Question about Emerson Televison & Video
I HAVE A EMERSON 20
IT HAS A POWER SORCE BUT WONT TURN ON
    Top Expert:
  • Emerson Master
  • 14,553 Answers
If Emerson parts may be scarce or hard to find--20 inch set may be cheaper to replace than fix. I can offer some suggestions but what is your skill level? l see some who cannot even safely get the set apart.
Posted on Nov 08, 2012
Does insinkerator air switch only have power to both outlets wen its switched on
Yes, generally it does. I presume you are referring to the electrical outlet in which it is plugged into? All the switch does is break the circuit between the "hot" wire and the sorce which, is always hot on one side.
Jun 26, 2014 | Emerson InSinkErator STC-BLK Sink Top...
I HAVE A EMERSON TV AND IT WONT TURN ON, IS THERE A RESET BUTTON?
No reset or circuit breaker on this type of set--if you can safely open it follow the power cord inside to the fuse and check it first.
Nov 07, 2012 | Televison & Video
Ld190em1 wont turn on
Check its main power regulator circuit for any defective component/s
Aug 18, 2012 | Emerson EWF2004 20" TV
Its a emerson tv
Check the power supply for bad caps.
May 26, 2009 | Emerson EWF2004 20" TV
Emerson tv wont turn on
I would check the fuse first
Mar 24, 2009 | Emerson Televison & Video
Digital oster 20 cup capacity rice cooker wont turn on
Rice cookers will only cook if you have enough water in it. If all the water has cooked out, then the cooker will turn off. Remember when you put your rice in the cooker, make sure you level it off. Then add twice as much water so that it will over cover the rice.
Nov 18, 2008 | Oster 3072 20-Cup Rice Cooker
Emerson 20" lcd
bad power board or bad capacitors on the power board service required
May 27, 2008 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
NEW EMERSON 20" LCD STERO TV/DVD- NOT WORKING
the flash was the fuse inside the set blowing it usually takes out one or two diodes in the power supply section but maybeyou got lucky and its only the fuse.
Mar 10, 2008 | Emerson EWL20D6 Television
EMERSON-MODEL#VT911OA-W VERSION-C
If the set will not turn on with the power button on the front of the set, you must then try turning it on with the remote. You must be sure that the remote is working correctly. If the set turns on with the remote, then your power button itself is bad or has cracked loose. This is easily fixed without having to replace the board. If the set does not turn on with a working remote, then something inside the set has failed and it should be serviced by a qualified tech.
Aug 20, 2007 | Emerson EWF2704 TV
Televison & Video Logo
49 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
