Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Compression Poulan chainsaw
I have a Poulan Wildthing chainsaw and I need to know the compression pounds to set it?
Thanks Rodger
  • 181 Answers
You can not set the compression on two cycle motors,the compression new is at about 90 to 95 pounds after six to nine pulls of the recoil
Posted on Jan 07, 2009
I have a poulan 2375 wildthing it sat for 2 yrs primer ball went bad. replaced it. it is getting fuel and has compression but spark seems weak and it will not start
Get a can of Nulon starter fluid and spray in the carby or a bit down the plug hole,it,s probably dried out.the Nulon is called Start you ?????.The spark appears weak on those machines ,that's normal.
Oct 01, 2016 | Poulan Garden
Need to know what the compression should be for a 2150 poulan chainsaw
the compression on a chainsaw can be checked by simply holding the crank rope by itself, it should chug down the rope very slowly.
Apr 03, 2013 | Poulan Oregon Chainsaw Chain For Chainsaw...
Poulan 18" wildthing chainsaw wont start
have you tried spraying Starter fluid into the Carb to see if it will at least try to run and verify you have good spark?
Dec 05, 2012 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan 18" wildthing chainsaw (model
This could be a couple of things, if the fuel tank brather is blocke the tank will vacume, to test this try slackening off the fuel cap when the saw starts to die, if it picks up again it is a fuel tank braether issue, the other possibility is a bad ignition unit breaking down, the only test for this is to replace the unit and try again.
Sep 19, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
How do i get the side back on my poulan wildthing theres a ring on the cover does whats the trick on getting it back on does it go around the sprocket housing or inside it
That is the brake ring and should fit over the clutch outer drum. If the brake was set when you pulled the cover off, it will be necessary to release the brake mechanism to get it to pass over the drum. Good luck!
Sep 08, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Runs to fast
You need to adjust the idle and high speed screw settings on the saw. Consult your user manual for tuning the engine.
Feb 13, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Wildthing 18" chainsaw 2375 sprocket/drum replacement
mso 9]> Normal 0 false false false MicrosoftInternetExplorer4 mso 9]> mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> mso 10]> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi tchild,
my name is Dennis Gladx and I can assist you with the problem of getting the sprocket off of the crankshaft of your chainsaw.
To remove the centrifugal clutch and sprocket you unscrew it from the crankshaft and it has a left hand thread. Also a little trick to remove anything from a crankshaft that could turn while you want to unscrew the item, Remove the spark plug and insert some rope into the cylinder for the piston to squeeze against and you will jam the piston without damage.
Glad to be of assistance Please rate this solution because I can learn from your rating. Thank you
Nov 08, 2008 | Poulan Garden
Poulan wildthing chainsaw
Go on the internet to:
http://lawnandgarden.manualsonline.com/manuals/mfg/poulan/poulan_gas_chainsaw_product_list_3.html
this is a free site that will give you access to a manual.
Pleased to be of service.
Oct 19, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
726 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
