Question about Whirlpool RBS245PDS Electric Single Oven
Whirlpool Model #YGFE461LVQ
Oven overheating - burns cookies in a couple of minutes
Can oven cleaning products be used in a Whirlpool "Steam" Clean oven. My oven did not come clean, baked on stuff did not come clean.
Yes they can be used, but rinse them off and run the oven at 450F to after to burn off any residue. 10 minutes of oven time should do.
Nov 11, 2016 | Whirlpool Ovens
I'm so tired of this! Everything I bake is overcooked/burnt on outside and not cooked on inside. IE..banana bread, cookies, muffins. I have two gauges that are telling me that the temperature is correct. I...
The cheapest would be to go buy an oven thermometer. A couple of dollars. Set oven at 350. Put thermometer on the oven rack. Put in a cake pan, etc with water in it. Let be 15-30 minutes. Then read the thermometer. You can tell by how much it is off.
Really, what might have to be replaced is the thermostat. That constantly trying to kick in would be the ticking noise.
Mar 03, 2014 | Whirlpool Ovens
Oven burns in back and raw in front
That oven is very poorly rated and is prone to a lot of repairs. Most people advise to get something else. There is no common solution. I am sorry.
Feb 15, 2013 | GE Profile JTP56 Electric Double Oven
I turned on self-clean on my Whirlpool self-cleaning oven. After a certain amount of time the oven completely shut down with the control panel blank and the oven door is unable to open. I have turned off...
There is a couple of things that could cause this. This oven has a cooling fan that is supposed to keep the electronics from overheating. There is a thermo cut-off that is supposed to shut it down if this happens.
If it worked like it should, all you have to do is replace the thermo cut-off and possibly the fan. If it didn't the control board will also have to be replaced.
Jan 07, 2012 | Whirlpool RBD305PD Electric Double Oven
Oven won't restart after self cleaning. What to
Try resetting by turning off breaker for a couple minutes then turn back on. If this does not do it you will need to acess you door latch switch. This is acess by removing the top panel. Check for continuity with latch open you should have none and you should have continuity with latch closed. You can enter your model # at www.appliancehelponline.com to bring up illustrations and parts.
Mar 28, 2010 | Whirlpool RBS245PDS Electric Single Oven
Hi i have a very old 1970? whirlpool electric single oven
It sounds like you burned out the oven heating element control board.
Jul 18, 2017 | Whirlpool Ovens
From "bake" mode, oven door locked, both heating elements on.
The F3 E2 error code indicates that the electronic oven control board in the range senses an over-temperature condition in the oven.
This can be caused by a failed temperature sensor probe, a wiring problem between the sensor and the control board, or a failed electronic oven control board.
If the oven is apparently not overheating when this error code appears, then your likely failure is the temperature sensor probe.
If the oven is overheating, then you likely have a failed electronic oven control board due to a stuck relay not cycling the oven heating element off properly.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$%^
Dec 21, 2008 | Whirlpool RBS275PD Electric Single Oven
Whirlpool RBS245PDS Electric Single Oven Logo
209 people viewed this question
Top Whirlpool Ovens Experts
Sal De
Oloyede Monsuru
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
