Question about Husqvarna 295cc Back Pack Blower HVH 130BT
My 130bt blower with start an idle fine but wont rev up
  • 1,043 Answers
Adjust the high speed screw on the carb. It is marked with an "H".
Posted on Dec 07, 2016
3 Suggested Answers
slohry
  • 87 Answers
SOURCE: Husqvarna 130BT leaf blower - locked-up
If you stored it with fuel in it, the piston and cylinder may be stuck together. The old fuel turns to a gummy varnish. spray some WD-40 in to the cylinder through the spark plug hole and rock the flywheel back and forth to break it loose. Then flush the fuel system and carburetor. If that isn't the problem, remove the muffler and inspect the piston, rings, and cylinder for vertical scoring, if scoring is present a top end rebuild may be necessary.
Posted on Apr 13, 2009
kel1guy2002
  • 3740 Answers
SOURCE: my 130bt blower stops reving after several
Hi and welcome to FixYa. I am Kelly. The next time it does this... loosen the gas cap a lot momentarily for about 10 seconds then tghten it and attempt a restart. If if starts right away again the gas cap is bad. It is supposed to breathe via a rubber seal in the cap. There are 5 parts in the cap. If it can not breathe the gas tank goes into a vacuum as fuel drains and you will experience fuel starvation.
Also check inside the fuel tank for debris.
See this link http://www.jackssmallengines.com/help.cfm#Home
Click on
Husqvarna Power Equipment
Blowers
130BT (I used the 2001 - 2007) There is also a 2008-2010 choice
and then click on Fuel tank a.s.s.y
I suspect the problem is either going to the the fuel cap or the fuel filter.
Thanks for choosing FixYa,
Kelly
Posted on Nov 10, 2010
I can't start my home lite 26b blower
Mike if the Blower wont start, it's not the High/Low Jets.
They only adjust High RPM running and the Low helps the carb transition from Idle to High rev.
Ethanol gas is a carburetor destroyer... Also, it eats the gas lines .
Jun 27, 2015 | Garden
Carburetor
either carburetor needs cleaning or check the Flame Arrestor on the muffler...they clog and engine can't Rev high
Sep 08, 2013 | Husqvarna 130BT 29.5CC Gas Leaf Blower...
Picture of timing marks on briggs 6.5
Maintenance diagram od Husqvarna 130BT timing gap settings.
Apr 05, 2013 | Husqvarna 295cc Back Pack Blower HVH 130BT
HUSQVARNA 130BT GAS BLOWER STARTS FINE, BUT LOSES POWER WHEN I TRY TO USE????
Sounds like a fuel starvation problem, Strip and clean carb. Avoid using airlines to clean carbs. remove low and high adjustment screws, reset to factory settings. Walbro carbs are generally scew both of them back in all the way and then turn out 2 full turns each anticlockwise.
Mar 02, 2013 | Husqvarna 130bt 130 Bt Gas Powered...
Huskvarana blower 130BT starts but will not stay running
Fueling issue, check primer bulb and fuel line for air leaks, and possible clean and service card.
Dec 27, 2012 | Husqvarna Garden
I've had my 130bt blower for about a year now and in the past week it hasn't been running good at all. Never had a problem until now. when i squeeze the throttle it seems to bog down and die, if i...
It's probably not the Coil; that's the good news. The bad news is it's probably the small screen in the carburetor. So you will need to take the carb. apart again. I'm sending you a Link to my Tip(s) on this problem. The first one is fuel line check, and then you can go to my carb. clean Tip from there.
Good Luck!
Jim
Aug 20, 2011 | Husqvarna 295cc Back Pack Blower HVH 130BT
My 130bt blower stops reving after several minuets. Will start but not rev after running fine for 5-7 minuets?
Click on
Blowers
Kelly
Nov 10, 2010 | Husqvarna 295cc Back Pack Blower HVH 130BT
Husqvarna 295cc Back Pack Blower HVH 130BT Logo
332 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
