Question about IBM ThinkPad X40 Notebook
How can i get my computer to run the way it use to
  • 2,878 Answers
Windows tends to slow down with time. That is why so many people reset to original status.
Slow Windows Machine! Sounds like not enough resources such as RAM and CPU. Check Performance in Task-Manager (CTRL-ALT-DELETE). High CPU levels causes hang ups like freezing. Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. In Startup tab, uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate. Consider increasing RAM. Uninstall any extras like those pushy toolbars, and add-ons.
Posted on Nov 08, 2012
If my computer slows way down or stops can I use this vivitar experience image manager
No Nancy the CD image manager doesn't remove the Viruses from your Computer the best way to do this if you have Virus on the Computer is by downloading Malwarebytes on the Computer, Run the Application and Run a Quick scan it would clean the infections. Please find below the Link to Download Malwarebytes:
http://www.filehippo.com/download_malwarebytes_anti_malware/
Download the Latest Version.
Good Luck!!!!
May 13, 2013 | Microsoft Windows 7 Home Premium 64BIT...
I had a btand new 2011 quickbooks running on my computer then after a week it crashed. I can't open it and it gives me many error messages when I try to reinstall it. I have a 64-bit computer that has...
Hi there !
For some reasons computer can crashed because some corrupted, missing files, virus program or faulty driver installed. Faulty installed drivers or multiple drivers installed with the same drivers can crashed your computer. Running on Safe mode will remove mulltiple same drivers in your computer and it will run on fresh install driver when loading to normal mode.
I suggest to run your computer on safe mode.
To run on safe mode, just restart your computer and press F8 to run on safe mode. After going to windows setting, restart your computer again. Check if this solve your problem.
I hope it helps you and thank you for using FixYa!
Jan 09, 2011 | Computers & Internet
I'm trying to sync my files from my old computer
no you can what you have to use is files and setting transfer wizard in windows xp you can start the Files and Settings Transfer Wizard by clicking Start on the computer running Windows XP, pointing to All Programs, Accessories, System Tools, and then clickingFiles and Settings Transfer Wizard. (If both computers are running XP, you can start with either one.)
just select "i want create wizard disk in following drive " and select you external disk drive tha will do the trick...
Apr 11, 2010 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
Computer start, but os doesn't run
This is very simple......... just run an automatic repair for your operating system... This always work
May 18, 2009 | HP Compaq Presario SR2050NX PC Desktop
Computer runs slow
Slow computer can also cause by alot of software install on your system that is using the resources of your computer like the Memory and Processor, so first thing you can do is to remove some unneeded software that you have on your computer and then after that try also running a scan on yuour computer with a good anti virus and anti malware because can also slow your computer down...
May 07, 2009 | Computers & Internet
Computer running on 100% capacity
100% sounds like something bad is running like adware, spyware or a virus possibly.
I would suggest going to Start>Run and type in msconfig. Then go to the startups, and you can uncheck the things you don't need. Things like adobe reader, adobe updates, and such can be turned off.
Second, download and run the following programs, ccleaner, Malware Bytes anti malware, and Super Anti Spyware.
Run the ccleaner and delete all your temp junk, then run scans on both the other programs. You might need to turn off your anti virus program to do this.
Apr 12, 2009 | HP Pavilion a1610n PC Desktop
CPU fan not running?
If the fan isn't running, the computer probably shut itself down because it overheated. Check to make sure the cable going from the fan to the motherboard is securely plugged in. If it is and the fan still doesn't run, you have a faulty fan and need to replace it before you start up your computer again. It's not good to run a computer that hot.
Please rate, thanks!
Mar 18, 2009 | Computers & Internet
Start up
try starting the computer normally, this usually happens if you computers power was cut while booting up, its just a small harmless glitch.  As for the returning back to the prompt try running it with command prompt. when you get to the command prompt, type (chkdsk) and let it run this might also fix any other problems that you are not seeing.
Jan 09, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
IBM ThinkPad X40 Notebook Logo
43 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
