Question about Insignia IS-LCDTV32 32 in. Television
Whenever a cell phone rings near my Insignia NS-LCD32 the sound goes away and the picture gets static-y. This did not happen when I was at my old apartment...it just started happening when I moved into my new house in August. I have had this tv for a little over a year. Is this something that can be fixed or should I look into finding a new tv??
    Novelist:
    Scholar:
  • 67 Answers
This is a common problem for a lot of electronics these days: unwanted interference from a communications device. It is usually caused by a lack of proper shielding inside of the unit to absorb and redirect stray electromagnetic signals. But If it has started since you moved, then I suggest checking the outlets as a start.
Is the outlet 2 or 3-prong? If it is 2 prong, then that is immediately the problem. The electrical outlets should be 3-prong, with the round hole being the ground. If the wiring in the building is old 2 wire, but the outlet is 3-prong, the outlet's ground hole is not hooked up to anything, therefore, cannot carry the interference away from the TV.
There is a possibility that the wiring may be reversed, as well, which does cause all kinds of problems.
You can purchase an outlet checker from any hardware store, and they are always a great thing to have in any case. Check every unknown outlet for problems, and it may save your equipment, and you, from damage/death in the future.
If your outlets are the culprit, then a GFI (ground fault interrupter) outlet can be safely installed, and usually works fine (it compares the neutral and ground current, and makes a connection in the process).
Give this a shot. Post your findings if you would like.
Posted on Jan 05, 2009
Where is the location of T CON board on NS LCD32
Cheryl, I will post links to what the T con board looks like so when you remove the rear panel from TV, you will be able to compare and find it easily.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
LCD TV Repair Tutorial Con Board Common Symptoms Solutions How to Replace...
INSIGNIA NS LCD32 Con Board LC320W01 SLA1 6870C 0142B 2L
Amazon com INSIGNIA NS LCD32 CON BOARD CPT 320WF01C SD Electronics
Mar 23, 2016 | Insignia NS-LCD32 LCD TV
Insignia ns-lcd32 has developed a vertical shadow.
Unfortuntly you have a panel that is going out. This is not cost effective to fix.
Apr 11, 2012 | Insignia NS-LCD32 LCD TV
Insignia NS-LCD32
Most likely either the main board (processes all signal) or even an issue with the power board (supplies wrong voltage somewhere).
In either case not cheap.
Mar 23, 2012 | Insignia NS-LCD32 LCD TV
My Insignia NS-LCD32 tv keeps turning off and on repeatedly. Happens when on cable and also on dvd...
I notice that the adapter gets hot when my TV shuts down so when I want to use that particular TV I set it on an ice pack. it stayed on! I got my Insignia TV at Best Buy. not shopping there anymore.
Oct 09, 2009 | Insignia IS-LCDTV32 32 in. Television
No Sound
if you have dvd player then connect its audio out to your tv audio in. if no sound then, it might be that your audio amplifier inside your tv is the culprit. usually this happens when turning the volume fully.
Jun 08, 2009 | Insignia IS-LCDTV32 32 in. Television
Same Insignia problem but still not working
Check if there is back light on or not?
If back light is on means this unit is having problem with panel (deffective.).
If there is no back light change main baord.
Good luck
Dals123
Oct 10, 2008 | Insignia IS-LCDTV32 32 in. Television
Insignia IS-LCDTV32 32 in. Television Logo
61 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
