then detect your wireless network and the internet.
Feb 25, 2009 | Netopia 2247NWG-VGx Wireless Router...
Wireless problem
I'm Guessing your using Ubuntu 7.04... Due to a bug in the native driver shipped with Ubuntu, the wireless card on this laptop is detected and installed but you cannot find any wireless networks. Here’s how to fix it.
* Let’s disable the native Ubuntu driver. Type this in a terminal:
gksu gedit /etc/modprobe.d/blacklist
and insert at the very end of the file:
# buggy broadcom wireless driver
blacklist bcm43xx
* Next, do this in a terminal:
sudo rmmod bcm43xx
* Now, let’s download and install the windows driver for the wireless card. You have to download it from the Dell support website. Click here to download it.
Or you can use the direct link to the executable:
http://ftp.us.dell.com/network/R140747.EXE
Since it’s a windows self-extracting executable, you need wine to use it:
sudo apt-get install wine
then:
wine <path_to_R140747.EXE>
Replace <path_to_R140747.EXE> with the actual physical path to the file you downloaded from the Dell support website. Follow the instructions and extract the files to a folder of your choice. Alternatively, you could extract the files on a windows machine and copy them over to your ubuntu system.
* Now, let’s install ndiswrapper. We need it to load the windows driver.
sudo aptitude install ndisgtk ndiswrapper-common ndiswrapper-utils-1.9
* Let’s install the windows driver:
sudo ndiswrapper -i <location_of_bcmwl5.inf_file>
Replace <location_of_bcmwl5.inf_file> with the path to the bcmwl5.inf file you extracted earlier.
* Let’s make sure the driver is installed:
sudo ndiswrapper -l
You should get something like this:
bcmwl5 : driver installed
device (14E4:4311) present (alternate driver: bcm43xx)
* Now we need to set up ndiswrapper to load our new driver automatically:
sudo gedit /etc/modules
and add a new line that says:
ndiswrapper
That’s it, restart your laptop. During the restart, the wiFI LED should light up. If it doesn’t, try the Fn + F2 key combination. After the reboot, configure your network settings:
System -> Administration -> Networking
Enable the wireless connection and tinker with the connection settings if you need to. You may have to disable the wired connection because wireless and wired connections may not work simultaneously - your mileage may vary in this regard.
Note:
It seems Network Manager prevents the card from connecting to detected wireless networks. I advise you to remove it if you can detect wireless networks but cannot connect to them. To do this, type the following in a terminal:
sudo apt-get –purge remove network-manager network-manager-gnome
Alternatively, you can open Synaptic and remove these two packages.
* Summary:
1.) Install ndiswrapper
sudo apt-get install ndisgtk ndiswrapper-common ndiswrapper-utils-1.9
2.) Install the windows wireless driver
Remember to replace <location_of_bcmwl5.inf_file> with the actual path to the location of the bcmwl5.inf file
3,) Make sure the card has been detected and installed
ndiswrapper -l
4.) Disable the native ubuntu wireless driver
Insert at the very end of the file:
blacklist bcm43xx
5.) Remove Network Manager if it gives you problems
Reboot
You wireless card should be working flawlessly now.
I Hope this helps :)
Cheers
Jasonjohn89
Jan 31, 2009 | Computers & Internet
Network connection problem
you need the drivers for the nic. you can get them from support.dell.com by typing in the service tag. obviously, you'll need a computer with a working network connection. copy them over on cd or usb drive to the laptop.
Jan 31, 2009 | Dell Latitude D800 Notebook
Dell 4700 Computer Integrated NIC Problem
Check for the pins inside the integrated NIC to check if the pins are bent / disfigured. Does not look like the additional card is making any different, looks more like a moving NIC cable is makin the difference.
Lemme know if this helped!
Dec 13, 2008 | Dell Ethernet Card Network Adapter
Not detecting any wireless networks
You have not mentioned having a wireless router or access point to serve as the hub on an infrastructure network. I you have a router please let me know -- the instructions for the solution changes.
The following is an article to create an ad hoc network between wireless cards without a wireless access point or a router. If you ignore the steps about connecting to the internet with a wired connection and the internet sharing instructions. This will allow your machines with wireless adapters to communicate with each other (assuming the operate on a common band). The article goes on to indicate one machine with a wired connection can act as the "router" for the other two when it is on to allow them share internet access with the wired machine (the wired machine also needs a wireless card for this to work).
Ad-hoc networking access point
Jan 03, 2008 | D-Link AirPlus G DWL-G510 802.11g/b...
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
