Question about Zenith SY2768S TV
Tv picture the tv comes on normally and after a few minutes a big black square covers most of the picture leaving only the outer edges and when i change channel the picture will be normal for a few minutes and then the big black square will come again?
  • adowling1 Sep 13, 2008
    I can not find anywhere in the menu to shut off closed captioning
  • 398 Answers
Your closed captions are on and set to TEXT. Go into the menu, turn off the closed captions and the black box will vanish.
Posted on Jun 26, 2007
Black box covers television picture
called a TV repair store, got info over the phone for no charge and the TV is now as good as new. You should tell folks about the charge straight up, I wouldn't mind paying for a service but think you should advise at the onset.
Jan 26, 2009 | Televison & Video
Black Box appearing on my screen
unplug the set for a while , but this problem will return because of a malfunction in the EPROM CHIP , this controls the menu and a few other functions
Oct 17, 2008 | Philips Magnavox 27MS343S 27" TV
Toshiba TP50G60 Big Black Square Covering the screen?
try the closed caption adjustments. i had a tv that did the same thing and the captiong did it. turn caption off nd try.
Oct 09, 2008 | Toshiba TP50G60 50" Rear Projection...
Big Black Square
It turns out that the Closed Caption option was turned on somehow. When I turned that off the Black Square went a way and did not return.
Sep 14, 2008 | RCA T19408 19 in. TV/VCR Combo
Black square on one channel
that's a picture inside a picture option, and it sounds like the inside picture is set for a blank channel...just go to the menu, and shut off the picture in a picture option..should do the trick..
and keep the kids away from the machine
May 24, 2008 | Insignia IS-LCDTV32 32 in. Television
A black box appears on the screen
Just happened to see your black box problem associated with your T.V.; Thought I would pass along an idea for you to check into, and let me know if it helped...Check into whether or not it has a onscreen text block mode, if it gets into this mode by accidentally pressing the wrong buttons on the remote and or TV, it could and I have seen, at least with zeniths, a big black box which will cover the whole screen except for a 2 to 4 inch border around the box and outer edge of the screen...if this is the case, find someone familiar with the correct setting for the set associated with this problem, and get it back into the right mode....Hope this helps..T.
Jan 15, 2008 | Haier 20" TV/DVD Combo
Shut off the closed captioning and your problem will be gone.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Jun 26, 2007 | JVC AV-27F702 27" TV
Tv has lost two outer sides of vision despite changing picture mode
That's either a high voltage problem, or a deflection problem. WARNING, CRT Based Televisions have potently life threatening voltages inside them, and should be serviced by trained personnel only. With that out of the way. According to http://www.repairhelper.com It's a capacitor failure Fault - Width and E/W correction fault Remedy - Replace R626 and C630 I don't have a manual so I can't tell you for sure what the resistor and capacitor do, or where they are located.
Dec 30, 2006 | Bush WS6671 28" TV
Black Square Covers 80% of screen on most channels on TV
have your tv checked by a tech.probably your chip the eprom needs to be reset by lifting it up from the board and resolder back.some one could have put in a code for those channel.good luck.
Dec 27, 2006 | Toshiba CF35E50 35" TV
Televison & Video Logo
117 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
