I HAVE A EMERSON TV AND IT WONT TURN ON, IS THERE A RESET BUTTON?
THE POWER SORCE HAS POWER BUT THE TV WONT TURN ON
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
No reset or circuit breaker on this type of set--if you can safely open it follow the power cord inside to the fuse and check it first.
Posted on Nov 08, 2012
My Emerson TV wont turn on
Could be an open internal fuse or power supply failure
Aug 03, 2017 | Emerson Televison & Video
While I was watching my Emerson TV I heard a loud click and the screen went black and audio went off. When I press tv button on cable remote the tv button glows red, and nothing happens on the tv.
Hi the power supply might have shut down through overheating turn the power of at the wall socket & wait for a short time before trying again the TV might reset itself if this doesn't work its probably shut down from a faulty component. good luck
Oct 23, 2016 | Emerson Televison & Video
Tv wont turn on
Is the outlet powered? Try turning set on with own power button? Remote power button? If still nada, then check to see if something is amiss with the power supply section of set. Look for bad caps and diodes.
Oct 07, 2015 | Emerson Used Original BLC320EM9 Remote...
The volume onmy Emerson TV turned down to zero. I turned it up with the buttons on the TV it turned back down to zero. The zero volume stayed on the screen.I turned the volume up withremotenoresponse.
The main system control memory IC to this TV is damaged. Replace it. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jun 27, 2015 | Emerson Televison & Video
TV WONT POWER ON
Hi does the TV have any standby light etc, if so power off at the wall and leave for 1 minute the power back on and watch the standby LED it may or may not blink try to power on if the light blinks this may be a fault code and you can search this up with the model number.
Apr 08, 2015 | Emerson LF320EM4 32" 720p 60Hz Class LED...
Emerson tv problems
sounds like a button problem, your remote seems to be in programming mode,
I would take apart and clean,
Take batteries out 1st.
# 2 Take a Q tip with rubbing alcohol and swab your keys.
# 3 use some compressed air to blow out and dry keys.
# 4 Re- set your TV to factory reset.
Power tv up and follow instructions to remote set up.
Jul 18, 2014 | Emerson LC320EM9 32 in. LCD HDTV
Tv wont come on,sensor light flashing red and blue, emerson
hi, this fault could be down to capacitors on the power board
regards
shaun
Nov 10, 2013 | Emerson Televison & Video
I HAVE A EMERSON 20
If Emerson parts may be scarce or hard to find--20 inch set may be cheaper to replace than fix. I can offer some suggestions but what is your skill level? l see some who cannot even safely get the set apart.
Nov 07, 2012 | Emerson Televison & Video
I have an Emerson TV Model # EWF2004A, where is the reset button on it or does it not have one
Most Emerson sets must reset with power OFF. Just unplug the TV from aC mains power wall socket, and re-plug it back after 10 minutes or so. This must make a hard reset to TV. If the problem is with resetting, it will get rectified.
Jul 04, 2012 | Emerson Televison & Video
Emerson sb350 ( spongebob dvd combo )
I had the same problem.I fixed it by unpluging the tv.Then while holding in the power button I plugged it back in,still holding in the power button for twenty seconds.That fixed it.I read somewhere you could reset a Sony that way so I gave it a try and it worked.I also put a cd cleaning disk in it because it was saying "wrong disk" and that fixed that problem.Good Luck
Aug 10, 2007 | Emerson SB350 13 in. TV/DVD Combo
Televison & Video Logo
506 people viewed this question
Top Televison & Video Experts
Electro Med Services...
