Question about RCA HD56W58 56" TV
Burning smell, high pitched sound, no power
I love my tv so I hope you can help. It made a high pitched sound, then just shut off and there's a burning smell. Any ideas would be welcome.
4 Suggested Answers
techman
  • 3130 Answers
SOURCE: NO PICTURE, JUST A HIGH PITCH NOISE, SMELLS LIKE SOMETHING BURNING
Very common problem with these sets. The High Voltage transformer and the horizontal output transistor is most likly the problem.. If you know the saftey issues involved and know how to solder and unsolder, you can repair this set but theres a possibility you could also have a fault in the horizontal driver circuit, such as l401. if your not a tech its best to have this set fixed by a trained tech, if you wnt to spend between 175 to 225.00 Good Luck
Posted on Aug 13, 2006
  • 3 Answers
SOURCE: RCA 36" TV - High Pitch Sound - No Picture or Sound
check for high voltage s3ection of your TV. A Flyback transformer is defective especially in the high voltage cale of your flyback....
Posted on Oct 20, 2007
  • 157 Answers
SOURCE: Tv will not power on. Hear a high pitched sound
the horizonal output transistor is shorted-replace it also resolder coil near transistor-if output shorts again flyback transformer is bad
Posted on Sep 15, 2009
Dodge caravan 2001 blowing burning power steering fluid.
I can answer some of your questions without being there in person.
The smell inside the van is from fresh air entering the venting system. Not sure why you don't get it from all vents. The fresh air intake is in front of the windshield and will pick up any smells from the engine compartment.
Loosing the serpentine belt would not necessarily cause you to loose ps fluid, but having a leak could drain the pump and damage the bearings in the pump, causing the pump pulley to drag on the belt.
The ps pump could be in the final stage of failing.
And the shaft seal in the pump could be leaking fluid onto the engine and exhaust.
Feb 23, 2013 | Dodge Grand Caravan Cars & Trucks
UNPLUG SET if you have not done so--fire hazard exists.
I would open rear and LOOK--see what if anything you can see that is burnt---all parts will have a location number printed under or next to them---will point to where problem is---make sure set not plugged in and do not stick your hands inside.
Nov 08, 2012 | RCA HD56W58 56" TV
My 32v434t television.
The TV was making the clicking noise and not turning on because an internal error was being detected.
Now things had got worse , and something had blown inside the TV.
The burning smell and high pitched noise is coming either from Flyback transformer or PSU board. Repair is a delicate matter and must be done by a technician.
Jul 05, 2009 | RCA TruFlat 27F520T 27" TV
MPV 2001 burning smell, high whine?
Sound like the alternator bearings are seized or about to seize. The noise could be the bearings or the belt and the smell may be either of them also.
Jun 01, 2009 | 2003 Mazda MPV
Panasonic WIDESCREEN 52" hdtv: power tries to come on and then there is a burning smell. The power button LED on the TV flashes several times. This starting happening after the TV was on and suddenly...
check of fluid leak from the tubes, check to see where the burning smell is comming from. could be anode, hv wire, splitter, surge caps in h-circuit, but it sounds like a high voltage transformer.
what is your model number of your tv?
Apr 10, 2008 | Televison & Video
Sylvania Television shut down suddenly with a high pitch sound at the back
TV's have a circuit that monitors the high voltage and shuts down the set if it senses something amiss.
Figure on replacing the flyback transformer.
Hope ya fix it!
Jan 28, 2008 | Proton MM2701VT 27" TV
Oct 19, 2007 | RCA 35V432T 35" TV
Panasonic pt-47wx53 problem
What does the light on the front of the TV set do. This is a self diagnostic tool. How many times does it blink?
Aug 16, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Aug 13, 2006 | RCA F36665 36" TV
RCA HD56W58 56" TV Logo
27 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
