Question about Magnavox MPD722D 7 in Portable DVD Player with Screen
Av cable shorted out need new cable to have both units working
  • doug pennington Nov 09, 2012
    thanks i have manual one side other does not if i twist cable around second dvd player works so i think cable is shorted out
    Master:
  • 689 Answers
You can get them.At any audio supply store,
Posted on Nov 09, 2012
Postal code for 250 city centre av ottawa
There are multiple units at this address. Postal code for unit 2 is:
2-250 CITY CENTRE AVE
OTTAWA ON K1R 6K7
Dec 14, 2014 | Computers & Internet
Yamaha RX-A1010 died when connecting new cable
check the hdmi jack that you plugged into and make sure that none of the pins got bent. If the wrong pins touch each other or the chassis it could short out something and cause it to shut down.
Jun 24, 2013 | Yamaha RX-A1010 Aventage Audio video AV...
Dvd play works but vcr playing does not
For this unit the component output (green, blue, and red cables) only work for the DVD player portion of it. You will need to connect either the av input on the back or the front with composite (yellow, red, and white cables) to your television in addition to the component cables I assume you have connected already. Once you have done so you will need to switch this unit over to the right av output in order to access the vcr and also switch your television over to the right av input in order to pick up the signal from the vcr.
May 05, 2010 | Toshiba SDV395 DVD Player/VCR
Xbox 360 Video Problem
HI. Replacing the video cable would also be my first suggestion. The Xbox AV cable has many manufacturing faults. If you are using the original cable tat came with the unit, I suggest to replace it with newer model.
Now, if you experience the same issues after replacing the original AV cable, this will lead to a more serious issue that concerns the HANA chip. This chip is responsible for the transfer of information through the AV cables. The transfer port(the AV cable end that is inserted into the Xbox), is directly connected to this actual chip. If the internal connections to this chip have failed, or are failing, this will be the culprit. The chip will need to be replaced, or the solder joint will need to be resolderd. If this unit is still under warranty, I would suggest to contact Microsoft for a free repair ticket. Do Not open the case if the unit is still under the manufactures warranty. This action will void the warranty.
NOTE_ Try replacing the AV cable first.
Jan 19, 2010 | Microsoft Xbox 360 Console
E74 code
E74: AV cable error... There is a problem with the AV cable, try using a different AV cable. If the cable is known to be working then there is a 90% chance it's a scaler chip problem (the "ANA" or "HANA" chip connected directly to the AV cable) in rare cases it is the GPU.
Jun 18, 2009 | Microsoft Xbox 360 Console
I am looking for a repair facility for Adcom pre amp and amplifier in Orange County, CA
Here are all the repair facilities listed with Adcom for Califorina.
Hope this helps.
Accutech
16617 S. Normandie Ave, Ste. C
Gardena, CA 90247
United States
310-324-7406
Classic Audio Repair
3401-F Adams Ave.
San Diego, CA 92116
United States
619-282-9101
classicaudiorepair@gmail.com
http://www.repairaudio.com
E. Joseph (walk-in only)
3969 S. Sepulveda Blvd.
Culver City, CA 90230
United States
310-390-1077
George Meyer TV & Stereo
12418 Santa Monica Blvd.
Los Angeles, CA 90025
United States
310-820-1113
georgemeyer00@aol.com
http://www.georgemeyer-av.com
Northridge Electronics
4505-2B Industrial Street
Simi Valley, CA 93063
United States
805-583-1919
HADRIAN333@YAHOO.COM
Scan Audio Service
8101 Orion Ave, #5
Van Nuys, CA 91406
United States
818-786-4240
scanaudio@sbcglobal.net
Solutions! Speaker Repair of California
4334 Sunset Blvd.
Los Angeles, CA 90029
United States
323-666-4161
TV Unlimited
1296 Kifer Road, #601
Sunnyvale, CA 94086
United States
(408) 733-6913
kdpark@sbcglobal.net
Feb 19, 2009 | Adcom Audio Players & Recorders
GPX PD808B Portable DVD Player
The pin on a regular 3.5mm av to rca is TOO SHORT. If you get the unit from GPX, you'll note it is a bit longer. I found this problem also affected Sony and other portable DVD players - the regular 3.5mm plug is TOO SHORT. I haven't found a source other than GPX for the av cable with the correct length plug. Weird but true.
Sep 02, 2008 | GPX PD808B Portable DVD Player with Screen
Audio but no video when i turn xbox 360 on
hi MC, power off unit unplug av cable from back of xbox.. then power up unit.. after a couple minutes the xbox will shut down.. plug the av cable back in and power up.. Good Luck
Jun 30, 2008 | Microsoft Xbox 360 Console
Magnavox MPD722D 7 in Portable DVD Player with Screen Logo
19 people viewed this question
Top Magnavox Televison & Video Experts
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
