Question about Emerson MW8168B Microwave Oven
Our Emerson MW1161SB smells like electrical burning won't heat
SOURCE: i need a manual for MW1161SB suffix A 120V
I have the manual, tell me what you want to know, and I'll look it up
Posted on Jul 11, 2010
  • 8909 Answers
SOURCE: i need a glass turn tray for emerson microwave
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies and Driver downloads (if applicable) as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Posted on Dec 31, 2010
heatman101
  • 43501 Answers
SOURCE: mw1161sb suffix a emerson microwave
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
[]\\\\\\\\\\\\\\0
Posted on Feb 22, 2011
heatman101
  • 43501 Answers
SOURCE: Emerson microwave oven MW8102SS smells electric
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 '
Posted on Jun 10, 2011
walesarumi
  • 6993 Answers
SOURCE: MY EMERSON MW8987W MICROWAVE WON'T HEAT UP
Investigate these three areas if your microwave won't heat up foods.
Power Diode
A diode is an electronic component that readily passes current in one direction only and blocks the flow of current in the opposing direction. If your microwave's diode has become defective, your microwave will not heat. Test the diode to determine if this is the cause of your problem. Replace it if it is defective.
Testing a diode
NOTE: Before you test your diode, make sure your microwave is unplugged, and that you discharge the microwave's capacitor.
Whether it is shorted or open, a defective diode will most likely show some sign of defect. Defective diodes will usually emit an electrical burning smell, signifying its defectiveness. Also, it may have split in two, or it may exhibit a burned crack, or possibly even a blistered spot.
A shorted diode is indicated by a loud humming noise from the high voltage transformer, and no heat produced when a cook cycle is initiated. Whereas little or no heat produced in your microwave, with an absence of a humming noise is indicative of an open diode. In either case, the diode has to be replaced.
With your microwave unplugged, and your capacitor discharged, use extreme caution to remove the lead that leads to the capacitor. You can leave the ground connection attached. The side of the diode that goes to the ground is usually marked with a dot, stripe, or arrow. Set your ohmmeter to R x 10,000 or higher. Touch the positive meter probe to the anode and the negative meter probe to the cathode to measure the resistance across the diode terminals. Remember that the cathode is on the side that goes to the ground, which is often marked by a dot, stripe, or an arrow.
A normal diode, that is a non-defective diode, will read anywhere from 50,000 to 200,000 ohms. Differences in microwave make and model account for this large range in resistance readings.
Reverse the meter probes and measure resistance while touching the positive probe to the cathode and the negative probe to the anode. Reversing the probes like this should result in a reading of infinity. Unless a bleeder resistor is present. The presence of a bleeder resistor would produce a reading of the value of the resistor.
High Voltage Capacitor
A capacitor is an electrical device which stores electricity. A defective capacitor may be why your microwave is not heating. The capacitor will have to be tested to determine if this is the cause of your problem. A defective capacitor will have to be replaced before your microwave will work again. Make sure you discharge the capacitor before you test it, though.
Magnetron
A defective magnetron is the third possible cause of why your microwave is not heating. Test your microwave's magnetron. Replace it if it is defective.
Testing a magnetron
NOTE: Before you test this component, make sure your microwave is unplugged, and that you have discharged the capacitor.
There are two tests to conduct in order to determine whether or not a magnetron has become defective. If you receive results other than what are detailed below, you will have to replace your microwave's magnetron. Each test is described for you here:
TEST 1: Locate your magnetron and label each of the wires attached to it so that you know which wires are to be replaced where. Set your ohmmeter to the lowest resistance scale. Take a resistance measurement between each of the magnetron terminals by touching each probe to one terminal each. Reverse the probes and take a second resistance measurement. Each measurement should read less than one ohm.
TEST 2: Set your ohmmeter to its highest resistance scale. Touch one of the meter's probes to a magnetron terminal. Touch the other probe to the metal magnetron housing. Take special caution to not touch the two probes together. This could result in an inaccurate reading. This test should produce a reading of infinity - indicating an open circuit.
If you cannot perform the above task yourself, ask a family or friend that has the ability to assist you or have a certified and experienced appliance repair technician examine and replace your magnetron. This task is much too dangerous for the average layman to perform on his own.
Read the tips on the below links on how to replace your microwave oven's diode and how to discharge the capacitor.
http://www.fixya.com/support/r7088355-replace_microwave_ovens_diode
http://www.fixya.com/support/r7088317-discharge_microwave_ovens_capacitor
I hope the above is helpful.
Regards.
Walesarumi
Posted on Sep 29, 2011
I need a manual for Emerson microwave model mw1161sb suffix A
Email the company they will tell you how to get it in PDF form from thjem
Apr 29, 2014 | Microwave Ovens
My emerson microwave turns on but it won't cook or
Check to see if it has a DEFROST SETTING if Defrost setting is on it will not reach an adequate temperature
Jun 07, 2012 | Emerson Microwave Ovens
Emerson microwave oven MW8102SS smells electric burn while heating food.
heatman101 '
Jun 07, 2011 | Emerson MW8102SS 1100 Watts Microwave Oven
Mw1161sb suffix a emerson microwave not heating food
Basic
heatman101
[]\\\\\\\\\\\\\\0
Dec 18, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
I need a manual for MW1161SB suffix A 120V
mcdevito75 here, You should be able to contact Emerson online or check with any store selling Emerson microwave ovens for contact info.
Jul 09, 2010 | Emerson Microwave Ovens
Not heating. Electrical burn smell.
Basic Microwave Oven TroubleshootingTips
heatman101][[\\[]
May 19, 2010 | GE JVM1440 Microwave Oven
Emerson Model MW8627W does not heat after changing fuse!
check the magnitron and capacitors one of this is bad
Sep 18, 2007 | Emerson MW8627W Microwave Oven
Emerson MW8168B Microwave Oven Logo
126 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
