Question about Plumbing
Grundfos pump wiring diagrams
Grundfos 32-60/4 a f a bube heating pump. i need to know whether the internal overload is an adjustable type or a fixed set point. there are some white wires under the wiring box and i am not sure whether this is the overload or not as i dont have a booklet with it
SOURCE: Wiring diagram needed RV rooftop coleman
Motor1258,
Thanks for the response, to be more specific, the nine pin connector was damaged, but I was able to connect the wires back to main unit panel. I am ready to hook to the hunter thermostat and do not know which wires to connect to. This is my problem and I do not want to short something out. Hope this helps, I want to get it installed again. Thanks again for caring....Jerry
Posted on Aug 16, 2008
  • 3 Answers
SOURCE: wiring diagram to connect programmable Thermo to Heat Pump
I don't know if this will be helpful or not, but I just installed a new Honeywell and the Honeywell customer service guy helped me get the wires done correctly. The number is 800-468-1502.
Posted on Jan 05, 2009
SOURCE: Wiring Diagram for Ruud Heat Pump
Unfortunately, the wiring diagrams for heat pumps are not so easy to come up with. The outdoor unit will have its own diagram, but may not include the indoor air handler and will probably not include the thermostat. That said, the orange wire is commonly run from the thermostat to the reversing valve in the outdoor unit. This wire is usually not connected to the indoor airhandler. The orange wire is usually used in a unit that has the reversing valve energized in cool. Ruud, however has its reversing valve energized in heat. Probably not useful but maybe helpful
Mike
Posted on Mar 26, 2009
  • 142 Answers
SOURCE: irrigation sprinkler pump, flotec, 230VAC wiring
green to srcew on the motor. this is ground.,
Black on T1
Red on T2
If the rotation is going the wrong way, simply switch the black to T2
Red to T1.
Check this before you couple it to the pump..
Posted on Jun 03, 2009
  • 10 Answers
SOURCE: NEED A WIRING DIAGRAM FOR 2008 KLR 650
http://www.bigcee.com/faq/KLR650-color-wiring-diagram.jpg
Posted on Jun 14, 2009
How to unblock. Impella on jprain4 pump grundfos
Grundfos is the only pump I know of that needs to be freed before every heating season. I like Taco.
Feb 19, 2017 | Grundfos Plumbing
WHY DOES MY BOILER PUMP CONSTANTLY RUN
Hello anon, this sounds like there is a problem on the electric side of your boiler. Depending on the boiler if its a combi type it is one of the pcb's calling for the pump to run. If at all possible call a specialist who deals with Central Heating and dont try and fix it yourself.
Aug 02, 2014 | Grundfos Pumps Grundfos Redi-Flo2 Electric...
Central heating pump stops running
If you can not hold your hand on the motor for a count of 10 when it has cut out, the motor has overheated and needs to be replaced or find some reason for an overload.
Jun 21, 2017 | Grundfos Garden
Grundfos jetpaq pumps
Sounds like a broken connection or a link in the over temp circuit.
Or the controll is knackered.
I would say it is unlikley the motor has failed, I have stripped water related dead seized grundfoss units and freed them back up and they have outlasted an economy replacement unit.
I am assuming your unit is single phase, if it is there should be an internal OL reset.
I am not sure where exactly on your unit but if you open the control box it should be evident.
If it has tripped I would check the capacitor as over time they diminish in capacity which would lead to overloading or not start at all which would trip the OL very quickly.
Dec 01, 2013 | Plumbing
One of my 3 Grundfos UPS 15-58 FC pumps on my heating system has a slight rattle and is running very hot. The temperature drop across the pump is also much greater than that of the other supply side...
In most cases the impellers are what fail in these pumps. Generally speaking if a bearing is going out you won't have a heat difference you would have a pump that fails to run due to overheating of the thermal overload or the circuit breaker tripping. You can test the pressure to see if it's the same or close to the others 15% or more requires a replacement of the impeller.
Running these pumps without fluid will also quickly destroy impellers within 10 minutes. They require that fluid to stay cool.
Oct 13, 2013 | Grundfos Pumps UPS15-58FC
Wiring diagram for grundfos pump
It depends partly on your phase and voltage requirements, but here is a picture of some options.8_7_2012_4_14_07_pm.png
Aug 04, 2012 | Grundfos Pumps Grundfos CH4-50 11 2Hp...
I just recieved a grundfos add on timer for my small circulating pump the wiring diagram is not clear need some advise on how to wire
More information is needed. Add a comment.
Grundfos makes many models and many parts.
http://www.plumbersurplus.com/Prod/Grundfos-24-HR-Programmable-Clock-Timer-%28505474%29/11040/Cat/680
You do not say what wires what are available, or what the instructions say, so the expert is left guessing.
Guessing: Normally this type of timer module has at least 4 or 5 wiring terminals.
Two terminals power the clock motor, and two terminals are for the switch.
Example wiring: power from circuit breaker connects to terminals 1 and 3, line going to motor connects to terminal 4, and neutral from breaker box and neutral going to motor connect to terminal 2.
http://waterheatertimer.org/images/FM1-wiring-280.jpg
Another basic wiring plan same as described above:
http://waterheatertimer.org/images/NO-NC-timer-200.jpg
Add a comment with exact information shown in instructions, and what wires you have, and what each wire goes to.
Of add a comment with in-focus photo posted on flickr.
Open following link for recirculation system resources:
http://waterheatertimer.org/Water-heater-recirculation-system.html
Jul 06, 2011 | Grundfos 505474 24-Hour Progammable...
Just bought a house and it has a grundfos timer/pump attached at the hot water tank. I have no hot water and the timer doesn't turn (as I've seen other timers do). Is it supposed to turn so that the...
Grundfos is a sealed unit and not a repairable item.
The timer dial should turn.
And pins located around dial control ON-OFF functions as timer dial rotates.
Does the receptacle have power?
If receptacle has power, and Grundfos is not working, then it is broken.
Grundfos manuals for UP series pumps do not show breakdown or parts list of any kind.
http://www.us.grundfos.com/web/download.nsf/Pages
Bigger question:
Why don't you have hot water?
Is water heater functioning?
Water heater is a separate appliance from Grundfos pump.
Grundfos pump circulates hot water from tank into the lines so there is no waiting for hot water ... but hot water heater should still make hot water.
Add a comment about water heater if that is also a problem.
You could have 2 problems, and water heater is main issue.
For do-it-yourself electric water heater repairs:
http://waterheatertimer.org/6DIY.html
Nov 20, 2010 | Grundfos The UP1510B5ATLC 125th HP 1...
Grundfos submersible well pump with Grundfos CU301 control. Control box shows no contact to pump. What is the problem or problems?
Grundfos is a p. o. s. I have a new system cu 301 and I have had to get it repaired twice by Fogle Pump and Supply. These guys are real rip of artists in Washington State and should be reported to the BBB. Dont Use Fogle if you need a well
Sep 15, 2010 | Grundfos RCP-96 Recirculation Pump for...
Plumbing Logo
102 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
