Question about Genie Company Vacuums
We have an old genie 5 gal wet/dry vac 1.25 peak hp 60hz 125ph 8.5 amps That is all I can find on it for numbers or letters. The top is bloack, the drum is red. The bag around the filter is to
All details found on it are listed in the What's your problem box.
SOURCE: USE GENIE WET DRY VAC WITH OR WITHOUT PAPER LINER?
I wanted to clean out my wood burning stove ashes. When I turned the vacuum on, the ashes blew out the top???? Is there supposed to be a bag or filter to keep this from happening?
Posted on Aug 05, 2009
shastalaker7
  • 1515 Answers
SOURCE: Older model shop.vac parts/owners manuel
Hi, I know on my Craftsman shop vac 2 different sizes of vacs that I use, I try and stick to the craftsman filters, but you can use other brands if they are not available or you want to save some ( $ ) ? As far as a manual for this vac, more then likely you will have to go to the maker and distributor as Sears, O.C.Hardware also sell there products. You may have to go with a manual that is the same peak H.P.and gallons that covers all different makes and models. Filter wise, make sure you have the right ones on or off when using the wet or dry pick-up settings.
Sincerely,
Shastalaker7
Posted on Jan 23, 2010
  • 11 Answers
SOURCE: jhe4576. I own a Genie SV125Q, 5 gallon wet/dry
Where did you buy this unit from? Go back there and ask if they have filters for yours. Otherwise look in the Yellow Pages for vacume cleaner repair shops. Sometimes they have all kinds of filters for all kinds of vacumes. You can try places like Wal Mart. What you want to look for are filters that will work with your unit. The foam filter you refer to is called a pre-filter. It traps the bigger particles so they won't damage your paper filter or clog it up especially if it's wet stuff you're picking up. You can remove that foam filter and gently wash it out in the sink with a mild dishwashing liquid and warm water. And even sometimes if you have time you can wash a paper filter out by hosing it out from the inside, with just a gently rinsing on the outside. Don't use any solvents on it just soap and water. And don't use high pressure either, as it will destroy the paper. I have cleaned my paper filters several times before I finally had to replace them. You can also look at places like Lowe's. They carry shop vacs and a whole assortment of attachments as well.
Posted on Mar 08, 2010
pappapumpdaf
  • 635 Answers
SOURCE: genie 400PC 16 gal shop vac but can't find filters
If you need paper filters, you can easily use a bag filter cut in half, and have less dust clouds than the original filter. Remember to use the lock ring. Generic ShopVac mini's have the same filter in foam.
Posted on Mar 11, 2010
Testimonial: "I have a lot of upright vac bags from long gone vacs & I hadn't thought about cutting one down! Good idea, now I've just got to go get a foam filter."
javeedcare
  • 316 Answers
SOURCE: I have an old shop
http://www.hammerwall.com/Download_Manual/16114/
GO TO THE ABOVE ADDRESS TO GET YOUR MANUAL.
REGARDS.
PLZ RATE THIS
Posted on Jul 04, 2011
I ran over the cord to the vac with my lawn mower ,I need to replace the damaged cord with a new one. How do I remove the old cord?
You need to remove the screws that are in the location of where the wire goes into the vacuum. Then you will see a cord grip and connectors for the wires.
May 13, 2016 | Craftsman 2.5 gal, 1.75 Peak HP Portable...
Is there an 800 number where I can reach customer service for my shop vac?
I cannot find a 1-800 # but here is some of the contact info from their website. Hope this helps.
https://www.shopvac.com/contact.asp
United States Customer Service
Phone: (570) 326-0502xepmsfks7ymm8bsamlyf2owtpszamzmeaygcpjvaaaaaelftksuqmcc
Fax: (570) 326-7185xepmsfks7ymm8bsamlyf2owtpszamzmeaygcpjvaaaaaelftksuqmcc
Web: Send Email
Regular Business Hours: Monday - Friday, 8:00 AM - 5:00 PM EST
Jul 16, 2014 | Shop-Vac Corporation 18 Gallon 6.5 Peak Hp...
Where can I find a filter for genie sv300q?
I have the Genie 3000 which is a 20 gal. wet/dry vac with a 3.0 HP motor. I had bought at Home Depot some 20+ years ago. I bought a replacement filter at HD made by someone other than Genie and claiming to fit my model...but it did not fit...too loose to stay in place. I did track down some hypo filters that might fit...but at $28+ for the filter I decided it was time to get a new model with better and cheaper and available filters. I bought a Ridgid WD1451 14 gal with 6.0 HP. It is so much nicer and quieter. HD regularly carries the WD1450 for $99 or so. The WD1451 is the same model but also had the car vac hose and attachments (a $40 set) included for free. That was a limited offer probably no longer available. Get you a new one and enjoy it...I did...and I still have the Genie...but I think I'll toss it because it is too big, too loud, and I love this new Ridgid.
May 28, 2014 | Genie Company GV150 Wet/Dry Vacuum
Wet vac wont turn on
That Model of Shop vac often has on/off switch failure.
Dec 02, 2013 | Craftsman 20 gal, 6.5 Peak HP Wet/Dry Vac
Trying to vacum and it starts to blow
There are two outlets on a shop vac one to blow and the other to vacum.
Dec 13, 2012 | Craftsman 12 gal 5.0 peak hp Wet/Dry Vac -...
Small wheels missing scratches floor
http://www.ereplacementparts.com/hoover-s3765-windtunnel-bagless-vacuum-parts-c-37315_37445_37456.html
Here is a link I found. Since you listed the Product being an s, it won't be compatible with anything else other than an s.
Jul 28, 2012 | Vacuums
Dc08 animal turbine head
I'm not sure from your question what sort of issue you're having with the turbinehead. If you can reply and provide me with more details, I'm sure I can help.
Alternatively, you may find the answer to your question on our online Support page. If you select your machine from the list, you'll be able to find troubleshooting guides to help resolve many simple issues:
http://support.dyson.co.uk/Support/Cylinders.aspx
If you'd prefer to speak to someone in person, one of our advisors will be happy to provide assistance - please call us free on 0800 298 0298. Our Helpline is available from 7am until 10pm, 7 days a week.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Feb 27, 2012 | Dyson DC08 Cylinder Bagless Canister...
THE BRUSHES ON THE CLEANERHEAD WONT ROTATE. EVEN THOUGH I HAVE BOUGHT A BRAND NEW COMPLETE BRUSH HEAD ASSEMBLY. AND I HAVE PRESSED THE SIDE RESET BUTTON. PLEASE CAN YOU HELP ME.
I'm sorry to hear you're having difficulties with your DC24. If you've found the new cleaner head hasn't helped, I'd encourage you to get in touch with us directly - one of our experts will be happy to provide the assistance you need. As long as your cleaner has been used in accordance with the terms and conditions listed in the user guide, it should be covered by our 5-year warranty. You can call us free on 08002980298 - our Helpline is available from 7am until 10pm, 7 days a week. We'll look forward to hearing from you.
Kind regards,
Jack
Sep 12, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
Vacuums Logo
451 people viewed this question
Top Genie Company Vacuums Experts
Michael Vincent Cruz
richie46
Are you a Genie Company Vacuum Expert? Answer questions, earn points and help others
