Question about Honeywell Heating & Cooling
Wire a 6457 honeywell
I need to wire a 6457 into a s plan system which are the motor terminals and which are the interlocks please
SOURCE: Where does the T Wire go on the RTH7400
the t wire is for an outdoor anticipator reset. If you dont have a terminal on your thermostat it does not have to be used. Just tape it off.
Posted on Jan 19, 2009
billyvangogh
  • 108 Answers
SOURCE: need to wire a honeywell RTH7400D thermostat to 3 wire hot water
Just mark the old wires on the old thermnostat...R , W etc...and put them on the same terminals on the new 1.....also there should be some adjustment ire : switch on the back or under the cover to adjust for Hot water heating or electric heat...either is the setting you should have it on....also you shouldn't setback the thermostat at night or when away very much....2 degrees is fine , as the boiler will run along time to raise the temperature in the morning and may not get there by the set time
Posted on Oct 26, 2009
heatman101
  • 43501 Answers
SOURCE: three wire system, going to a five terminal
The Rc and Rh should have a jumper wire between them let it in. and hook the red wire to one of them it does not matter which one as they are jumpered. The white wire goes on the "w" terminal and the Blue wire will go on the "G" green terminal to run your fan.
This should get you up and running again!
Posted on Nov 13, 2009
  • 587 Answers
SOURCE: i need a y plan wiring diagram
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Posted on May 12, 2010
  • 192 Answers
SOURCE: Removed my non programable
Leave the factory jumper between R & RC. Connect the wires to the new stat just as you have them labeled. Use a piece of thermostat wire to make a jumper from AUX to E terminals. Your new thermostat should give you instructions on how to access the installer set up. You are going to set it up as heat pump with aux. I see this is 2 days old but if you need any help let me know.
Posted on Feb 15, 2011
My Honeywell HZ311 3 zone system (Cool & Heat) system all lights are flashing. Please advise how do i reset (restart) the stem. Thank you!
Honeywell TrueZONE HZ311, HZ322, HZ432 Manual
www.manualslib.com > ... > Other > HZ311, HZ322, HZ432
View and Download Honeywell TrueZONE HZ311, HZ322, HZ432 manual online. ...Page 3. Zoning System Design Manual IntroductIon Fig. 2 depicts a typical residential layout with three zones. ... Zoning System Design Manual Plan the Zones In planning azone system, here's what you need: Panel ... Restore password.
Sep 29, 2015 | Cars & Trucks
I just recieved a grundfos add on timer for my small circulating pump the wiring diagram is not clear need some advise on how to wire
More information is needed. Add a comment.
Grundfos makes many models and many parts.
http://www.plumbersurplus.com/Prod/Grundfos-24-HR-Programmable-Clock-Timer-%28505474%29/11040/Cat/680
You do not say what wires what are available, or what the instructions say, so the expert is left guessing.
Guessing: Normally this type of timer module has at least 4 or 5 wiring terminals.
Two terminals power the clock motor, and two terminals are for the switch.
Example wiring: power from circuit breaker connects to terminals 1 and 3, line going to motor connects to terminal 4, and neutral from breaker box and neutral going to motor connect to terminal 2.
http://waterheatertimer.org/images/FM1-wiring-280.jpg
Another basic wiring plan same as described above:
http://waterheatertimer.org/images/NO-NC-timer-200.jpg
Add a comment with exact information shown in instructions, and what wires you have, and what each wire goes to.
Of add a comment with in-focus photo posted on flickr.
Open following link for recirculation system resources:
http://waterheatertimer.org/Water-heater-recirculation-system.html
Jul 06, 2011 | Grundfos 505474 24-Hour Progammable...
Replacing an ST699 with a ST9400C following repl wiring diagram, but programmer does not come on. Is the diagram incorrect? Wiring colours do not follow any of the plans. Syst has room stat, cyl stat,...
Disregard wire colors. Instead wire by terminal designation. In other words :
Wire on "R" Terminal on old thermostat to "R" Terminal on new thermostat no matter the color.
Jun 14, 2011 | Honeywell Heating & Cooling
I need to replace an old Thermostat that just has 3 wires coloured Red, Blue and Yellow. The Honeywell THR830TUK Thermostat I have bought shows 5 wires on the diagram. I'm not sure which wire goes into...
The honeywell THR830TUK thermostat does not require a neutral as shown in the instructions.Connect the LIVE to terminal "1" and your YELLOW SIGNAL wire to terminal "3".
Connect your EARTH (if you have one) to the EARTH connection on the top left hand corner of the thermostat and blank off your NEUTRAL wire with a block connector.These instructions were supplied to me by Honeywell Customer Support.Hope this helps.
Jan 08, 2011 | Heating & Cooling
I have an intermatic C8865 timer. i want to wire it into an EFM model AF150-1 coal stoker furnace, because the fire goes down to far inbetween actual times heat is called for. also have main switch for...
Intermatic C8865 timer is a 5-hour cycle timer that repeats same cycle each 5 hour period.
This timer has 120Volt clock motor and is 120V timer.
Timer has NO and NC terminals.
NO terminal turns ON when timer turns ON
NC terminals is ON all the time, except when timer turns ON. At this point NC terminal turns OFF.
You have 3 things: 120V timer, 120V honeywell transformer, 120V stoker motor/fan
The transformer needs to be ON at all times.
The stoker motor is going to turn ON when the cycle timer turns ON.
You have 120V cable with black wire, white wire (and bare ground, which connects to green ground screw and to other bare grounds and won't be discussed further)
Black wire is hot
White wire is neutral
Black wire connects to 'Switch common terminal' on timer.
Same wire also connects to black wire on Honeywell transformer.
White wire connects to 'Clock terminal' on timer
Same wire connects to white wire on Honeywell transformer and to white wire on Stoker motor.
So all the white wires are connected together.
Last wire is black wire to stoker motor.
This wire connects to NO terminals on timer.
Here is drawing.
Add a comment any time
Dec 13, 2010 | Intermatic C8865 Timer, 1HR CYCLE TIME, 30...
I need a y plan wiring diagram
HONEYWELL WEBSITE:
Go to honeywell.com
Apr 22, 2010 | Honeywell Programmable Thermostat Heater
Cannot get central heating working,for honeywell ST6400 programme
with y plan 3 connections on programmer HW on HW off CH on HW on to cylinder stat then HW call to Orange on Mvalve to power boiler and pump HW off to grey wire on Mvalve to close hot water CH to room stat common then heating call to white on Mvalve
Jun 13, 2009 | Honeywell Programmable Thermostat Heater
Honeywell RTH3100C
You need to go into the installer setting to change it from heatpump to single stage gas heat.Go to www.honeywell.com if youve lost them.
Dec 13, 2008 | Honeywell Programmable Thermostat Heater
Hi i am working as an electrical installer and would like to know where i can access all the electrical drawings for all the different heating systems Honeywell
http://www51.honeywell.com/aero/Products-Services/Avionics-Electronics/Egpws-Home3/InstallationInformation3/digs-draw-sw.html?c=21
try this.. all honewell drawings.. in it
Nov 13, 2007 | Honeywell HFS641P Stand (Pedestal) Fan
Heating & Cooling Logo
74 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
