Question about Car Audio & Video
What does the colors mean? - Car Audio & Video
    Master:
  • 689 Answers
What do you mean buy what does the colour mean for what? Need better details.
Posted on Nov 08, 2012
Olevia tv shows nothing but black and white color how do i fix it
Black and white like no color, what does black and white color mean?? not sure what you mean
Mar 19, 2018 | Olevia Televison & Video
I have a Mitsubishi 65" dlp TV and the picture is green and yellow with no reds or magenta's so would that mean i need a new bulb or does it have something to do with the color wheel
It means that the color wheel or it's encoder is not properly syncing with the controller. It is therefore blanking the DLP chip on the red and blue sections of the color wheel. Clean the color wheel motor and encoder disk, lubricate the motor. This should correct the problem. There may be dirt in the opto-coupler that is reading the color wheel. Be sure to clean it with a vacuum and small brush. Regards.
Nov 28, 2015 | Mitsubishi WD Televison & Video
What do the different colors of roses mean?
it is amazing what u can learn by learning to google
try "color of roses"
Mar 18, 2015 | Garden
No picture just a bar of color and the sound change color bar
l think you mean no picture except for the display for color and sound--If menu comes up also that means the OSD is ok.
Video problem in that case and almost certain the main board is the reason.
Dec 07, 2012 | Toshiba 40RV525U 40 in. LCD TV
For a maytag dishwasher WU900 need a wiring diagram thanks Norm
Each component should be labelled clearly on your diagram. Look at figure 6-A. The symbols used to represent each component are pretty universal.
Wire colors are abbreviated and shown next to each wire. For example, Y means a yellow wire, V means Violet, R means red, LBU means light blue. Black is usually abbreviated BK, blue is usually BU. GR or GN are green, GY is gray. A wire color with a dash or a slash means --- with a --- stripe. For example BU-W means Blue with a white stripe, T/R means tan with a red stripe.
Figure 6-A: Typical Wiring Diagram
Oct 17, 2010 | Dishwashers
I have the machine fax Canon Pixma MX 300. It writes "Recommend new C-CRT". Please, explain me what it means.
If the machine is a color printer it may mean Recommend new Color Cartridge. The color cartridge may be low on ink or defective.
May 18, 2010 | Canon MX300 Office All-In-One Printer
Hp 2110 won't let me print
You have to change the Print -> Settings -> Preferences
O Print in color (this means color inclufing B&W)
O Print in Black (this means print in black only)
Select the Print in Black
When the printer says replace the color cartridge, just close the window instead of saying Yes or OK.
This is not the official HP trouble shooting solution. But, it often works
Good luck
luciana44
Jan 07, 2010 | HP Office Equipment & Supplies
Color ink for ip1000 does not flow..??
Now put out u color cartridge and take one tissue paper or toilet paper then put ink color head to paper(soft pressure).after that see u paper are inside show three color appear in paper????(red,yellow and blue).if all have means you cartridge ok if only same or no any coming out means u color ink problem need to replaced new unit.
if got all color out better u open u printer body and check are all cable u plug in back is correct or wrong position??.second u can try go to printer preferences go to find print out in color or in gray-color and change their setting to print out in color
Sep 01, 2009 | Canon PIXMA iP1600 Printer
F380
You are using HP's cartridge with the smallest output . So if you are printing 80 pages of text, you will have a problem by the time you reach 95 or 100 pages. If you are printing in color, you only have 1ml/color. Meaning 3 colors. But in order to print a red, it will combine a magenta and yellow to product 1 color. So 3 colors doesn't mean 3 ml worth of colors. Effectively you may only be able to print 10-20 pages of color then your cartridge is empty. The black cartridge has about 4-5ml of ink. So if you print a lot I suggest you get another printer.
Mar 30, 2008 | HP DeskJet F380 All-In-One Printer
Color wheel
as a technician i dont feel the color wheel is a difficult repair. HOWEVER ..color wheel relacement means sometimes depending on model removal of light engine. which means you can get into alignment issues. then once the color wheel is replaced then it too has to be alligned.
Dec 27, 2007 | RCA HD50LPW164 50" Rear Projection HDTV
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
