Question about Samsung Televison & Video
Windex in my tv will it come back to life
My daughter sprayed windex on my tv I think it went into the bottom frame now its showing gray with lines but i can see the regular tv in the back
    Top Expert:
  • Samsung Master
  • 14,553 Answers
The only hope is to have a tech or shop open it---it got down on the board and will rust parts and leads and or damage them---it can be fatal but only a examination will reveal that.
Posted on Nov 08, 2012
Testimonial: "Thank You so Much"
  • Christina Nov 08, 2012
    Sorry But do you think It can be fixed
3 Suggested Answers
  • 1075 Answers
SOURCE: daughter sprayed water on samsung lcd 32 inch on the front panel
electric and water are a bad mix as you know my advice to you unplug tv put it in very warm room for about 3/4 days do not plug in hopefully it can be saved.adrian
Posted on Feb 15, 2009
  • 1335 Answers
SOURCE: sprayed windex on lcd tv
You need to get LCD screen cleaner to keep from streaking the screen. Check with a computer store or an appliance store that sells LCD screens and they can recommend the correct method for cleaning the screen.
Posted on Dec 07, 2010
Fix wet tv
Replace all ur vertical section condenser .
Apr 15, 2014 | Televison & Video
How can I fix a 3/4 inch vertical black line on my Samsung UN60D8000?
When liquid drips onto the x buffer boards (located along the bottom edge of the display panel ) the liquid Will damage the ribbon cables that are connected to the display panel. Replacing the display panel may be the only way to repair the tv. I've been in the tv repair business for over 30 years.... Dan
Jul 15, 2013 | Samsung UN Televison & Video
Black line on hitachi projection tv
sounds like the water has went under the rim and dried there the line will never disapear
Jul 23, 2009 | Hitachi 42V710 42" Rear Projection HDTV
My streetpilot c330 won"t shut off.
IT'S CALLED A FROZEN SCREEN...
2 OPTIONS
ONE, RESET IT !!! (See resetting instructions below)
TWO, let the battery die out!
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Mar 12, 2009 | Garmin StreetPilot C330 GPS Receiver
Daughter sprayed water on samsung lcd 32 inch on the front panel
Feb 15, 2009 | Samsung LTN468W 46 in. LCD Television
How to clean inside of screen?
Your tv has two screens on it. The outter screen and the inner screen. The outter screen has a frame around it held on by clips. You can remove this outter screen by gently prying it from the tv. There is a small gape between the outter screen and the tv casing. When prying the outter screen be carefull not to dsanage the tv case or the outter screen frame. Take note of the location of each clips because you will need thses to put the outter screen back on. Clean with a good gentle screen cleaner, (Do Not Use Windex). Philips screen cleaning gel for plasma & LCD works very good. Install the outter screen back on the tv by making sure the clips line up and use light pressure to snap it back in place. Do Not Hit Outter Screen To Force Clips Into Place.. I do this on my tv about once every 6 months or so.
Jan 04, 2009 | RCA P61960 61" Rear Projection Television
Blank Screen on Garmin C330
It took a nap...
Dec 11, 2008 | Garmin StreetPilot C330 GPS Receiver
Water damage
take the front screen off inspect it, wipe down the tubes and mirror with paper towels and a glass cleaner dont overspray. try that. good luck
Aug 15, 2007 | Sony Grand WEGA KDF-55XS955 55" Rear...
Discoloration from water
I dont think your daughter did any damage bacause the water can not get into the set form the front unless the water went in thru the holes in the back,in that case water can cause a lot problems,it will dry but it will also damage some components,if the water went in from the back you need to take it somewhere to get it clean so it does not built up corrosion with time.Good luck.
Sep 19, 2006 | Samsung LTN468W 46 in. LCD Television
Televison & Video Logo
191 people viewed this question
Henry  Thomas
Henry Thomas
